Demo Recommendation - Tiling - Contractor Talk
Demo Recommendation
Old 03-08-2012, 09:45 AM   #1
dan_s's Avatar
Trade: Paint and Floors
Rewards Points: 54
Demo Recommendation
Putting a bid in for a GC for demo and removal of 4400 sq feet of tile. It is 18'' on concrete. Just saw the blueprints and haven't looked at it in person yet. Won't come up with the final bid until I actually see the place.
Most of my tile removals are small remodels, 300-400 sq ft at a time. I usually use hammer drill, prybar and hammer to start and prep the floor as appropriate.
I never have removed this much at one time before. What are some suggestions on tools to rent, techniques, things to consider. The floor has to be taken down to concrete and ready for tenant finish when leased. My plan was to have a 3 man crew chip of the tile and thinset then grind the floor smooth with a floor grinder.
Thanks
dan_s is offline
Old 03-08-2012, 11:06 AM   #2
Carly's Avatar
Trade: GC, remodeling
Re: Demo Recommendation
Hey, I am no expert at this, but I have done it the same way as you have just described. I have had great success with this in most cased, but once in a 10 x 10 bathroom it took me an entire day to get the tile off the floor and grind the entire floor as none of the mortor broke loose from the concrete slab. Will never underbid this type of work again.
Carly is offline
Old 03-08-2012, 12:18 PM   #3
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
There are companies that specialize in this for a reasonable price. I would find one and tack on a buck per foot for my troubles.
I know of one in Louisville, don't know if they travel to Indy. I'll see if I can get a number.
Greg
HS345 is offline
The Following 2 Users Say Thank You to HS345 For This Useful Post:
dan_s (03-08-2012), TNTRenovate (03-09-2012)
Old 03-08-2012, 04:16 PM   #4
dan_s's Avatar
Rewards Points: 54
Thanks Greg, ill give them a call, have to look at it before I decide to sub out or give it a try. I have used the walk behind models before, never this large. Figure I will take up some tiles at the door in the middle and at the far corner to see how it will be. And of course bid with some wiggle room for hours.
dan_s is offline
Old 03-09-2012, 10:23 PM   #5
adams,b's Avatar
Trade: hardwood floors
Rewards Points: 250
That hurts my back thinking about it. We always use the Hilti 908 hammer. Chisel but then the flex bit. Have someone spray it with water as your using it to keep the dust down and keep the bits cool. Pump up sprayer works really good! Then grind it clean with diamond cup wheel.
adams,b is offline
Old 03-09-2012, 11:01 PM   #6
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Attachment 67523
That's the way to do it...be ready for numb fingers, hands and fore arms...you will be shaking till the next day!
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 03-10-2012, 12:56 AM   #7
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
I would probably also just jack-hammer it...if you put some small holes in concrete,you can just pour self leveling over floo or patching compound over dents
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
Old 03-10-2012, 12:57 AM   #8
Mad Italian
He works out
www.gabesmasonry.ca
Old 03-10-2012, 09:57 AM   #9
heathwwilson's Avatar
Trade: tile installer
Rewards Points: 25
I do all my own tear outs two people if its under 1000 can usally get it done in a day I did a couple of 6000 feet tear outs with a crew of six in a day I just rent a couple of stand up hiltis with the 8 in flat blade they definately work the best on the thinset for popping the tile ip I just use a one inch bit to pop it up as long as the tile is 12x12 or bigger its always pretty simple also the long stand up 4inch.scrapers are awsome for thinset removal dont hire someone else and lose money you could be making just put some elbow grease and time into it a couple if 8$an hour helpers and youll be good to go besides every tilesetter needs big tear out experience itll help you learn for the future id charge at least 2.50 sq ft
heathwwilson is offline
The Following 2 Users Say Thank You to heathwwilson For This Useful Post:
Evan1968 (03-10-2012), TNTRenovate (03-10-2012)
Old 03-10-2012, 11:15 AM   #10
Mad Italian
pricing questions are sort of frowned upon here...information you provide is valuable but i would not say how much i would charge.
www.gabesmasonry.ca
Old 03-10-2012, 01:53 PM   #11
Tile Contractor
HS345's Avatar
Rewards Points: 886
Companies that do demo charge far less than that. You could hire it out, save your back, still make a buck, and let the illegal aliens go back to where they came from.
Eight bucks an hour? Really?
Greg
HS345 is offline
Old 03-11-2012, 08:29 PM   #12
ESSaustin's Avatar
Trade: Hauling/trucking
Rewards Points: 384
If you can get $2.5/sf, that's pretty good. Down here the going rate is a bit less.
ESSaustin is offline
Old 03-11-2012, 08:39 PM   #13
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
According to whom? Numbers are so arbitrary across the board, it doesn't really matter what your opinion is about another's situation. Some people need to make a certain dollar amount just to drive to a site and not lose their ass...even if you could make a buck with that price.
Angus
angus242 is offline
Old 03-11-2012, 08:42 PM   #14
Rewards Points: 25
I dont always get that asking that every time would be robbery especially on somthing over 1000 but if I can tell its going to be alot of trouble move furniture drop clothes dust barriers etc. that's a good number to try to be at or,around for tile tearout imo
demo question A-1 Interiors Construction 3 02-15-2012 09:17 AM
Demo Debris disposed into a pool CGallagher Excavation & Site Work 14 07-23-2011 05:49 PM
Sales Beaver software demo Mike's Plumbing Marketing & Sales 4 04-18-2011 09:44 PM
Building Demo Estimate LNG24 Excavation & Site Work 7 05-07-2009 05:21 PM
