Base Of Retaining Wall (Timber) - Landscaping - Contractor Talk
Old 04-26-2010, 11:43 PM   #1
Diamond Cut Construction
gariecrowder's Avatar
Trade: GC/Remodeling Contractor/Residential
Hi guys,
I have a question that maybe you guys can clear up for me. I have a buddy that says I do not need to use crush gravel rock on my base if I'm using timber. I have only built two retaining walls so far. They have come out pretty good, I'm happy to say. He says. "I should just stake the timber to the ground. As long as i have my drain pipe properly buried i would have no problem with drainage. Is there anyone else that agrees with this? I have never heard of such a thing. Please enlighten me if you can. Thanks in advance for the lesson.
Diamond Cut
Construction
gariecrowder is offline
Old 04-27-2010, 12:22 AM   #2
Making a living
Five Arrows's Avatar
Trade: Kitchen and Bathroom remodel, general contractor
Rewards Points: 182
Re: Base Of Retaining Wall (Timber)
Are you suggesting placing wood on the ground and putting a retaining wall on it to level the wall? I might not be understanding. This sounds crazy to me. The wood will rot and the wall fall over or go out of plumb as the natural decay process progresses.
Stick with compacted rock for a base.
"Getting paid is a pretty important part"
Five Arrows is offline
The Following User Says Thank You to Five Arrows For This Useful Post:
jg2259 (07-19-2016)
Old 04-27-2010, 04:36 AM   #3
AtlRemodeling's Avatar
Trade: Residential Remodeling
Rewards Points: 250
Personally I would use a gravel footing for any wall but then again personally I would not build a wood retaining wall. We always build segmental retaining walls.
Many factors come into play when building a retaining wall. Soil composition, height of wall, slopes above or below the wall, etc. If it is a very short wall you could probably get away without a gravel footing but to me gravel is easier to level than soil. Make sure you embed enough courses below grade to stabilize the base of the wall and off you go..
AtlRemodeling is offline
Old 04-27-2010, 12:11 PM   #4
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Lightbulb
Gravel will filter the water and allow it to
flow through whatever weep areas are available.
There are plenty of wood retaining walls around.
Railroad ties and pressure treated timber work well
and can be seen along Americas highways.
In the mines, wood has been used for centuries
to hold back the earth.
skyhook is offline
Old 05-01-2010, 10:21 AM   #5
Yes, I would put the timber right on the ground. I agree with AltRemodeling, it would seem that gravel would work best for leveling. No doubt about it. A couple of the premier wall builders in my town, both agree that there's no need for gravel. They say all that is needed is timber, 6 inch nails, period. They claim to not use any rebar, no 12 inch spikes or anything. The wall is 40 feet long and 3 feet high on one side, 2 feet on the other. Driveway in the middle. I'm beginning to wonder if there are joking.
Diamond Cut
Construction
Old 05-04-2010, 10:36 AM   #6
pdmcgowan's Avatar
Trade: Excavation
I dont know I'd be safe and put atleast a 6" base. We have craptastic timber retaining wall on the front of the tuck under house that leads up to the front door thats causing alot of problems. Basically the whole thing is settling downwards and out pulling stoop and driveway edge downward. I know theres more to it then just a bad retaining wall but I dont think it helps it anyway. I see a awful lot landscrapers causing problems trying to cheap out on basic construction practices.
pdmcgowan is offline
The Following User Says Thank You to pdmcgowan For This Useful Post:
jg2259 (07-19-2016)
Old 05-05-2010, 01:22 AM   #7
I agree. I'm to going to do what i know, gravel base it is. I want to thank all you guys for the advise and help. This is one of the best sites for contractors hands down. Thanks again.
Diamond Cut
Construction
Old 05-06-2010, 02:05 AM   #8
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
I've only ever built stone or block walls and always use gravel.
but I know guys who build it with wood and they don't use gravel. Make sure you do proper deadmen, and I guess it would be fine.
Winchester is offline
Old 05-10-2010, 02:30 PM   #9
Winchester thanks, for the feedback. Deadmen are the very essence of timber walls. Not properly assemble would be a waste of time and money. I can assure you the customer would not be please in a couple years. Thanks again.
Diamond Cut
Construction
Old 05-26-2010, 05:32 AM   #10
Stone Guy
Rock Headed's Avatar
Trade: masonry
Rewards Points: 534
Compacted soil, rebar, ten inch nails and deadmen.
Rock Headed is offline
retaining wall help tuffplay Landscaping 9 09-29-2010 08:29 AM
Retaining wall block? Upchuck Excavation & Site Work 10 09-29-2009 05:25 PM
Setting fence posts on top of concrete retaining wall Tim C. Decks & Fencing 7 06-04-2009 07:16 AM
Retaining wall stepup ranvic Landscaping 3 11-11-2008 10:12 AM
Block retaining wall repair Sieloff Masonry 1 05-13-2008 07:34 PM
