Dealing With Inconsistent Tile Sizes? - Tiling - Contractor Talk
Old 05-27-2015, 09:00 PM   #1
daxsmith's Avatar
Rewards Points: 124
Hi All,
I'm installing 8 x 8 tumbled travertine tile in a shower.
I've been watching the vertical grout lines to keep them in-line and plumb but I'm having problems with some tiles being wider than others.
Since the travertine has both square and rounded corners I've found I can trim a little off the wide tile and it still looks good and isn't noticeable.
But I keep thinking if I trim some off a tile I may have to trim some off the tile that sits directly on top of that one, and so on....
I tried narrowing up some of the grout lines between tiles leading up to the wider tile but I couldn't get enough by doing that. Ended up having to trim the wide tiles.
What is the recommended way of dealing with tiles like that? Is it common to trim them to keep the grout lines running plumb?
daxsmith is offline
Old 05-27-2015, 09:44 PM   #2
Talking Head
EthanB's Avatar
Rewards Points: 358
Re: Dealing With Inconsistent Tile Sizes?
What's your joint size? What's the tile size and how much are they off?
Normally, I'd just use a wedge spacer to even things out. If they're way off then maybe you can sort through them and use the ones that are most off-size for cut tiles.
PS- are these from HD or Lowes?
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
CarpenterSFO (05-27-2015)
Old 05-27-2015, 10:17 PM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
Originally Posted by daxsmith View Post
What is the recommended way of dealing with tiles like that?...
Wide and/or non-uniform grout lines. If you want uniform tile size, and uniform narrow grout lines, pay for rectified tiles.
Alternatively, buy lots of extra tile, and use the ones that are too far out of standard size, for cuts, edges, etc.
A tumbled tile is usually part of a more rustic look, and wider grout lines should be OK. How wide are your joints?
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
overanalyze (05-27-2015)
Old 05-27-2015, 11:03 PM   #4
daxsmith's Avatar
Rewards Points: 124
I'm doing 1/8" grout lines. Had I known I'd run into some problems with the tile sizes I would have gone wider to give me some room for adjustment.
Tile sizes are 8 x 8. They are not box store tiles. I bought them from a local shop that only sells tiles.
I found one tile probably 3/16 to 1/4" wider than the others. I ended up trimming it to size and it actually looked fine. The travertine has tiles that have square corners and others that are rounded so a cut edge doesn't stand out as it looks like just another tile with a square corner.
daxsmith is offline
Old 05-27-2015, 11:24 PM   #5
- Bob
Old 05-28-2015, 12:01 AM   #6
Texas Wax's Avatar
Rewards Points: 1,902
A bit abstract .... and not production tile setting
Run an exacting grid that the average tile size fits in, with desired joint size.
Cull out or cut the oversize pcs.
When setting individual tiles they get centered in a grid square. Joints will vary but over a series of tiles they appear to straighten. The larger the jiont the less variation shows. 1/8" >average< jionts have a rustic look, yet will still have a uniform-geometric look.
It's an art setting natural stone/tiles.
Hell with a lot of tile's dimensional stability plus spacers ...
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
CarpenterSFO (05-28-2015)
Old 05-28-2015, 12:05 AM   #7
When setting individual tiles they get centered in a grid square....:
Good advice.
- Bob
Texas Wax (05-29-2015)
Old 05-28-2015, 11:03 PM   #8
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I've dealt with this by using a random pattern.
Let's say you are doing a 14' wide room or 8' long wall. You sort out the tile and use 14' or 8' of the same size for one row. This will solve your problem in both dimensions. You just have to make sure you have 14' or 8' of the same size.
cleveman is offline
Old 05-29-2015, 07:56 AM   #9
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Grid measurements all day. Three tile wide maybe, balance the three in between.
I wouldn't put travertine in a shower, I always recommend against it for maintenance reasons.
MIKE ANTONETTI is offline
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 01:03 PM
Tile over Tile fireguy Flooring 5 09-16-2012 05:25 AM
