Floor Prep - Tiling - Contractor Talk
Floor Prep
Old 02-04-2019, 08:32 PM   #1
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 758
Floor Prep
I have a new one to me. Remodeling a bath. Existing floors are Saltillo Terra cotta type tiles over 1-1/2" thick gypcrete with pex radiant tubing. They installed them over some kind of "paper" that was glued to the gypcrete. Is this an older crack isolation product? Good news is that the tiles demo easily.
I need to bring the elevation of the gypcrete under the tiles up after demo because the new porcelain is 7/16" vs the almost 1" that the old tiles are. My plan before demo was SLC after demo and then tile. As we demoed I found that they ran wide bottom plates as a screed for the gypcrete. I am now concerned with movement between the gypcrete and the wide plates. Now I am thinking of Ditra XL to help make up the elevation and give me crack isolation. What say you...right direction? Should I lightly grind the gypcrete to get rid of any glue residue left on the gypcrete?
overanalyze is offline
Old 02-04-2019, 08:45 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,308
Re: Floor Prep
Sounds good to me. Last gypcrete I tiled over I primed with diluted redgard. Not sure what's considered best practice now. Grinding lightly with a cup wheel doesn't seem like a bad idea.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
overanalyze (02-04-2019), TheConstruct (02-08-2019)
Old 02-04-2019, 09:06 PM   #3
tjbnwi's Avatar
Rewards Points: 3,804
Re: Floor Prep
Check with Schluter, I believe you can now use Kerdi board on floors. 3/8 would work well in this case, save a lot of mortar.
tjbnwi is online now
Old 02-04-2019, 09:14 PM   #4
Always Learning
Rewards Points: 758
Re: Floor Prep
Wouldn't the foam act as a thermal break and not let the floor feel as warm?
Old 02-04-2019, 09:17 PM   #5
tjbnwi's Avatar
Re: Floor Prep
Dumb ass me---I missed that part---sorry.
Old 02-04-2019, 09:20 PM   #6
Always Learning
Rewards Points: 758
Re: Floor Prep
So maybe a bit of slc and then the XL would do the trick...
Old 02-04-2019, 09:26 PM   #7
tjbnwi's Avatar
Re: Floor Prep
Yes, that would be the best approach.
Old 02-04-2019, 11:04 PM   #8
edward trowelhands
Trade: Diplomat
Re: Floor Prep
XL will also act as somewhat of a thermal break. Worth asking the client if they ever had a need for more heat.
overanalyze (02-05-2019)
Old 02-05-2019, 02:07 AM   #9
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 320
Re: Floor Prep
You will have to seal the gypcrete first it won’t play nice with Portland based products.
I can't compete with hacks.
donerightwyo is offline
The Following User Says Thank You to donerightwyo For This Useful Post:
Old 02-08-2019, 05:37 PM   #10
Always Learning
Rewards Points: 758
Re: Floor Prep
We primed the subfloor according to manufacturer's requirements and poured the SLC in the areas needing brought up today. It went well. 14 50lb. bags for this lift. We will put another 1/4" over everything next week.
Also have all the GoBoard done in the shower and that gypcrete primed for starting the floor Monday.
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
TheConstruct (02-08-2019), Xtrememtnbiker (02-09-2019)
