Fixing Low Spot In Lawn - Landscaping - Contractor Talk
Old 08-29-2015, 08:42 AM   #1
Stunt Carpenter's Avatar
Rewards Points: 3,012
Hey guys I'm having some problems with settling around my front porch.
When I first moved in the downspout was directing water in the wrong place and caused the problem but I am unsure what I can do to fix it. I would rather not remove the grass if I don't need to.
Can I add new top soil over the grass or is that's going to just make a mess?
https://builddaley.com/
Stunt Carpenter is online now
Old 08-29-2015, 09:05 AM   #2
hdavis's Avatar
Re: Fixing Low Spot In Lawn
Attachment 219730
You can add soil over the top, but it's best to break up the grass some first. I've done it both ways, and the only climate it really makes a difference is where you have droughts or fungus problems.
hdavis is online now
Old 08-29-2015, 09:14 AM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 202
While you could easily add soil over the top like mentioned above - why not rent a sod cutter, roll it up, add the soil and roll it back down. I would also slightly mound it so that when it settles some you wont have the same issue. Just make sure you have everything drain away from the house
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
hdavis (08-29-2015), Rio (09-03-2015)
Old 08-29-2015, 10:37 PM   #4
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 1,019
What I used to do is add sand over the grass. Enough to let the grass blades show thru. The sand works its way into the soil and lifts the valleys up.
gowings is offline
The Following 2 Users Say Thank You to gowings For This Useful Post:
handymanhenry (09-30-2015), Railman (09-06-2015)
Old 09-06-2015, 07:52 AM   #5
markandrews's Avatar
Trade: Landscaping
Rewards Points: 4
This is exactly what I've done as well, with good results.
markandrews is offline
Old 09-30-2015, 05:55 PM   #6
handymanhenry's Avatar
Trade: landscaping
Rewards Points: 6
Show us an updated pic when you get it fixed!
handymanhenry is offline
Old 10-01-2015, 08:07 AM   #7
Don't hold your breath. Nothing is happening till spring now. To much else to do
builddaley.com
Old 02-16-2016, 02:10 PM   #8
BenTaylor's Avatar
Trade: landscaping
Rewards Points: 66
I would remove the grass with a sod cutter, shovel some fresh dirt in there, put the sod back on, water liberally and be on my way. Doesn't have to take long.
BenTaylor is offline
Old 02-17-2016, 11:46 AM   #9
Brownchickenbrowncow
elementbldrs's Avatar
Trade: General Building
Rewards Points: 1,376
I know a few landscapers that carry a container of sand and seed just like at the golf course for sanding divots. They infill spots here and there, over time they have a nice flat lawn.
Phil
elementbldrs is offline
Old 02-18-2016, 12:54 AM   #10
dmcarnes's Avatar
Trade: Remodeling / general / handyman
Rewards Points: 80
Had an old property with a mess of a lawn, mixed sand and top soil and it did a good job of leveling out and letting the grass grow through. Also, square point shovel works just as well as a sod cutter for a small area like that.
dmcarnes is offline
Old 02-18-2016, 03:14 AM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,696
I put top soil on an area in my lawn that kept sinking where a tree used to be. As the grass grew through it I kept adding more until I had it even. Worked like a charm.
Calidecks is online now
m1911 (02-18-2016), SmallTownGuy (03-07-2016), Texas Wax (03-07-2016)
Old 02-18-2016, 03:17 AM   #12
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I'm surprised that doesn't kill the grass, learn something new everyday
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Calidecks (02-18-2016)
Old 02-18-2016, 06:28 AM   #13
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,888
I didn't know fake grass could grow! Or was this at a different house?
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following 2 Users Say Thank You to heavy_d For This Useful Post:
SmallTownGuy (03-07-2016), Tom Struble (02-18-2016)
Old 02-18-2016, 10:31 AM   #14
GC/carpenter
Calidecks's Avatar
My front yard is real.
Old 02-18-2016, 11:15 AM   #15
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Oh right.
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 03-03-2016, 08:36 PM   #16
nailomatic's Avatar
Trade: general
Rewards Points: 294
Attachment 219730
Seriously. Put some dirt there to get a nice grade. Plant some grass seed. Move on. Gads.
Are you serious?
nailomatic is offline
Old 03-03-2016, 08:37 PM   #17
nailomatic's Avatar
Trade: general
Rewards Points: 294
Attachment 219730
... almost forgot. If your downspout is "directing water in the wrong pace", then direct it to the right place.
Hope this helps.
Peace.
Old 03-07-2016, 09:19 AM   #18
Are you serious?
Really you just needed to come in here and post that.
Are you serious?
builddaley.com
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
dmcarnes (03-07-2016)
Repairing lawn after construction. nickko Landscaping 13 10-06-2014 04:59 AM
lawn maintnance rgb lawns Help Wanted or Looking For Work 0 04-25-2013 08:26 PM
Top Spot for "Remodeling Kansas City" kcremodeling Websites and SEO 10 02-25-2011 07:49 PM
strange wet spot skipdow Windows, Siding and Doors 16 02-06-2011 01:47 AM
Squishy Spot in My Lawn sage Landscaping 2 04-05-2006 06:09 AM
