Stump Rot - Hole Drilling - Landscaping - Contractor Talk
Old 07-26-2018, 04:32 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 574
Bought 'Stump Out' which I'll be pouring in about a 15" stump base.
Have contacted the company (Boride Products) who hasn't gotten back, on if I can simply drill straight down instead of connecting each vertical hole bottom with an outer drilling (air circulation?).
Will not be burning the stump after chemical rotting. Relying on powder only.
artinall is online now
Old 08-13-2018, 07:02 PM   #2
artinall's Avatar
Rewards Points: 574
Re: Stump Rot - Hole Drilling
Finally was able to get a hold of the company today, and yes, they say the holes must be drilled in pairs for circulation, even when not burning out later.
Old 12-20-2018, 12:29 PM   #3
artinall's Avatar
Rewards Points: 574
As a follow up to this wildly active thread - similarly, the stump rot had virtually zero effect. One stump looked like ash and the other a harder species... (secretes orange) Had 6 to 8 weeks before onset of cold temps.
The Following 3 Users Say Thank You to artinall For This Useful Post:
hdavis (12-21-2018), Peter_C (12-20-2018), Rio (12-20-2018)
Old 12-20-2018, 01:50 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Originally Posted by artinall View Post
As a follow up to this wildly active thread - similarly, the stump rot had virtually zero effect. One stump looked like ash and the other a harder species... (secrets orange) Had 6 to 8 weeks before onset of cold temps.
I am guessing it is going to take years...ever see a forest with a downed tree that has been there for years rotting away?
Depending on depth and size of root ball, sometimes it isn't that hard to dig around the big roots to gain access, then cut them with a reciprocating saw, or a chainsaw with a trashed chain. Then chain it to something heavy with an engine and hit the throttle. Back up and do it again...and again. Or if using a stretchy tow strap until your back window has a hole in it and the stump is firmly lodged in the back seat.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
artinall (12-20-2018)
Old 12-20-2018, 03:18 PM   #5
artinall's Avatar
Rewards Points: 574
At which time it starts to decompose.
The Following 2 Users Say Thank You to artinall For This Useful Post:
Peter_C (12-20-2018), Sam @ PWE (03-16-2019)
Old 12-20-2018, 09:51 PM   #6
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,645
Like this? https://i.imgur.com/xJJonU5.mp4
rescraft is offline
Old 12-20-2018, 11:33 PM   #7
Peter_C's Avatar
Rewards Points: 412
Or this!
Peter_C is offline
Old 12-21-2018, 09:45 AM   #8
hdavis's Avatar
Rewards Points: 2,074
A 15" stump wouldn't take too long to get out with the right tools.
Dig around it (I use a cutting mattock for this), cut roots as you find them in the way. Get a hole dug under it side to side. Set your stump puller up over it, and run the chain under the stump. Keep pumping the handle until the stump pops up.
You do have a stump puller, don't you?
hdavis is online now
Old 12-21-2018, 09:55 AM   #9
artinall's Avatar
Rewards Points: 574
Those are funny.
I actually know of someone who was doing this with a tractor. Not realizing the amount of force, the stretching chain snapped back to his spine and paralyzed him.
For years I dug'em out and chain sawed under surface. Just more than I'm willing to do these days...
Ah, a stump puller? Uh-ah. Besides, this are downslope going into some honeysuckle.
Old 12-21-2018, 10:11 AM   #10
hdavis's Avatar
Then auger and 1/2 stick of dynamite and snake hole it. Much faster, less sweat.
artinall (12-21-2018)
Old 12-21-2018, 10:19 AM   #11
hdavis's Avatar
The old stump uller I used was a wooden tripod with iron at the top that a ratcheting chain mechanism was hooked to. Roughly a 6' handle. Each pump of the handle would move the chain about half an inch.
Old 01-14-2019, 03:14 PM   #12
artinall's Avatar
Rewards Points: 574
Maybe I'll pour some kerosene down all those swiss holes once the snow clears and char it out. If it doesn't want to cooperate -- kill it!
Just didn't want to risk the uncontrollable roaring and all...but this could be the time. Neighbors burning fireplaces and everything's ultra dry.
The Following User Says Thank You to artinall For This Useful Post:
hdavis (01-14-2019)
Old 01-14-2019, 03:54 PM   #13
Mike-B's Avatar
Rewards Points: 1,142
Dump a bag of cheap charcoal on it. Light it up.
Repeat till gone.
Mike-B is offline
Old 01-14-2019, 06:05 PM   #14
rblakes1's Avatar
Rewards Points: 3,594
I was expecting a lot more stupidity and destruction
rblakes1 is offline
Old 01-21-2019, 03:12 PM   #15
artinall's Avatar
Rewards Points: 574
Along the same vein, you may want to vid search "tree felling gone wrong"
Old 01-21-2019, 03:46 PM   #16
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 834
Trying to burn a stump is going to be a waste of time .
My FIL used to say it takes as much wood as was in the tree.
Digging a large stump out by hand is a young mans work
Rent or hire a stump grinder or excavator
Idothat is online now
Old 01-21-2019, 06:20 PM   #17
hdavis's Avatar
Burning them out isn't as tough as it seems. Building a fire on top of it doesn't do a lot of good.
Idothat (01-21-2019)
Old 01-21-2019, 08:38 PM   #18
Idothat's Avatar
Rewards Points: 834
To burn one will require some digging . Almost digging it up
A fire on top will only draw water up trough the roots
Old 01-21-2019, 09:15 PM   #19
hdavis's Avatar
Auger down from the top, auger down from low on the side. Make sure they connect. Dump in diesel and light.
Still takes a while.
tree stump pappagor Excavation & Site Work 11 05-13-2013 06:46 PM
Hammer Drilling Porcelin Inner10 Tiling 50 07-15-2012 01:30 PM
hole drilled through valve body Everend Plumbing 5 07-13-2012 05:23 AM
