Glass Mosaic Accent Tile Over Kerdi - Tiling - Contractor Talk
Old 05-06-2015, 11:19 PM   #1
mike gunderson's Avatar
Trade: general, remodeling specialty
Rewards Points: 183
I've seen this talked about before, but I have another question on this topic. If i just have say a 4" accent strip of mosaics in my shower I have always used ditraset to adhere them just like the rest of my tile. I have never had a problem. They seem to stick as well as the field tile. Am i looking at problems in the future years with this method?
Thanks, Mike
mike gunderson is offline
Old 05-07-2015, 12:23 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Glass Mosaic Accent Tile Over Kerdi
I feel like a broken record. I know there are the fancy Schluter workshops and they put the fear of the devil in you about using modified thinsets over their membranes.
HydroBan
AquaDefense
RedGard
NobleSeal
WediPanels
Green Skin
are all popular membranes and all of them don't restrict you to using unmodified thinset to install tile. So please tell me, what magic does Schluter use that these other membranes don't have?
It's common the refer to the manufacturers of products for specialized installation instructions when veering off the path of TCNA recommendations. So, I recommend if the glass manufacturer suggests a modified thinset to install their glass, that's what you should consider...even though that goes against Schluter. You're not gonna melt the Kerdi with a modified thinset.
Angus
angus242 is offline
The Following 3 Users Say Thank You to angus242 For This Useful Post:
avenge (05-07-2015), TNTRenovate (05-07-2015)
Old 05-07-2015, 12:34 AM   #3
diplomat
Golden view's Avatar
Rewards Points: 1,550
Their reasoning being that modified thinsets need to dry and their impermeable membrane might prevent that.
I've often wondered about the technical side of that though. Modified thinset is still Portland cement. Doesn't the cement portion set the same as unmodified, and then as the polymers dry they do their thing?
I can say from my limited experience that modified will give a much better bond to kerdi with glass tiles.
Golden view is offline
Old 05-07-2015, 12:38 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Modified needs air to cure. Unmodified is self-curing.
Angus
angus242 is offline
Old 05-07-2015, 06:25 AM   #5
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
There's set and cure, two different things. I say put some modified under water a few days see what happens.
MIKE ANTONETTI is offline
Old 05-07-2015, 06:38 AM   #6
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
What real world condition does that simulate?
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 05-07-2015, 07:53 AM   #7
GO Remodeling's Avatar
Rewards Points: 96
Depending on the glass tile size. The thinset dries from the outside edge to the center of the tile. A large glass tile could take a several days longer to dry thoroughly. I haven't had any problems with small mosaics and modified over membranes,
GO Remodeling is offline
The Following User Says Thank You to GO Remodeling For This Useful Post:
angus242 (05-07-2015)
Old 05-07-2015, 07:54 AM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Put a wad of it in a food saver vac sealer.
Inner10 is offline
Old 05-07-2015, 08:42 AM   #9
Ok, so put it in ziplock bag
Old 05-07-2015, 08:51 AM   #10
diplomat
Schluter has claimed reduced bond strength after even 60 days.
Old 05-07-2015, 08:52 AM   #11
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Originally Posted by angus242 View Post
I feel like a broken record. I know there are the fancy Schluter workshops and they put the fear of the devil in you about using modified thinsets over their products. You're not gonna melt the Kerdi with a modified thinset.
I'm at a Schulter workshop this very second, and I thought it would be that way. Our instructor is actually being very open minded about real world practices. He is saying that Schulter recommends non-modified for over top, BUT they won't run from the warranty if it made sense to use modified. They basically want you to use your brain and understand the properties of both types of thinsets, and use the appropriate one.
And again, Ardex will actually take over Schluter's warranty if you use their product.
TaylorMadeAB is offline
The Following User Says Thank You to TaylorMadeAB For This Useful Post:
HS345 (05-08-2015)
Old 05-07-2015, 09:02 AM   #12
Rewards Points: 183
No one has answered my question whether or not using ditraset on these small tiles will be a failure in the future. I definitely would not use this method for big glass tile that have a lot of weight.
Old 05-07-2015, 09:07 AM   #13
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
no It will not
they will be fine
charimon is offline
The Following 3 Users Say Thank You to charimon For This Useful Post:
angus242 (05-07-2015), HS345 (05-08-2015), Wile E Coyote (05-07-2015)
Old 05-07-2015, 09:52 AM   #14
There were situations where glass tile has cracked I believe from thinset shrinking. I would use setting material designed for glass.
