Hole In Porcelain Bowl? - Tiling - Contractor Talk
Old 05-01-2015, 09:20 AM   #1
music9704's Avatar
Trade: class b contractor
Rewards Points: 591
Any ideas on drilling a hole in a old porcelain bowl. Making a vanity top. HO said it didn't matter if I broke the bowl trying, but.......
music9704 is offline
Old 05-01-2015, 09:33 AM   #2
madmax718's Avatar
Trade: General
Rewards Points: 3,272
Re: Hole In Porcelain Bowl?
slow.. and dont push. You are using a diamond abrasive hole bit right? Oh ya, and tape up everything around it, and use lots of water.
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
music9704 (05-04-2015)
Old 05-01-2015, 09:35 AM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 110
Firm no slip surface like a rubber mat, diamond hole bit & water to help keep it cool
Light pressure & let the bit do the work
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Old 05-01-2015, 11:55 AM   #4
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Is this the same bathroom you're stuck in, figuring out how to tile on hot mud?
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
The Following User Says Thank You to CO762 For This Useful Post:
Old 05-01-2015, 12:25 PM   #5
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Will it be used as a vessel?
MIKE ANTONETTI is offline
Old 05-01-2015, 09:11 PM   #6
GO Remodeling's Avatar
Rewards Points: 96
Set bowl into a Rubbermade box filled with sand and water. It will provide full support while keeping the bowl cool from the diamond drill bit. Don't forget to drill with some water in the bowl, too.
GO Remodeling is offline
The Following 2 Users Say Thank You to GO Remodeling For This Useful Post:
music9704 (05-04-2015), SLSTech (05-02-2015)
Old 05-04-2015, 05:38 AM   #7
music9704's Avatar
Rewards Points: 591
Yes Mike, It is supposed to. HO keeps changing their mind. Well, auguring more like it. I usually listen to the lady of the house. Most of the time she wins. I should know something today.
Old 05-04-2015, 09:27 AM   #8
CO762's Avatar
To avoid that, disconnect all toilets in their house. It helps streamline their thought process to get a final resolution in a timely manner.
CO762 is offline
concrete into a hole, no access to pump bruno12345 Concrete & Paving 3 08-18-2013 03:28 PM
Haying foundation hole Upchuck Excavation & Site Work 18 03-30-2013 09:23 PM
Let me explain this and tell me if I'm wrong Dustincoc Electrical 9 03-18-2013 10:48 PM
Post hole nightmare Jer Decks & Fencing 11 10-19-2011 10:02 AM
1" to 2" countersink hole in precast concrete see spot run Tools & Equipment 4 10-11-2011 04:15 AM
