Fill This Hole. Lol. - Tiling - Contractor Talk
Old 11-06-2018, 07:56 PM   #1
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 86
Hey, so I had to chip up this speed bump in the floor. I should probably have grinded it but I had no help the moving the machine up and down stairs. Anyway. I chipped this up, and now I need to fill it flat. I went and used 3 bags of home Depot CementAll at $20 per bag. I followed instructions 100% with water ratio, mixing time, dampened the floor, etc. The stuff is fast setting, so I went out for a couple hours and came back to see it had cracks everywhere, and bonded 0% to the course aggregate below. So I'm like... WTF! LOL. anyway point is, what is the right product to fill this up. I just need it flush with the "rim" or slightly lower. I am going to pour SLC over this whole floor anyway in prep for 24x24 tile. It is 1/2" -3/4" deep.
Sent from my LG-LS993 using Tapatalk
FloorsByAlex is offline
Old 11-06-2018, 08:13 PM   #2
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 950
Re: Fill This Hole. Lol.
Portland cement and sand
Idothat is online now
Old 11-06-2018, 08:36 PM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,680
Self leveling compound with primer. With primer.... PRIMER!
Half of all people are below average.
Golden view is online now
The Following 4 Users Say Thank You to Golden view For This Useful Post:
asevereid (11-06-2018), SmallTownGuy (11-17-2018), TheConstruct (11-06-2018), TNTSERVICES (11-12-2018)
Old 11-06-2018, 09:14 PM   #4
Trade: Flooring
Rewards Points: 86
Did you say primer? Lol.
Ya I was looking for a more economic product to fill the "hole". I'm doing SLC on the whole floor 650 ft anyway. Do f wanna waste 2-3 bags on just this.
Old 11-06-2018, 09:22 PM   #5
TheConstruct's Avatar
Rewards Points: 720
Not really a waste if it works is it? The last three bags you used were maybe a bit of a waste.
TheConstruct is online now
The Following 2 Users Say Thank You to TheConstruct For This Useful Post:
Justin Rhoades (11-23-2018), rrk (11-07-2018)
Old 11-06-2018, 10:06 PM   #6
avenge's Avatar
Rewards Points: 420
You just wasted $$ by trying to cheap out, I guess FloorsByAlex includes shortcuts on prep.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Old 11-06-2018, 10:37 PM   #7
Trade: Flooring
Rewards Points: 86
Not really. The scenario doesn't call for a leveling agent. I'm filling a pocket in the slab. I plan on spending 1200 on SLC after this is filled anyway. Makes no sense to dump $100 in the hole when $20 of portland/sand is more appropriate.
That's pretty ****ty of you to try and call me out like that. I do all I can and spend what I need to to make sure projects are done correctly.
Old 11-06-2018, 11:36 PM   #8
Rewards Points: 720
Look at weldbond to use as a primer if you go Portland/sand route.
BlueRidgeGreen (11-09-2018), FloorsByAlex (11-06-2018)
Old 11-06-2018, 11:58 PM   #9
Trade: Flooring
Rewards Points: 86
I just tried searching for it. Can't find anything online but weldbond glue is that what you mean?? The weldbond gallon universal adhesive??
Old 11-07-2018, 01:07 AM   #10
Frank Castle's Avatar
Rewards Points: 424
Ouch!
That last part was uncalled for.
Alex did what he thought he should do. Now he wants help. Hopefully lesson learned.
avenge, you are correct the first shot was a waste of $$. What's your fix?
Alex, how deep is that hole? How many bags of SLC will it take?
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following 3 Users Say Thank You to Frank Castle For This Useful Post:
BlueRidgeGreen (11-09-2018), DaVinciRemodel (11-10-2018), Rio (11-10-2018)
Old 11-07-2018, 01:37 AM   #11
Trade: Flooring
Rewards Points: 86
Originally Posted by Frank Castle View Post
Ouch!
It varies from 1/4" to 3/4" rough aggregate exposed. My first go at it took 2+ 50 bags of CementAll, which isn't cheap it's like $22 per bag so F that guy. Lol. I would assume it would call for the same quantity if I use 50 lb SLC.
Old 11-07-2018, 01:49 AM   #12
Rewards Points: 720
Yep, weldbond wood glue. You can probably use other brands of white glue, just read the directions and it should say something about bonding new concrete to bold. Usually dilute it quite a bit with water.
Old 11-07-2018, 02:03 AM   #13
Rewards Points: 424
I'm no concrete expert, but isn't that what SLC is for, up to about 2"?
Just use the SLC and be done with it.
Lesson learned.
At least it wasn't the Tree Fiddy school of hard punches. That's rough.
Old 11-07-2018, 06:10 AM   #14
Idothat's Avatar
Rewards Points: 950
Weld Crete by Larson, the blue stuff .
The Following User Says Thank You to Idothat For This Useful Post:
Old 11-07-2018, 07:13 AM   #15
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 2,006
https://www.menards.com/main/floorin...7256669&ipos=1
Slc is $30 a bag here, I would have used that.
Big Johnson is offline
Old 11-07-2018, 07:21 AM   #16
https://images.homedepot-static.com/...2b41e0b098.pdf
“After your mixture has been placed and begins to harden, water cure the area to ensure a strong, crack-free finish.”
Did you water cure it? I’m guessing no. The instructions clearly state to do so to prevent cracking.
Old 11-09-2018, 08:00 AM   #17
rblakes1's Avatar
Rewards Points: 2,496
All these replies and not one "that's what she said"
I would've gone with slc for that as well.
rblakes1 is offline
Old 11-09-2018, 09:07 AM   #19
Mike-B's Avatar
Rewards Points: 850
I'm not a tile guy. Used to do a lot of commercial carpet and VCT. We mainly used 2 products for floor repair. Ardex feather finish for smaller spots. If it was a larger area, we'd use Dependable self leveler.
Mike-B is offline
Old 11-09-2018, 02:21 PM   #20
tang's Avatar
Trade: Remodel contractor
Rewards Points: 379
Ardex is good stuff, but at $50+ bucks a bag. Id say SLC over primer, and stick with one product. The cheep becomes expensive....
tang is offline
Post Hole Auger Help openhearth Tools & Equipment 9 07-18-2012 12:46 PM
Cabinet fill ? Dirtywhiteboy Finish Carpentry 15 01-15-2012 02:42 PM
Topsoil fill for Oneida NY jmacd General Discussion 5 01-07-2012 08:32 PM
hole saw and right angle drill issues PARENOS Plumbing 26 07-26-2011 05:28 PM
Need to fill HM Door - Grout/Mortar pump suggestions/alternative? lacknothing Masonry 8 05-06-2011 04:48 PM
