Installing Tile Over Tile - Tiling - Contractor Talk
Old 06-14-2015, 11:35 AM   #1
JoeMac's Avatar
Trade: Ceramic tilr
I have thick paver style tile over concriet, started to bust up tile to get to slab and lay new tile. When busting up old tile it is severely damaging slab with deep pits. The old tile is stuck very well, I want to lay new tile over the old pavers. I have sanded the glaze off and am happy with that, the problem I have is that the existing pavers have some pretty severe cupping at corners. Question is do I do a scratch coat the spead the floor with a notched and then butter the back of the tile to get me over the cupping. Any help, suggestions, or advice would be appreciated. I have lots of experience laying tile floors, showers and counters I just have never layed tile over tile and the cupping issue is concerning
JoeMac is offline
Old 06-14-2015, 12:00 PM   #2
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Re: Installing Tile Over Tile
Unless the cupping is extremely bad, you should not need to skim coat the old tile--you are there and a pro(right?) so you make that call---use a two part modified thin set like Kerabond and Keralastic---if the concrete base is getting torn up by the demo--you might have discovered an old mud set floor--and it is the soft deck mud pulling apart.
Please go to the introduction section here and introduce yourself and your business--
mikeswoods is offline
Old 06-14-2015, 12:04 PM   #3
JoeMac's Avatar
Trade: Ceramic tilr
The cupping is pretty severe.
JoeMac is offline
Old 06-14-2015, 01:03 PM   #4
KAP's Avatar
Trade: Custom
Rewards Points: 92
Your finished tile longevity is only as good as its substrate...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
CompleteW&D (06-14-2015)
Old 06-14-2015, 02:27 PM   #5
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
How bout a picture? Your descriptions are vague(thick pavers, pulling up slab, severe cupping) for evaluation, and "your" perception.
MIKE ANTONETTI is offline
Old 06-14-2015, 02:51 PM   #6
ccoffer's Avatar
Rewards Points: 1,140
It's pretty standard for properly installed tile to take the finish coat off when removed. I'd roll with it and then use a crap ton of thinset going back.
ccoffer is offline
Old 10-29-2015, 10:15 AM   #7
woodfloor's Avatar
Trade: flooring
Rewards Points: 86
Remove any moldy or loose grout with a rotary tool or carbide scraper. Vacuum the tiles and clean with detergent and water to remove dirt, sealers and wax. Rinse the surface with clear water and let it dry. Buy a latex-modified thin-set and mix it in small batches to keep it from skinning over.
Wood Flooring New Jersey Phone: 201-330-0909
Wood Flooring New York Phone: 212-252-3838
woodfloor is offline
Old 10-29-2015, 10:50 PM   #8
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Grind it flat and go.
charimon is offline
Old 10-29-2015, 10:55 PM   #9
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Little EcoPrime Grip
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Nick1001 (10-30-2015)
Old 10-31-2015, 06:28 AM   #10
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Just a bit skeptical on that one.
Forget for a second you are going over tile. What if the concrete floor was cupped or uneven as the tile is? What would you do?
Answer is level or flatten the floor first. How do you do that? A experienced tile setter would know how.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Order of installing tile? daxsmith Tiling 57 05-31-2015 09:35 AM
Installing ceramic tile Rickk13 Flooring 2 04-07-2015 12:36 PM
Ceramic tile ZackyBundles Flooring 26 03-05-2013 10:09 AM
Know Your Tile Type tilecleaningTX General Discussion 0 11-21-2012 04:15 PM
