Ditra SET ...no Slake Needed - Tiling - Contractor Talk
Old 08-20-2016, 08:07 AM   #1
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 809
I picked up a couple bags of ditra set from my supplier the other day and it was in new packaging. After i mixed a bucket i was letting it slake and as i was sitting there i started to read the back of the bag and under the mixing instructions it said " not necessary to slake". Just to be sure i called my supplier and she called there ditra rep who told her that they said that bostic was talking a bout doing the no slake but he did not know that they did it yet. any way that saves me ten or fifteen minutes of time each mix.
nicko
"Quality work for those who know the difference"
nickko is offline
Old 08-20-2016, 08:43 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Ditra SET ...no Slake Needed
nicko
The core concept of slaking if I understand correctly is it gives time to hydrate the polymers, then the re-mix helps them bond together. With unmodified it just the hydration of portland.
Inner10 is offline
Old 08-20-2016, 11:35 AM   #3
nickko's Avatar
Rewards Points: 809
yes but the all ditra set i have used in the past said to let it slake for fifteen minutes. now all of the sudden no slake. Just wondering why the change
nicko
nickko is offline
Old 08-20-2016, 11:37 AM   #4
Inner10's Avatar
nicko
No idea.
Inner10 is offline
Old 08-20-2016, 01:49 PM   #5
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 852
I was also taught that crystals form in the thinset (cement). And the slake time allows crystals to begin forming, then remixing breaks those up so there are more individual crystals and they mesh together stronger as they continue to form.
I used a Laticrete thinset on a job a few months ago that also did not call for slake time. Guessing they've reformulated the mix?
dsconstructs is offline
The Following User Says Thank You to dsconstructs For This Useful Post:
Golden view (08-20-2016)
Old 08-20-2016, 02:03 PM   #6
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Slake.....I am the only one around here I have ever seen let the mix slake. One guy even accused me of phucking the dog because I was letting it slake. Kudos to you guys.
CrpntrFrk is offline
Old 08-20-2016, 08:03 PM   #7
aptpupil's Avatar
Rewards Points: 1,894
Says it right there on the bag. Tell that guy to eff off.
aptpupil is offline
The Following User Says Thank You to aptpupil For This Useful Post:
CrpntrFrk (08-20-2016)
Old 08-23-2016, 12:10 AM   #8
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I slake when called for by the instructions.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 08-23-2016, 12:11 AM   #9
Hair Splitter
Trade: General
Hydration is the goal.
Old 08-23-2016, 12:12 AM   #10
Hair Splitter
Trade: General
Ardex does not need slaking. They can also be reconstituted. I am switching to Ardex. Rep is meeting me Wednesday on site to go over their products. They have some pretty bad arse products.
EDIT: I will also add that you need to follow all of the directions on the bag, that includes proper mix proportions.
Old 08-23-2016, 06:16 AM   #11
General Contractor
greg24k's Avatar
Rewards Points: 8,522
The reason they changed that is because with Ditra tile is not adhered to the substrate, instead its mortared to the DITRA underlayment, which in turn, is mortared to the subfloor. This is the most important factor in this system to prevent the transmission of movement which in turn the main cause for tiled floors to crack.
As some of us know, sand been used for 100 and more years as a non-rigid layer of material between the substrate and the tile to prevent cracking, so Ditra is pretty much does the same function but its a bit more advanced system than using a sand sand layer and provides waterproofing on top of that. Therefore they changing that slaking is not required with Ditra.
greg24k is offline
Old 08-23-2016, 10:04 AM   #12
Inner10's Avatar
Is this post suppose to make sense?
Inner10 is offline
TNTRenovate (08-23-2016)
Old 08-23-2016, 02:34 PM   #13
diplomat
Golden view's Avatar
Rewards Points: 1,056
I notice many thinsets firm up a lot when slaking, then you mix them smooth and they stay smooth much longer. I think some early quick hydration happens in that first 10 minutes, maybe from finer particles. If slaking wasn't a step, it might encourage mixing too loose to compensate.
Golden view is offline
Old 08-23-2016, 09:07 PM   #14
Hair Splitter
Trade: General
I would stick to the instructions on the bag. Much smarter people than us (chemists) spent a lot of time and money coming up with the correct formulas. Ardex stresses using their measuring cup and mixing to there spec. If you are too thick then you might not have the right thinset for the project. That's why I love my reps.
Old 08-24-2016, 05:33 PM   #15
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Leave him alone he went to Schluter 1 training. At least I think that was where I heard it.
charimon is offline
Old 08-24-2016, 06:44 PM   #16
diplomat
I was just commenting on what I think slaking is and is good for, when the instructions call for it. I've never really seen a technical explanation.
Old 08-24-2016, 06:51 PM   #17
Inner10's Avatar
Oh man he must be an expert if he's got his Schluter 1!
Inner10 is offline
Old 08-25-2016, 09:03 AM   #18
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
DITRA underlayment...this system to prevent the transmission of movement which in turn the main cause for tiled floors to crack.
When ditra first came out--OK and the next 8 years...and probably still to this day, it wasn't an "anti-fracture membrane", it was an "uncoupling membrane". Get your propaganda straight.
There were/are many anti-fracture membranes, but only one "uncoupling membrane". Truly majik....whatever that is....
Krok is offline
Old 08-25-2016, 10:48 AM   #19
General Contractor
greg24k's Avatar
I didn't come up with that, Ditra did, so you need to get your facts straight
With that said,there is no magic in it as you put it, simple concept when you understand how different forces work between tile movement and substrate movement bellow, maybe you get the basics, you will stop wondering what makes ditra perform as it does... Not to mention that before Ditra hit the market in USA, waterproof composite sheet membrane for stone or tile been used since the early 80's, at least when I started using that in every tile installation.
So uncoupling or not it makes no difference, and as long as you use isolation system or now days it's called "Crack Isolation system" which used in concrete, stucco, etc you will never have a single installation failure.
Happy learning my friend, it's always fun, always new and that's why we here one happy CT family
greg24k is offline
Old 08-25-2016, 10:50 AM   #20
General Contractor
greg24k's Avatar
It's Schluter 101, you try try it to understand better... I'm just saying
greg24k is offline
drywall subs needed ASAP estimating2013 Help Wanted or Looking For Work 4 04-27-2013 06:46 PM
Corrugated Nail Gun Advice Needed openhearth Tools & Equipment 8 04-17-2013 07:43 PM
Ditra & Schluter Metal Edge Beanfacekilla Tiling 38 04-10-2012 09:37 AM
Did Ditra hold moisture in thin set Big Dog Dan Tiling 52 03-09-2012 08:22 PM
Hey all....Ditra Question for a Hearth CMSStoneworks Tiling 8 12-14-2011 02:33 PM
