What Makes A Good Weed Wacker? - Landscaping - Contractor Talk
Old 05-20-2012, 02:40 PM   #1
wopachop's Avatar
Trade: construction
Rewards Points: 75
Hoping to find a used one off craigslist. Dont want a cheezy plastic ryoibi but also dont need the newest model out. Gas power is fine.
Been searching around. I thought there would be more options besides the string. I saw the "weed beater" or whatever its called. Its got 3 metal blades. Those work well or gimmic?
This is on desert type of dirt. Lots of little rocks to fling around. The weeds grow fast and strong. There is a good amount of area to cover so the radius might matter...not sure. That metal 3 blade guy looks small and slow.
Can anyone recommend what would work best for us? Its for home use. Thank you.
wopachop is offline
Old 05-20-2012, 02:55 PM   #2
Still have all my fingers
Bergstrom's Avatar
Re: What Makes A Good Weed Wacker?
I have owned a Honda 4 stroke straight shaft trimmer for the last 5 years and it's been the best one I've ever owned. I live on a lake and the weeds grow like well.....weeds. The four stroke seems to have a lot more torque than a two stroke and doesn't bog down in the thick stuff
Killing the Earth, one raised panel at a time.......
http://bergstromcabinets.com
http://minneapoliscabinets.biz
http://maplegrovecabinets.com
Bergstrom is offline
Old 05-20-2012, 03:01 PM   #3
Dirtywhiteboy's Avatar
Rewards Points: 13,598
I agree with Bergstrom, Honda and you can't go wrong or any Japanese name. Shindiawa, Husqvarna,,,......
Dirtywhiteboy is online now
Old 05-20-2012, 03:03 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 10,350
I like Stihl. Straight shaft are way better then curved. Go with square string or plastic knives if you are doing heavy grass. Brush, go with circular saw style blade. The steel three blade is pretty useless
Morning Wood is offline
Old 05-20-2012, 03:10 PM   #5
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Be careful with the stihls as some are not made in the US and I browsed numerous forums a year back trying to figure out what models to get. I ended up with a straight shaft model and it's about middle of the road in their range and i took down a whole yard of milk weeds with it and it ate it up with just the thicker plastic string that comes with them. The milk weeds were over an inch thick at the bases and didn't think it would have the muscle to do it but if you kept the revs high it went through them like butter.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-20-2012, 03:17 PM   #6
operator
peteo's Avatar
Trade: excavating, concrete, landscaping
Rewards Points: 518
Husqvarna is made in Sweden.
peteo is offline
Old 05-20-2012, 03:41 PM   #7
Designer/Contractor
Rio's Avatar
Rewards Points: 790
I Had a four stroke Craftsman but after wearing it out got a two stroke Echo and was surprised at how much lighter it was than the 4 stroke and also how much longer it runs on a tank of gas.
Rio is online now
Old 05-20-2012, 04:01 PM   #8
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
echo straight shaft,you can't kill em
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
Jaws (05-20-2012), MAD Renovations (05-22-2012), Max10 (05-25-2012)
Old 05-20-2012, 04:31 PM   #9
Bill1500's Avatar
Trade: Landscaping/Maintenance
Rewards Points: 111
X2 on Echo. They're built like tanks.
Bill1500 is offline
Old 05-20-2012, 04:36 PM   #10
Thank You Very Much I knew that and knew somebody would call me on it Although not sure if they are still made in Sweden or elsewhere
Old 05-20-2012, 05:13 PM   #11
Licensed Gas contractor
gastek's Avatar
Trade: Pools
Rewards Points: 1,012
The key is the straight shaft. "He said shaft!"
gastek is offline
Old 05-20-2012, 05:45 PM   #12
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
This is the one I have had for about 6 years.
http://www.stihlusa.com/trimmers/FS130R.html
My yard is almost an acre, my parents use it as well on their yard across the street which is a little over an acre. Never had any trouble with it.
SuperiorHIP is offline
Old 05-20-2012, 05:47 PM   #13
The Sheriff
Jaws's Avatar
Rewards Points: 14,472
Echo. I weedeat 2 acres at the shop and 29 trees and a fence encompassing one acre at my house. Its 9 years old and never been worked on. My dads is older and the primer bubble is broken, have to spray WD 40 in it to start, but starts right up.
Jaws is online now
Old 05-20-2012, 06:21 PM   #14
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,794
I have a toro pro line. It has been a good wacker.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 05-20-2012, 06:23 PM   #15
txgencon's Avatar
Rewards Points: 452
I have an Echo string trimmer, blower and several chain saws. I have a Husqvarna stick edger. All are two cycle and have had them for several years. The only issues I've had are a result of the ethanol in the gas nowadays. The Husqvarna seems to require less warmup and seems to have slightly better quality than the Echo products, but not by much.
If you've got lots of curb to edge, it's hard to beat a stick edger.
txgencon is offline
Old 05-20-2012, 06:33 PM   #16
Trade: Construction
I run the stihl pre mixed fuel in my gear. It's def worth it. They all start first pull with this fuel even when left all winter.
Old 05-21-2012, 10:11 PM   #17
Acres's Avatar
Trade: lawn maintenance
Rewards Points: 250
Gotta agree with echo, picked up mine sometime last season after stihls bit it and wacked about 2,200 lawns.. started it up this season turned over first pull....stihls days are over (IMO there carbs suck a**).. Husqs are to heavy for my liking same with stihls (both regarding lower end ones).. 199 home depot echo, just be careful I do not recommend or like there new quick change string trimmer head (logistical nightmare)..
Acres is offline
Old 05-21-2012, 10:16 PM   #18
Acres's Avatar
Rewards Points: 250
Seems like it would be very time consuming. Ive never actually seen that used in the field of "mowing" except for completely overgrown edges (almost redos) or lawn edge installs "In both scenarios of course would be extra charges".. No Upside down weedwhacking?
Groundclear concentrate? If your dealing with large stolons where it kinda looks like grass is growing from a green baseball in all directions and not just vertical.. you may need to look into brush cutting/ers type stuff, blades etc..
Acres is offline
Old 05-21-2012, 11:43 PM   #19
Fire up the BBQ
griz's Avatar
Rewards Points: 1,032
Stihl or Echo both great....
or a 6' guy with a sharp Misery Whip....
griz is offline
Old 05-23-2012, 07:58 PM   #20
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Red Max/Shindaiwa...
Straight shaft has a gear-head assembly that is more prone to fail then a curved shaft.
Ultimate Wisdom---------
MALCO.New.York is offline
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 02:50 PM
Found good software for those of us with a variable income. englishdave Business 7 12-13-2010 01:33 PM
Creative Nonfiction Essay 1 Kowboy Off Topic (Non Trade) 35 10-23-2010 03:15 PM
Potential good news for everybody Mike's Plumbing General Discussion 20 09-08-2010 11:23 AM
