Fill This Hole. Lol. - Page 2 - Tiling - Contractor Talk
Old 11-09-2018, 08:31 PM   #21
avenge's Avatar
Rewards Points: 540
Re: Fill This Hole. Lol.
Originally Posted by Frank Castle View Post
Ouch!
That last part was uncalled for.
Alex did what he thought he should do. Now he wants help. Hopefully lesson learned.
avenge, you are correct the first shot was a waste of $$. What's your fix?
Alex, how deep is that hole? How many bags of SLC will it take?
No it wasn't he attempted to shortcut it by saving on material didn't want to "waste" $$. He does flooring he should know anything you use that primer is a given. And about the only thing you'll find at HD that will work is SLC.
If it didn't crack he would have found out later after he poured over it with SLC that it had no adhesion. Does it ever pay to try and save $$ especially on prep?
avenge is online now
Old 11-09-2018, 08:36 PM   #22
rblakes1's Avatar
Rewards Points: 2,928
Originally Posted by tang View Post
Ardex is good stuff, but at $50+ bucks a bag. Id say SLC over primer, and stick with one product. The cheep becomes expensive....
I think I get the tl1000 at about 30/ bag from my supplier
rblakes1 is offline
Old 11-09-2018, 10:59 PM   #23
Hack
asevereid's Avatar
Rewards Points: 296
I was asking a flooring rep about a similar situation the other day... About cost effective (read :cheap) alternatives for filing larger divots in the floor.
A straight Portland mix, heavy on the acrylic primer topped the list, followed by a cheap mortar bed, mixed heavily with the acrylic additive /primer.
Mortar is cheaper than Portland, and substantially cheaper than feather finish... But doesn't feather out at the edges.
I like using it to fill the majority of the void, and then topping with primer and slc.
Do any of you flooring pros see any issue with this? I'm not a pro installer... Not by far. But the rep stated that it was acceptable.
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following 2 Users Say Thank You to asevereid For This Useful Post:
BlueRidgeGreen (11-12-2018), TheConstruct (11-17-2018)
Old 11-10-2018, 09:45 AM   #24
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 112
I did skip the water curing step which was the demise of the plan. I did end up priming, and filling with SLC prior to self leveling the whole floor. Thank you to those who provided valuable criticism. And those that said I was trying to cheap out can ***** off.
Sent from my LG-LS993 using Tapatalk
FloorsByAlex is offline
The Following 2 Users Say Thank You to FloorsByAlex For This Useful Post:
Old 11-10-2018, 09:53 AM   #25
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,274
What’s the final finish? Epoxy paint? Was the moisture level low enough that quickly?
Big Johnson is online now
Old 11-10-2018, 10:00 AM   #26
tjbnwi's Avatar
Rewards Points: 2,686
My guess is you're looking at the wet SLC.
tjbnwi is online now
TNTRenovate (11-12-2018)
Old 11-10-2018, 10:16 AM   #27
Trade: Flooring
Rewards Points: 112
Yes it is wet SLC.
Finish will be 24x24 tile starting Monday, as long as there's no more waves.
The Following User Says Thank You to FloorsByAlex For This Useful Post:
Big Johnson (11-10-2018)
Old 11-12-2018, 09:09 AM   #28
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 824
Hard to tell everyone you bought the cheapest solution and when it failed you were called out for buying the cheapest solution.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
avenge (11-12-2018)
Old 11-12-2018, 01:14 PM   #29
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 3,216
Lesson learned.
Happens to all of us.
As long as you keep aiming for the bullseye....always learning, looking to get it perfect.
Looks like you are ready to roll.
Post the finished tile pics in the Tile thread
(So more people can “help” you.)
BlueRidgeGreen is offline
The Following 2 Users Say Thank You to BlueRidgeGreen For This Useful Post:
FloorsByAlex (11-12-2018), Xtrememtnbiker (11-13-2018)
Old 11-12-2018, 08:19 PM   #30
Hair Splitter
Trade: General
Rewards Points: 824
Originally Posted by BlueRidgeGreen View Post
Lesson learned.
Yeah, but telling someone that called him out on something he admitted to doing isn't a total lesson learned, IMHO.
Old 11-13-2018, 04:38 PM   #31
Renaissance Man
superseal's Avatar
Rewards Points: 5,790
I use rapid set materials all the time including the cement all...it's a great product that happened to be used wrong. Probably too wet placed over a dry dusty surface.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
BlueRidgeGreen (11-14-2018)
Old 11-16-2018, 09:33 PM   #32
Trade: Flooring
Rewards Points: 112
So I leveled it all out with maple syrup, and stuck the tile down with melted marshmallows. Hope it holds up....
The Following 3 Users Say Thank You to FloorsByAlex For This Useful Post:
Frank Castle (11-17-2018), overanalyze (11-17-2018), TheConstruct (11-17-2018)
Old 11-17-2018, 01:26 AM   #33
Hack
asevereid's Avatar
Rewards Points: 296
http://goo.gl/Il8c2
Post Hole Auger Help openhearth Tools & Equipment 9 07-18-2012 12:46 PM
Cabinet fill ? Dirtywhiteboy Finish Carpentry 15 01-15-2012 02:42 PM
Topsoil fill for Oneida NY jmacd General Discussion 5 01-07-2012 08:32 PM
hole saw and right angle drill issues PARENOS Plumbing 26 07-26-2011 05:28 PM
Need to fill HM Door - Grout/Mortar pump suggestions/alternative? lacknothing Masonry 8 05-06-2011 04:48 PM
