Joint Between Brick Pavers And Slab - Landscaping - Contractor Talk
Old 04-01-2012, 07:46 PM   #1
phil
phnola's Avatar
Trade: general contractor
Rewards Points: 35
Hello all,
I am a GC down in New Orleans. Hopefully y'all can follow this one. I recently got a job to pour a 17'x17' colored slab patio in the backyard of a lady's house. The homeowner had installed a brick border (concrete laid) and wanted the slab poured inside this brick border so that the surface of the slab was flush with the top of the brick border. She was very adamant about keeping the border, as she had apparently put a lot of work in to it.
Now the brick border that she installed, while sloped in the correct direction, was not even or straight enough to use as a form for the concrete so what I did was build my own forms so that the slab would be set 5" in from the border.
My (perhaps misguided) plan is to install my own brick border in between her brick border and the slab (she has a ton of loose bricks left over) . The bricks would obviously run parallel to the edges of the slab, with a 1/2" mortar joint between my bricks and hers, and an expansion joint between my bricks and the slab. My bricks will most likely be laid on a compacted concrete sand bed
My question is: What type of joint would y'all recommend between my bricks and the slab? Do you think an expansion joint is necessary? Or maybe just fill the joint with stone dust?
Thanks for any and all advice
Phil
phnola is offline
Old 04-02-2012, 08:12 PM   #2
MDLandscape's Avatar
Trade: landscape design and build
Re: Joint Between Brick Pavers And Slab
This is based on how we do work, in our zone 4-5 climate, meaning we get some serious freeze thaws. Since freezing isn't an issue, butt everything tight--no joint. It's what we do and aesthetically it's so much better long term. Joints are a point of weakness, avoid them if possible especially since you don't have to worry about the -30f temps we get in winter.
Hope this helps.
www.morningdewlandscape.com
MDLandscape is offline
Old 04-17-2012, 03:27 PM   #3
Premier pave's Avatar
Trade: paving
Good work...
http://www.premierpave.co.uk
Premier pave is offline
Old 04-18-2012, 08:38 PM   #4
lasvegas's Avatar
Trade: lasvegaspavers19
Really appreciate this post. It’s hard to sort the good from the bad sometimes, but I think you’ve nailed it!
pavers las vegas
las vegas paving
lasvegas is offline
Wet laid clay pavers on concrete........... jomama Masonry 7 09-08-2011 09:29 PM
Pavers Over Concrete - My Cousin's Method Tommy C Masonry 67 10-29-2009 09:31 PM
Walkout basement: Pavers on a slab? bert0168 Masonry 12 08-12-2009 05:52 PM
Pavers around a new pool-slab or no slab? Richie-C Masonry 22 03-17-2009 07:53 AM
Fireplace Insert Raised off the Slab Hambone Masonry 14 04-22-2007 08:54 PM
