Diamond Blade For A Multi Tool ? - Tiling - Contractor Talk
Old 05-11-2015, 08:49 PM   #1
Home wood's Avatar
Trade: carpentry
Rewards Points: 386
Hey guys I have to make a plunge cut into a marble floor.
I would love to use my cordless makita multi tool just as I would in a wood floor. Does any one know of a diamond blade for multi tools?
Home wood is offline
Old 05-11-2015, 09:44 PM   #2
tjbnwi's Avatar
Rewards Points: 392
Re: Diamond Blade For A Multi Tool ?
What size cut? Ramondi has a very small diamond blade.
Marble is soft, maybe a grit edge blade??
tjbnwi is offline
Old 05-11-2015, 11:04 PM   #3
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,358
fin and dremel made a blade for it. fin looked a lot better quality .
cedarboarder is online now
Old 05-11-2015, 11:04 PM   #4
tjbnwi's Avatar
Rewards Points: 392
Found a diamond blade for the MM or Bosch.
http://www.ebay.com/itm/like/3504895...lpid=82&chn=ps
tjbnwi is offline
Old 05-12-2015, 07:06 AM   #5
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Even with a diamond blade, you will not be able to easily plunge cut into marble with an oscillating tool. Use an angle grinder with a diamond blade.
I get my multi-tool diamond blades at Harbor Freight. They aren't as nice as the Fein, but at 1/5 the price.....
http://www.harborfreight.com/2-12-in...nry-68957.html
http://www.amazon.com/Fein-635021050.../dp/B0000223OZ
Greg
HS345 is offline
Old 05-12-2015, 07:10 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,131
Marble is soft, so any number of ways. What shape cut? If there will be an escutcheon covering the edges, you could even use diamond burr bit in a dremel (kind of like a dentist).
MarkJames is offline
Old 05-12-2015, 07:12 AM   #7
MarkJames's Avatar
That's cheaper than I would have expected.
Old 05-12-2015, 07:25 AM   #8
Tile Contractor
HS345's Avatar
Rewards Points: 886
Honestly, marble is soft, but not that soft. It is very dense. One will not easily cut marble tile with anything other than a diamond blade in a wetsaw or grinder.
Greg
HS345 is offline
Old 05-12-2015, 07:55 AM   #9
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 838
Yea, I've tried that with a fein and diamond blade. Didn't take long to give up and get the grinder out.
dsconstructs is offline
The Following 2 Users Say Thank You to dsconstructs For This Useful Post:
cedarboarder (05-12-2015), HS345 (05-12-2015)
Old 05-12-2015, 08:10 AM   #10
RiverBG's Avatar
Trade: Home rehab specialist
Rewards Points: 764
I would use an angle grinder and have a wet sponge to hold against the blade to keep the dust down. Just make sure you have some plastic set up to keep the water spraying anything it shouldn't
RiverBG is offline
Old 05-12-2015, 09:33 AM   #11
test
Trade: General
Good to know. I bought the blade for grout removal but never got the job. So i returned it.
Old 05-12-2015, 06:29 PM   #12
Rewards Points: 838
They're not too bad for grout removal, for most grouts. Just no way they're any good for cutting the tile itself.
Old 05-12-2015, 06:40 PM   #13
Home wood's Avatar
Trade: carpentry
Rewards Points: 386
Thanks guys
I think I will use the angle grinder for the bulk of the cut and then pick up the fein blade to square up the cut.
Old 05-13-2015, 03:21 PM   #14
test
Trade: General
The home depot staff suggested using these.
HILTI has a diamond blade deal going on Designed2Fail Tools & Equipment 0 05-21-2014 01:20 PM
Help Antique Tool Identification alexie Tools & Equipment 24 12-09-2012 11:32 PM
Tool GPS HomeProConsult Technology 4 09-23-2012 08:54 AM
Tool Definitions mudpad Tools & Equipment 5 01-17-2010 12:02 AM
