Best Method Of Filling Dip In Floor - Tiling - Contractor Talk
Old 05-13-2019, 11:16 AM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,576
I know this is kind of a rookie question, but what the heck...
I have a decent size floor to tile, about 300 sf or so, and there is a dip in one spot. About 5x5 or so. Over an inch deep in the deepest spot.
I don't want or need to use an SLC over the entire floor, because it isn't needed.
I've mixed up what someone called a "deck mud" before, and filled beneath the backed board. I've also troweled on a thicker layer of thinset over the backer board before. Both methods worked OK I guess. I haven't seen anything wrong with them. I've also put a thick layer of thinset under the Hardi-Backer before.
I thought about installing backerboard over the floor, except in the spot where I need to fill, and fill that with SLC.
Is there a best method for this situation?
Thanks, guys.
Old 05-13-2019, 12:34 PM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,060
Re: Best Method Of Filling Dip In Floor
Hire Tipi.
Big Johnson is online now
The Following 7 Users Say Thank You to Big Johnson For This Useful Post:
AustinDB (05-16-2019), Bull Trout (05-13-2019), mrcat (05-13-2019), NYgutterguy (05-13-2019), onmywayup (05-13-2019), Rio (05-13-2019), SmallTownGuy (05-13-2019)
Old 05-13-2019, 12:47 PM   #3
MarkJames's Avatar
Rewards Points: 18,889
I would prefill the low spot the day before, and screed it off. (if same day, maybe speedset early) Then no fiddling when you comb out thinset for backerboard.
MarkJames is online now
Old 05-13-2019, 01:01 PM   #4
Trade: Highwayman
That's what I was thinking of doing, filling it with thinset before, but I'm concerned about it fracturing when I nail down the backer board.
Hence I started thinking about going over the top of the board.
Old 05-13-2019, 01:12 PM   #5
MarkJames's Avatar
How about screwing that area with self-drillers, like GRK's?
But I'll bet no screws would be just fine there (as long as it's bedded in fresh thinset)
Old 05-13-2019, 01:24 PM   #6
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
SLC in that area. Two pours. Predrill holes for screws (2"). Thinset down and go. I would not skip the screws in that area. The thinset bond breaks after a fews years and really isn't designed as a bond, but a filler.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 3 Users Say Thank You to TNTRenovate For This Useful Post:
KAP (05-13-2019), Rio (05-13-2019), Seven-Delta-FortyOne (05-13-2019)
Old 05-13-2019, 01:29 PM   #7
Trade: Highwayman
I always nail backer board.
Probably no chance of doing that over an SLC?
Old 05-13-2019, 01:57 PM   #8
VinylHanger's Avatar
Rewards Points: 12,902
Where have you been. You obviously dont know how to level floor with strips.
Sheesh.
VinylHanger is offline
The Following 4 Users Say Thank You to VinylHanger For This Useful Post:
Bull Trout (05-13-2019), MarkJames (05-13-2019), mrcat (05-13-2019), Seven-Delta-FortyOne (05-13-2019)
Old 05-13-2019, 05:47 PM   #9
Hair Splitter
Trade: General
You can try. I just don't know how well it will nail through the SLC (your concern as well). You could predrill the nail holes.
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 05-13-2019, 05:53 PM   #10
avenge's Avatar
Rewards Points: 298
I've had no problem nailing through SLC but you need longer nails in that area.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
Seven-Delta-FortyOne (05-13-2019), TNTRenovate (05-13-2019)
Old 05-13-2019, 06:20 PM   #11
MarkJames's Avatar
But do you know if it cracked or not?
Old 05-13-2019, 06:22 PM   #12
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Planipatch from Mapei. You can screed it and it is workable un like thinset, We use it to fill in spots.
kevjob is offline
The Following 2 Users Say Thank You to kevjob For This Useful Post:
TNTRenovate (05-13-2019), Tom M (05-14-2019)
Old 05-13-2019, 06:23 PM   #13
MarkJames's Avatar
And it can be as thick as 1" in a single application.
Old 05-13-2019, 06:32 PM   #14
Trade: Highwayman
So what, if any, is the downside to floating thinset over the backer board, and letting it set up for a day?
Old 05-13-2019, 06:34 PM   #15
MarkJames's Avatar
As long as the board is bedded in thinset before you float over it, should be fine.
Old 05-13-2019, 06:34 PM   #16
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Nothing other than being a PITA to get flat and uniform. My tile guy does it all the time, pre fill day before with thinset and then tile next day. I like planipatch as it it tileable same day and very easy to work with.
kevjob is offline
The Following User Says Thank You to kevjob For This Useful Post:
Old 05-13-2019, 06:38 PM   #17
Hair Splitter
Trade: General
an inch?
Old 05-13-2019, 06:39 PM   #18
Hair Splitter
Trade: General
Why would it matter? The leveler is to fill the void. The crack shouldn't affect anything above it. Remember, the Romans laid tile on sand and it has lasted a very long time.
Old 05-13-2019, 06:40 PM   #19
Hair Splitter
Trade: General
Depending on how thick your float was you would need to use medium set, not thinset.
Old 05-13-2019, 07:54 PM   #20
Trade: Highwayman
This has been very helpful.
Thanks all for taking the time to give advice.
I'll checkout that planipatch product.
goneshootin88 (05-17-2019)
Floor framing. Why put a joist under a non-loadbearing wall? Willin Architecture & Design 54 10-28-2012 08:21 PM
Floor fill won't adhere to old concrete floor: help?? shaane Flooring 4 12-29-2008 11:21 PM