Old 05-07-2015, 10:39 AM   #15
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
You don't like answering the same questions over and over and over and over again? I could see a site like bridges that was setup to make money off of the diy types, but for me, the last thing I want to do is go home at the end of the day and answer the same stupid questions over and over. Guess that's why I generally hang out in the general section or politics--more interesting for me.
Unfortunately, the tile and stone trade has become that and it makes sense when it's gadget driven by manufacturers. Their widgets are like an apple computer--dumbed down so anyone can use them....but if they try and use something else or run into something not totally contained within that 'system', they lean back and have a blank look on their face.
Don't know if it's intellectually lazy people or just lazy people or just normal people that jumped into a trade where the latest and greatest gadgets rule.
TEC is taking over the world. Normal big box stores I don't expect anything from their people other than stocking the shelves (except plumb/elect). They need to just shut up and help the person load their shopping cart. But what's funny is I went to a local tile shop and one big flooring center that also does installs/uses subs. Both use/sell TEC and both were wrong about their products on many points.
What's funny is it seems like they have no other idea of any other products other than what they sell/use. I ask them if they have something comparable to X. I get a blank look and they say they don't know anything about their products. So I buy a few of their brand to try out, get the data/sell sheets, talk to the tech dept, then realize what I thought didn't make sense....didn't. It was wrong.
There seems to be so much knowledge (and skill sets) being lost in this trade.
On a side note, I think the tech reps are happy to actually get asked questions that will make them think and test their knowledge, not only of their products, but the process of 'what, why, where and when' as it applies to their products. But even some of them need to be pulled out of canned 'product recommendations' cue cards/computer/scripts.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 05-07-2015, 11:45 AM   #16
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
The 2nd most thing brought up with Schluter is warranty. I defer to the question of how many Kerdi/Ditra failures have you heard of? Yes, there was the case of some fleece issue but your choice of thinset would not have fixed that problem. If your tile fails when installed over Kerdi/Ditra, let's face it. It's your fault, not theirs.
Be smarter than the tile. It's not hard but it does take some time to learn the products you are using. Thinset is probably the product most commonly abused. I've seen so many guys not mix it properly. It is by far, the most important product in a tile installation. Yet, you hardly see the amount of time wasted arguing about it like you do Schluter specs.
Educate yourself on what thinset is and what makes it do its thing. Learn a product line so you can be informed on what to use and when. That will make a great installation.
Oh and if you're worried about glass and Kerdi, just use a rapid set. It's modified and self-curing. Even the thinset nazis at Schluter won't argue with using rapid set.
Angus
angus242 is offline
The Following 4 Users Say Thank You to angus242 For This Useful Post:
CarpenterSFO (05-09-2015), TaylorMadeAB (05-07-2015), TNTRenovate (05-07-2015), Xtrememtnbiker (05-07-2015)
Old 05-08-2015, 09:52 PM   #17
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Oh yes you are. If you use modified thinset over Kerdi you run the risk of starting a chain reaction that could ultimately destroy the universe.
Which is why my go-to over Kerdi is Ardex X-5. Please.....put me out of my misery.
Greg
HS345 is offline
The Following User Says Thank You to HS345 For This Useful Post:
angus242 (05-08-2015)
Old 05-08-2015, 09:54 PM   #18
Inner10's Avatar
You risk causing a tear in the space time continuum.
Inner10 is offline
HS345 (05-08-2015)
Old 05-08-2015, 09:56 PM   #19
Tile Contractor
HS345's Avatar
Rewards Points: 886
Ardex makes some fine "self curing", or, "self hydrating" modified mortars.
Greg
HS345 is offline
Old 05-08-2015, 09:57 PM   #20
Tile Contractor
HS345's Avatar
Rewards Points: 886
I doubt it would cause a failure in the future. What type of glass tiles are they, exactly?
Greg
HS345 is offline
Glass mosaic tile cutter reccomendation Cmac9000 Tiling 2 03-26-2014 10:59 AM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Amazing glass and tile cutter Tweed11 Tiling 17 10-31-2012 10:23 PM
one step glass tile install GO Remodeling Tiling 7 06-10-2012 07:16 PM
tile tops, star glass... ideas?? Tech Dawg Tiling 6 07-11-2011 08:23 PM
