Rational Method And Nomograph - Landscaping - Contractor Talk
Old 08-19-2020, 04:27 PM   #1
jwatts's Avatar
Trade: c-27
Rewards Points: 78
Trying to understand the rational method for determining flow rate and applying it to nomograph to figure out the diameter of pipe Iíll need to drain the roof. All downspouts currently drain to a single point so I need to get it away from the house, but not sure how wide it needs to be for a big rain. The slope away from the house is pretty steep, probably 30 to 40%, which Iíll probably have to verify to nail this.
Rational method -> Q = CIA
Q = volume of runoff in cf/s
C = coefficient of surface roughness (roof = 1)
I = intensity of the storm (using 2Ē of rain/hr, the historic high)
A = area of watershed (0.032 acres, or 1408 square feet of roof div by 43,560)
so Q = .064 cf/s
Well the lowest value on the nomograph for cf/s is 0.1, so Iím lower than that which doesnít seem right at all. What am I missing here?
jwatts is offline
Old 08-23-2020, 05:46 PM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,917
Re: Rational Method And Nomograph
A little simple compared to real life, IMHO
the limiting factor is the moment the water flows over the opening(top of vertical drop/drain), the water has to accelerate (vertically) from Zero to sufficient to get out of its own way , thus you need a 'sump' around the drain entrance , or the water backs up some till there is enough head & time to At your 0.064/Cubic feet/second flow rate, = ~0.47 gallons/sec = ~28.72 gallons/minute, 1723.5 gal. /hr.
I'd use commercial roof drain/pan sets with the needed back up intake if your roof doesn't have a large enough scupper for when the main drain fails/is plug with foreign matter . Remember you must keep the water ponding to less then the live load capacity, 30 psf is less then 6 inches of water depth....
10 seconds on Google lead to a chart that says a 2inch per hour rain can be drained, up to 1440 sq.ft. with a 2" drain.....I go one inch big for freak weather.....
Fouthgeneration is offline
