Cutting Bullnose Pieces - Tiling - Contractor Talk
Old 05-09-2014, 10:42 PM   #1
CarpenterSFO's Avatar
Rewards Points: 2,044
I've been asked to create some 3" bullnose pieces from some 1' square travertine tiles. I guess I'll cut the pieces, get a diamond router bit for the bullnose, set up a jig and run the pieces through.
Any tips or better ideas?
- Bob
CarpenterSFO is offline
Old 05-09-2014, 10:47 PM   #2
avenge's Avatar
Rewards Points: 720
Re: Cutting Bullnose Pieces
They make bullnose blades for wet saws.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
CarpenterSFO (05-10-2014), CrpntrFrk (05-09-2014)
Old 05-09-2014, 10:59 PM   #3
kambrooks's Avatar
Rewards Points: 572
And grinders.
And you'll probably wanna polish them afterward too.
I don't do it enough to make a real recommendation but I like my alpha wheels.
http://www.alpha-tools.com/Product.aspx?PageCode=1080
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
The Following User Says Thank You to kambrooks For This Useful Post:
Old 05-09-2014, 11:10 PM   #4
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Three passes with the diamond wheel. One at 45, then 22.5, then 67.5. I like Gator dry pads. Start with 100 and work your way up. Usually stop at either 400 or 600 depending on how slick you want it. Obviously you can take it further if you want a higher sheen.
CrpntrFrk is offline
The Following 3 Users Say Thank You to CrpntrFrk For This Useful Post:
CarpenterSFO (05-10-2014), MIKE ANTONETTI (05-10-2014), Texas Wax (05-10-2014)
Old 05-10-2014, 12:16 AM   #5
Thanks everyone. Obviously I have not been paying attention.
- Bob
- Bob
Old 05-10-2014, 05:01 AM   #6
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
How many do you have to make? A granite shop would do them up for you.
The profile wheels tend to get expensive if you dont use them enough. Making the bullnose is easy, polishing it up to match is the time consuming part.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 05-10-2014, 10:03 AM   #7
GO Remodeling's Avatar
Rewards Points: 96
How many pieces do you have to make? Only a few ?
Smoothly drag the tile across the wet saw blade to round over a bit. Belt sand a little more material off then finish with pads. Saves on polishing pads.
GO Remodeling is offline
Old 05-10-2014, 10:26 AM   #8
About 75 pieces. I have an employee who would do a good job, but I'll also ask one of the local shops - you never know.
- Bob
Old 05-11-2014, 10:14 AM   #9
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
75 pcs pick up a wet /dry bit for your grinder. It is big enough job to be worth the $120 investment, If it is shiney use enrich n seal on the edges
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Old 05-11-2014, 01:14 PM   #10
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Craig what do you mean " bit"?
Also "cutting " you mean " shaping ", contour, profile.
I'd get the bullnose wheel for the wet saw, it's kinda hard to recommend without the full assortment of tools needed when shaping stone.
Wet polishers and pads, it's just what you have when you work on marble/granite.
MIKE ANTONETTI is offline
Old 05-11-2014, 06:41 PM   #11
charimon's Avatar
something like this.
this is from contractors direct
charimon is offline
Old 05-11-2014, 06:54 PM   #12
I didn't know that existed, that just makes me mad that the tile distributor locally doesn't have that, just the wet saw bullnose blade.
Doesn't look diamond'ish
Metal cutting oscillating tool blade that can handle roofing nails? DuMass Tools & Equipment 16 03-17-2013 01:47 PM
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 01:03 PM
Cutting rafters [email protected]#e Framing 79 12-13-2010 08:25 PM
Metal cutting circular saws??? nwksremodeler Tools & Equipment 17 05-04-2008 06:29 PM
Cutting line on bullnose brentsid Painting & Finish Work 7 05-10-2006 06:43 PM
