Trade: Kitchen Refacer
Rewards Points: 250
Leveling Wall For Tile.
So the tile guy I was going to use flaked on me so now it is up to me to me to do the tile backsplash in this kitchen.
Probably 35 square in total. The problem is the walls are really uneven/wavy. If only we could change gravity so I can use a self leveling compound. Since I am unable to change the laws of physics what can I do here? What would be the best product to use? I was thinking using battens and cement board as an option. Could I get away with 1/4 board? This is a stucco wall. Screws don't hold well though. Any ideas would be apreciated. 4x8 subway tiles. Last edited by DKnafo; 05-18-2013 at 09:13 AM. |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Remodeler
Rewards Points: 574
Re: Leveling Wall For Tile.
Can you float it out with a sand/stucco/mortar mix?
Advertisement |
Rewards Points: 5,782
That could work, try to chisel off some ridges first. If it were a small mosaic you would be alright, but subway......flatter the better. You will need catipillars or rings to extend the electrical boxes. Make sure you check your faucet clearance too.
The Following User Says Thank You to Tom M For This Useful Post: |
TAHomeRepairs (05-18-2013)
Sponsored Links | |||
Advertisement |
Remodeler
Rewards Points: 574
All excellent points, when he said it was stucco I just figured it was an outdoor summer kitchen.
Re: Leveling Wall For Tile.![]() |
#6 | |
Rewards Points: 250
Re: Leveling Wall For Tile.Quote:
I am not sure exactly what it is. Soft whatever it is. Wall in a Manhattan condo. I tried to float it out with a mortar mix but that didn't go over well. I ended up just filling in the deep areas that needed patching. Last edited by DKnafo; 05-18-2013 at 09:33 AM. |
Rewards Points: 250
Were you suggesting I use the battans and 1/4 board or with TAHomerepairs?
Brooklyn|Staten Island Kitchen Cabinet Refacing |
Trade: tile, floors
Rewards Points: 81
Is it plaster? If plaster you could locate the studs, screw diamond lath to it and do a" one step mud job" off solid concrete/ masonry you could remove paint/ stucco, use thinset to bond mud to it.
The Following User Says Thank You to Hank B. For This Useful Post: |
Tom M (05-18-2013)
#9 | |
Thing is if you add lath and skim you end up building out nearly the same as a thin veneer board over furring. |
Trade: Handyman Services
Rewards Points: 16,091
Since it's a "non-wet" area, why not just level it out with setting compound, then prime/seal it? But that would mean waiting for it to dry completely. A quicker alternative would be to trowel on some thinset to the low spots and screed it (probably vertically). Fill in pockets, as necessary, after it sets up. You could install a couple pieces of wood (vertical) to guide your screed stick.
BTW, use the quick-setting leveler for this. Mapei has one, but I forget the exact name. Last edited by MarkJames; 05-18-2013 at 10:41 AM. |
Paul
Trade: Hard Surface Flooring
Rewards Points: 1,004
Screed sticks and Ardex feather finish mixed hot. I've done this many times, comes out baby's butt smooth and dries quick too. Regular mud would work but would take more work imo. Feather finish sticks to damn near anything and it's so easy to trowel smooth it's ridiculous.
Precision Floors (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
The Following 2 Users Say Thank You to PrecisionFloors For This Useful Post: |
BlueRidgeGreen (05-18-2013),
charimon (05-18-2013)
Rewards Points: 582
When I replace a backsplash I almost always cut the old one out, substrate and all. Takes no time at all i come up an inch from the countertops, and an inch down from the upper cabs, cut out with the Fein tool, replace with whatever backerboard you choose, and you have a new, flat surface for the new tile. This actually takes less time overall, as setting the new tile goes much much quicker.
In your case, if it's the studs that are giving you the unevenness, you can tune up the stud in question when it's exposed, using a belt sander. I never seem to have alot of luck adding material to try to correct an issue, I prefer to subtract, and rebuild correctly. |
The Following 2 Users Say Thank You to ArtisanRemod For This Useful Post: |
MIKE ANTONETTI (05-19-2013)
![]() Trade: Craftsman
Rewards Points: 246
Older Manhattan condo means it's probably plaster over gyp-block. That's why your screws aren't "holding".
Simple scratch coat, or the Ardex feather will be perfect.
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson |
#14 | |
Rewards Points: 246
Takes special Jedi techniques to fasten things to them......
The Following 2 Users Say Thank You to BlueRidgeGreen For This Useful Post: |
ArtisanRemod (05-18-2013)
Rewards Points: 246
One way to get the screed strips to hold is to butter them with construction adhesive, apply to wall, remove, let skin for a minute, reapply, then screw them in with Rock-to-Rock screws (laminating screws....very thick coarse thread) pre-drill a countersink for the heads so they don't spin out when you try to send them home.
Or....just use a long screed board over the scratch coat.....how long could the run be?
Rewards Points: 582
Somehow i didn't see Manhattan condo, but wouldn't have mattered as Im not familiar with NYC condos. Thanks, love this site for the diverse info.
#17 | |
Rewards Points: 250
So ardex feather would be good to what thickness? Would half inch work. I will see if I can find some. area is 12' long by 20 inches.
#18 |
Rewards Points: 246
From true feather edge to 1/2".....it's great stuff. Will stick to almost anything and sets up quick.
#19 |
Rewards Points: 246
I'm sure Precision has used it a lot more than I have.
He would be the guy for Ardex Feather advice. I frankly would have just straightened (screed) the brown/finish coat and went from there. As far as bond, those walls are generally done real well, so you are just adding to a sound existing masonry/plaster base to get straight. NYC has a long tradition of solid plaster work. But you can tell by looking at it. Disclaimer: I'm not a "real" tilesetter, I just play one on CT. ![]()
The Following User Says Thank You to BlueRidgeGreen For This Useful Post: |
#20 |
Paul
Yep I concur lol.
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Latest Wall Unit | Roger Manning | Carpentry Picture Post | 13 | 05-18-2015 03:47 PM |
Bathroom Design Help - dark floor and wall tile the same? | sbcontracting | Architecture & Design | 23 | 10-02-2013 12:14 PM |
Exterior wall covering options? | bob_cntrctr | Construction | 8 | 02-25-2013 08:05 AM |
Marble Wall / Floor Grout Maintenance ? | We Fix Houses | Tiling | 4 | 08-14-2012 12:00 PM |
Masonry Wall Art Picbrick | junie | General Discussion | 4 | 07-26-2012 03:51 PM |
Go to Page... |
