Loose Tile - Tiling - Contractor Talk
Loose Tile
Old 02-21-2012, 06:16 PM   #1
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
Loose Tile
When I walk across this floor all the tiles sound like they have sand under them. Sorry it's the best way I can think of to describe it. Anyway they are loose and they come up really easy. I'm thinking the problem is the cement board wasn't screwed down right or the original installer didn't install it right. I plan on taking it all up. Putting down new board and installing new tile. Anything else that could have caused this that I need to look for? The floor is 4 years old.
I need more tools.
summithomeinc is offline
Old 02-21-2012, 06:33 PM   #2
Ash@OTL's Avatar
Trade: remodeling/ home repair
Rewards Points: 160
Re: Loose Tile
Looks like the thinset wasn't properly mixed. It was to dry to create a bond between backer board and tile. No thinset ok the tile you took up. If the same installer did the shower I would check it too.
Ash@OTL is offline
Old 02-21-2012, 06:37 PM   #3
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Re: Loose Tile
Few things...
1) From the looks of no thinset bonding to the tile,the thinset was to dry when mixed or skimmed over before the tile was set.
2) The crunching sound might be for the same reason,only it was the thinset under the cement board that skimmed over.Or no thinset at all.
The above is number three.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 02-21-2012, 06:54 PM   #4
Dan_Watson's Avatar
Rewards Points: 2,748
Re: Loose Tile
Since the questions has been answered..
New hammer?
Dan_Watson is offline
Old 02-21-2012, 07:03 PM   #5
Re: Loose Tile
New hammer?
And New 5 in 1.. The short answer is I don't know where the other 9 are at at the moment. Now I probably own 10 hammers. And at least 20 5 in 1s if I could ever get them all in one place at the same time I would be amazed.
I need more tools.
Old 02-21-2012, 07:11 PM   #6
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Re: Loose Tile
Hehe, same here. Not to mention about fifty seven chalk boxes.
Oh, and caulking guns, let's not forget caulking guns.
From what I can see, not nearly enough coverage, and thinset either skinned over, or was too dry to begin with.
Moot points. Bottom line is, it has to come up.....sorry.
Greg
HS345 is offline
The Following User Says Thank You to HS345 For This Useful Post:
ROVACON (02-24-2012)
Old 02-21-2012, 07:23 PM   #7
Re: Loose Tile
Pretty much what I thought. I was thinking maybe the cement board wasn't screwed down good. Won't matter, It's coming up. Could there be any issues with the subfloor to look for? I think I'm overthinking this But I just want to make sure my job lasts longer than 4 years.
I need more tools.
Old 02-21-2012, 07:25 PM   #8
Re: Loose Tile
Maybe I need to start a new topic on lost tools and where they went. I bought at least 15 roller frames last year, 80 flashlights, 10 oil brushes, who knows on caulk guns.....
I need more tools.
Old 02-21-2012, 07:27 PM   #9
Tile Contractor
HS345's Avatar
Rewards Points: 886
Re: Loose Tile
It's possible, but if so that will work in your favor in this case. Hopefully no thinset under either, which is wrong, but a benefit when tearing out.
Yes, certainly. The subfloor should be a minimum of 3/4" ply or osb. You should also evaluate the joist structure. Size of joists, unsupported span, etc.
Greg
HS345 is offline
Old 02-21-2012, 07:35 PM   #10
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Re: Loose Tile
So what's up with Sharon Stone? I don't really keep up on movie stars.
What everybody else said.
Paulie is offline
Old 02-21-2012, 07:37 PM   #11
Re: Loose Tile
From what I've seen so far the original house was built in '79 and looks good. Had a remodel 4 years ago and everything I've seen so far looks like that tile.
I need more tools.
Old 02-21-2012, 08:58 PM   #12
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Loose Tile
I'm not a repair guy, but when I do, I do a 'start over'.
Pretty much covers all the detective work, unless one was the initial installer.
CO762 is offline
Old 02-21-2012, 09:01 PM   #13
CO762's Avatar
Re: Loose Tile
She's a helper at Stoner Tile.
CO762 is offline
The Following User Says Thank You to CO762 For This Useful Post:
Paulie (02-21-2012)
Old 02-21-2012, 09:10 PM   #14
Re: Loose Tile
Thanks for confirming what I said in the original post.
I need more tools.
Old 02-21-2012, 09:16 PM   #15
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Loose Tile
Gut it. Its all wrong. Id start by underpinning the foundation. The loose tiles are likely the result of improper soil calculations.
ohiohomedoctor is offline
Old 02-21-2012, 09:22 PM   #16
Re: Loose Tile
After I read your post I called everywhere. Finally I found an engineer this late at night. He agrees. We are going tomorrow and have decided that not only is the bathroom floor suspect but, the entire house needs to come down. We start demo at 8 am. Since the house has to be demolished all other outbuildings will be removed as well due to safety precautions. We also discovered that the soil calcs were so far off we are even removing the sod from the entire property just to be thorough. I'll post pics of the completed project.
I need more tools.
Old 02-21-2012, 09:50 PM   #17
Paulie's Avatar
Re: Loose Tile
Better contain the perimeter of the yard with poly. It looks like a pre 78' job, the sod has to be chalk full of lead dust.
Thanks for the update of Sharon S.... I figured the OP would have that mag he was reading between pictures read by now and have some intriguing news.
Paulie is offline
Old 02-21-2012, 09:55 PM   #18
Re: Loose Tile
Old 02-22-2012, 08:37 AM   #19
Aureli Construction
aureliconstruct's Avatar
Rewards Points: 75
Re: Loose Tile
Thinset issue, not tile backer.
www.aureliconstruction.com
aureliconstruct is offline
Old 02-24-2012, 03:51 PM   #20
leoncaesar11's Avatar
Re: Loose Tile
Of u want a good clean durable job I would rip it all up, install brown paper wire lath and mud it up(if on subfloor) then you have a nice level. Strong base, and please use some decent thin set lol.
leoncaesar11 is offline
Commercial Ceramic tile on concrete slab removal TD40 Tiling 5 03-18-2018 07:26 AM
Tile Over Gypcrete Golden Rule Tiling 6 11-26-2010 04:00 PM
Loose ends? Mike's Plumbing Business 7 09-25-2010 09:45 AM
big tile job mnjconstruction Tiling 68 05-23-2010 08:44 AM
Removing tile that is set under base cabinets.. bujaly Flooring 43 03-13-2010 05:15 PM
