String Trimmers Question - Landscaping - Contractor Talk
Old 05-18-2013, 03:12 PM   #1
dale rex's Avatar
Trade: painting and carpentry
Rewards Points: 187
I know this is probably more like a DIY question, but I have to replace my own personal gas powered string trimmer. Wondered if anyone has any experience good or bad with the 40v lithium battery powered trimmers out there? Im thinking that if they are any good for home use that they are lightweight and require no messing around with finicky gas engines.
dale rex is offline
Old 05-18-2013, 04:01 PM   #2
Texas Wax's Avatar
Rewards Points: 2,000
Re: String Trimmers Question
Just bought a ryobi 18v Lithium, not a 40v. ONLY Ryobi I have ever owned BTW Happy as all get out with it. Only have maybe 20 minutes of trimming to do, so it's perfect.
Will see how long it lasts
BATTERY POWER RULES
Texas Wax is offline
Old 05-18-2013, 04:05 PM   #3
dale rex's Avatar
Rewards Points: 187
thats my concern
how long will the batteries last before they need to be replaced at $100 each.
dale rex is offline
Old 05-19-2013, 12:12 AM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 506
I'd say you're definitely in DIY-land with this one. I can't imagine a pro landscaper using batteries. Heck, I can't imagine me using batteries--I typically need 1-3 hours run time.
Tinstaafl is offline
Old 02-28-2015, 05:27 PM   #5
gosmond's Avatar
Trade: Landscaping
Rewards Points: 12
I've had OK experience with "CORE Power"-brand battery-operated string trimmer.
Has a very innovative motor design: some kind of advanced pancake motor located down at the end of the shaft, direct drive for the string head, no gears. I get about 40 minutes of trimming, "normal" amounts of soft (green) grass weeds 4" to 10" tall. Takes 3 hours to recharge the battery.
The Ryobi cordless design puts the motor up in the handle, with noisy reduction gear shaft driving the head.
Generally speaking, Li-Ion batteries are good for 300 to 450 full charge / discharge cycles, after that they tend to conk suddenly and completely.
For pro landscaping work a battery-powered setup is going to be limiting unless you're doing LOTS of *light duty* trimming and edging. Let's say you need to edge 6 or 7 residential lawns a day (no heavy-duty clearing work,) in that case it might be economical to buy 3 or 4 batteries. Esp. if you / your customers value the quiet and emissions-free operation.
For medium-duty small lot clearing (again, mainly thin / wet weeds,) I've been having more success with the Stihl FSE60 cord-powered 6-amp string trimmer. Plenty of power, light weight. Not all that quiet but a lot quieter than any gas trimmer.
gosmond is offline
Old 02-28-2015, 06:10 PM   #6
GettingBy's Avatar
Rewards Points: 6,486
Originally Posted by dale rex View Post
thats my concern
http://www.google.com/search?client=...UTF-8&oe=UTF-8
GettingBy is offline
Old 02-28-2015, 08:43 PM   #7
Radical Basement Dweller
Robie's Avatar
Rewards Points: 8,430
This does not address your question at all, but I am the worst when it comes to gasoline powered lawn equipment...I hate it when it won't start.
With that said...I have the same Echo trimmer I have used for 20 years. It has been in the shop one time over that span. I don't drain it, clean it...don't do nothin' and it starts every spring on the 3rd pull.
I think I replaced the spark plug once and blow out the flimsy filter every couple of years.
Now since I said this...it will refuse to start in a few months.
"The trouble with Socialism is that eventually you run out of other people's money."
.....Margaret Thatcher
Robie is online now
Rio (04-06-2015)
Old 03-16-2015, 09:53 PM   #8
BugmanBCE's Avatar
Trade: Pest Control
Rewards Points: 537
I have an Echo weed eater I bought 2 years ago.... the darn thing gummed up after sitting for a few weeks and I tried endlessly over half a dozen occasions to get it started. It would run and sputter and then die. I let it sit a year and was going to sell it but asked a buddy and he said to put some Start Your Engines in there and let it sit for a while after priming it into the engine. It started a week later and runs again.
I use and recommend a corded electric trimmer. Way better. Works every time. Cords aren't a big deal.
Oh, and I didn't have old gas in it, I always have new gas mix.
Pest Control League City, TX
BugmanBCE is offline
Old 03-16-2015, 10:49 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 756
My wife bought me the Prius of weed eaters.....
Lithium Ion/Eon? 56 volt from HD....
Thing is kick azz....
after 45 minutes in tall grass it wore me out and was still going....
My Dad tells me that the landscapers in his condo complex are starting to use these due to noise issues....
griz is online now
Old 04-06-2015, 09:15 AM   #10
Grass Cutting Nut!
kawasaki guy's Avatar
Trade: Landscape Maintenance/Construction
Rewards Points: 180
Go gas. Only way. Invest the money in something nice like a SHindaiwa, Kawasaki, or Redmax. I run Shindaiwa, and have never had issues other than with the spark plug boots....
kawasaki guy
Owner of a fine full Service landscape maintenance and construction company in the South Jersey area.
kawasaki guy is offline
Old 04-06-2015, 01:01 PM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
that's a lot of wacking..
Tom Struble is offline
Old 04-06-2015, 01:04 PM   #12
Trade: siding
Rewards Points: 20
well there are Echo's and there are Echo's some are pro models and some not so much..
Old 04-06-2015, 01:46 PM   #13
Designer/Contractor
Rio's Avatar
Rewards Points: 526
Echo's are great, corded are okay but if you have a big lot that you need to work with a string trimmer totally impractical, never tried a battery operated one but we're weed whacking for hours at a stretch so it probably wouldn't be practical.
We always make sure to drain the fuel/oil mix every time out of the tank when we're done using it, seems to help it start the next time.
Rio is online now
Old 04-06-2015, 01:57 PM   #14
Grass Cutting Nut!
Rewards Points: 180
Echos are suppose to be OK. Any pro grade trimmer like a SHindaiwa, Echo, Kawasaki, Redmax, Stihl should serve you well. Good luck!
kawasaki guy
Old 04-06-2015, 02:01 PM   #15
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 850
I bought echo homeowner special 11 years ago. Love it. Original plug still
NYgutterguy is online now
Old 04-07-2015, 09:36 AM   #16
BugmanBCE's Avatar
Trade: Pest Control
Rewards Points: 537
Mine is the Echo GT225. Don't know if that is the pro model or not. I've never had good luck with gas engines for home tools that are infrequently used. That's just been my experience. Same thing with cordless tools. Batteries wear out and don't have enough juice. Corded is just cheaper and easier and always works. You can keep an electric tool for 10 years easy, cordless, not so much. Gonna have to get batteries again.
My GT225 is for sale if anyone wants it. $50. Come and get it.
Old 04-07-2015, 10:17 AM   #17
diplomat
Golden view's Avatar
Rewards Points: 738
Electric is certainly up and coming.
It's right for the right application. I now mow my tiny lawn on a tank of gas a year. Electric might be better.
Husqvarna now has a backback battery for a pruning chainsaw that runs an entire shift. Charge overnight and back to work.
Golden view is offline
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
