Base And Mortar Bed For Stone Slate - Tiling - Contractor Talk
Old 10-05-2012, 03:34 PM   #1
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
I have some stone slate I got from a job along time ago.
It is roughly 1/2 to 3/4 thick
It is random pieces( nothing is cut)
I need to make my hearth area larger
I would like to use this stone
roughly 19" deep by 6' wide
My question is
After I get my floor and subfloor beefed up.
Is there a setting material
I can use that will allow me to adjust the
heights a little while setting?
Should I use some wire lath or something in my setting material?
I will also have 1/2 to 3/4 mortar or grout joints
nailkiller1 is offline
Old 10-05-2012, 03:38 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Base And Mortar Bed For Stone Slate
Medium bed thinset like Mapei LFT. No lath necessary.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
nailkiller1 (10-05-2012)
Old 10-05-2012, 03:47 PM   #3
hurtlocker
Great thanks
Do I need another product for the grout/mortar joints
Or am I just tooling this product
Old 10-05-2012, 03:55 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Thinset is not used as grout. Just get a bag of sanded grout.
Angus
angus242 is offline
Old 10-05-2012, 03:59 PM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
You can also use type S or N mortar. You can set and grout with that.
Angus
angus242 is offline
Old 10-05-2012, 04:10 PM   #6
hurtlocker
I think i will try that
I was reading a couple bags of grout in the garage
They said up to 1/2 inch
Old 10-05-2012, 08:18 PM   #7
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
you can always set it in mud. Alot more time consuming and will jack your heights up.
blackbear is offline
Quikcrete mortar mix for stucco base coat Poppy Masonry 15 11-26-2019 10:58 AM
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
Slate patio repair aptpupil Tiling 9 10-22-2010 03:10 PM
mesh mortar alternative? Home Work Pro Flooring 15 03-09-2009 09:52 PM
Shower receptors that don't need to be set in mortar? Mike Finley Remodeling 8 10-12-2006 05:11 PM
