Joist Crown - Page 2 - Tiling - Contractor Talk
Joist Crown
Old 10-31-2018, 06:02 PM   #21
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,150
Re: Joist Crown
Originally Posted by overanalyze View Post
Interesting that the 2 of them are different.
I didn't see the species question answered. And there are a lot of other variables depending how advanced the calculator is.
Golden view is online now
Old 10-31-2018, 08:41 PM   #22
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 630
Re: Joist Crown
So how do you really get a valid answer? Is a tile websites calc better than the AWC's?
Anything can fail. I would like to know why the tile failed with L/600 before saying everything L/360 is garbage.
overanalyze is online now
Old 11-01-2018, 08:08 AM   #23
edward trowelhands
Trade: Diplomat
Re: Joist Crown
Every calculator and specification is conservative. I doubt the tile failed due to deflection, though low deflection would help against bad install practices.
overanalyze (11-01-2018)
Old 11-07-2018, 05:41 PM   #24
Always Learning
Rewards Points: 630
Re: Joist Crown
Damn...24x48 tiles are big! Takes approx 1 50lb bag of thinset for 4 tiles with 1/2x1/2 trowel and full back butter. Once we finally got going things set decent.
The Following 9 Users Say Thank You to overanalyze For This Useful Post:
asevereid (11-09-2018), BlueRidgeGreen (11-08-2018), Golden view (11-07-2018), greg24k (11-08-2018), rblakes1 (11-08-2018), Rio (11-08-2018), Tom M (11-08-2018), Wile E Coyote (11-09-2018), Xtrememtnbiker (11-07-2018)
Old 11-07-2018, 08:47 PM   #25
tjbnwi's Avatar
Rewards Points: 2,848
Re: Joist Crown
Looking good Andrew.
tjbnwi is online now
overanalyze (11-07-2018)
Old 11-07-2018, 09:54 PM   #26
Always Learning
Rewards Points: 630
Re: Joist Crown
One thing I need to solve is cutting this size and up moving forward.
These are 7/16" thick so the thin porcelain scoring and snapping systems won't work.
I tried the TS55 with a diamond blade but there was too much chipping even with multiple passes. I think that size blade running dry heats up to much and then distorts.
I was able to do a full length rip on our 7" Rigid wet table top tile saw with good results but damn that is an awkward cut.
Thinking of getting a small 5" wet/dry handheld saw and adapting it to run on my Festool tracks. I have some 32x60's and more 24x48's to install early next year and the cuts need to be money. Thoughts?
Old 11-07-2018, 11:27 PM   #27
tjbnwi's Avatar
Re: Joist Crown
My Monolit Masterpiuma and Rubi TS will snap up to 3/4" thick. They come up to 61" length.
Of the two, the Masterpumiuma is far superior.
Good thing they both come with wheels.
I believe you have the same ATS blade I have---put it in the saw backwards and pull the saw backwards along the track.
Old 11-07-2018, 11:39 PM   #28
Always Learning
Rewards Points: 630
Re: Joist Crown
That is the blade. Hmmm...will give it a try tomorrow. Thanks Tom!!
Old 11-08-2018, 09:04 AM   #29
General Contractor
greg24k's Avatar
Rewards Points: 7,996
Re: Joist Crown
Nice clean job!
greg24k is offline
overanalyze (11-08-2018)
Old 11-08-2018, 06:14 PM   #30
Always Learning
Rewards Points: 630
Re: Joist Crown
So I tried running the ATS blade and saw backwards...that worked ok but it was awkward and still not fast.
I have this cheap mesh blade from Amazon I tried in the grinder and it worked really good on the hard porcelain.
The guy working with me said we should try it in the Tracksaw...so we did. It works great! It took 3 arbor adapters to fill the space because of the thickened plate around the arbor hole. Also had to remove the riving knife because the tile blade is thinner.
It leaves a nicer edge than cutting wet on the Rigid table wet saw does. A light dressing with a 200 grit diamond pad cleans it right up. Very low dust was created. I think I will buy the new 5" dry cutting Makita with the rail adapter. This was really a good test of the dry blade and using a track to cut them.
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Rio (11-08-2018), Xtrememtnbiker (11-08-2018)
Old 11-08-2018, 06:28 PM   #31
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,718
Re: Joist Crown
I love that blade.
I was on a job recently where the guys were setting 48x48" tiles. They snapped them with the biggest Sigma snapper I've ever seen.
Inner10 is online now
Old 11-08-2018, 06:32 PM   #32
Always Learning
Rewards Points: 630
Re: Joist Crown
Originally Posted by Inner10 View Post
I love that blade.
Yeah I know they are available but it doesn't make sense for me as a infrequent tile setter.
Old 11-08-2018, 06:37 PM   #33
Inner10's Avatar
Re: Joist Crown
You nailed the coverage, the guys doing it told me half bag per tile. Didn't look fun...
Old 11-08-2018, 08:06 PM   #34
Always Learning
Rewards Points: 630
Re: Joist Crown
Definitely 2 man and suction cups required!
Old 11-08-2018, 08:45 PM   #35
Tom M's Avatar
Rewards Points: 12,774
Re: Joist Crown
Andrew have you ever done your own mud job? I always do mud floors but I bring in someone for it.
Wondering if the clip and wedges were more if a bitch trying to pull a monster tile like that.
Tom M is online now
Old 11-08-2018, 09:34 PM   #36
Always Learning
Rewards Points: 630
Re: Joist Crown
No mud dawgs in my area but I would like to try it one day just to see what it's like to lay off of.
Wedges worked fantastic. I can't imagine setting this size tile without them. This is a Build Direct tile (made in China). It is pretty flat but they aren't perfect. Not sure if any tile this size would be. I have some high dollar Made in Italy ones to install early next year. Be curious to see if there is a difference.
Tom M (11-08-2018)
Deck Screws vs Joist Nails subybohn Decks & Fencing 105 06-25-2018 06:54 AM
Inside corners on baseboard and crown otislilly Finish Carpentry 147 05-19-2014 07:07 AM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
Sistering A Truss Joist sparkyjw Construction 27 10-12-2011 06:31 PM
