Brick Walkway Renovation - Landscaping - Contractor Talk
Old 03-08-2010, 11:32 AM   #1
gzec's Avatar
I would like to repair a poorly laid brick walkway. I would like to clean out the dirt/material between the bricks and add new sand, level and secure the sides. What is the best method for removing the existing dirt/sand between the bricks. Hose w/special nozzle, air spade etc?
gzec is offline
Old 03-08-2010, 12:31 PM   #2
Thom
thom's Avatar
Rewards Points: 4,748
Re: Brick Walkway Renovation
The best method for removing the dirt between the bricks is to use a shovel, ..............................................
after first removing the bricks.
thom is offline
Old 03-08-2010, 02:40 PM   #3
AustinDB's Avatar
Rewards Points: 1,254
look up info on brick pavers, such as EP Henry (many others too) for proper installation instructions, that is if you're installing similar to concrete pavers. I've seen many a walkway with heaving throughout...depends on how 'proper' you want to fix it.
AustinDB is offline
Old 03-08-2010, 04:34 PM   #4
Yard Builders's Avatar
Trade: Landscaping Design & Construction
Depends on the level of quality, effort and expense, that you want to invest. You can power wash the dirt and sand from the joints, but probably won't get the whole joint...and will make quite a mess.
If you want it to look as good as possible, and last a long time...I would suggest removing all of the brick, and then power wash them, especially if you have had movement, ie: joints opening up, settling and/or heaving. Good also to be able to get matching replacements for any broken, or if new cuts need to be made. At this point, you can check out the base to see if it's adequate and adjust where necessary. But remember, it's only as good as its base.
Assuming you have a proper base, relay the brick. Instead of using sand to fill the joints (old school), consider using a "polymeric sand", which is designed for this application. It's a blend of fine silica w/ polymers which bond to the brick. It's sold at any brick paver supply and some contractor supply stores. It's not what I would call cheap, but well worth the money if you want it to last and not have to keep dealing w/ it, also helps to reduce weeds. There is a "high performance poly sand" for wide joints. Most important to gain full benefit of the product is to make sure you fill the entire joint, not just the top half. Also a good idea to run a wacker on it, to help it settle in. It also helps to put down an old rug or carpet between the wacker and the brick so you don't mark up or damage the brick. Hope this helps!
BTW...I'm the new guy, my first post!!
Yard Builders is offline
Old 03-08-2010, 06:07 PM   #5
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Nice first post! Welcome. Do the intro thing in the intro section. They like that here...proves you're not Osama I guess...
And you have to put your location in your profile or people will go apesh!t
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
Old 03-08-2010, 06:52 PM   #6
Thank you for the kind words Chris! And yea, I'll take care of all that...wouldn't want to upset the natives.
brick wall renovation or coverup rusty2010 General Discussion 9 05-25-2009 02:55 PM
brick wall renovation or coverup rusty2010 Commercial Construction 0 05-25-2009 08:26 AM
brick wall renovation or coverup rusty2010 Contractor Swap 0 05-24-2009 07:39 PM
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 07:19 PM
