Licenseing/certification For Pool Heat Pumps Only - Contractor Licensing - Contractor Talk
Old 01-11-2019, 08:38 AM   #1
Licensed Gas contractor
gastek's Avatar
Trade: Pools
Rewards Points: 1,012
I am a FL state licensed pool contractor and hold a gas/LP license to work on gas pool heaters, my main business area. I have been doing this for the past 10 years. I work only on gas, natural/LP, heaters. I have toyed with the idea of working on electric heat pumps but to be legal, I would need probably the type 1 608 certification, guessing this.
In the state of Florida, can you get this cert or do you also need an HVAC license? If this cert is what I need, I am guessing this can be obtained online or thru a weekend course. Guessing there is a test also. Google isn't always helpful nor are the folks at DBPR.
This is just for Florida only. Not looking to work in the HVAC field, just repair electric heat pumps for pools.
gastek is offline
Radiant Heat Layout HeyGuiher HVAC 7 01-08-2014 01:49 PM
Tile Heat shield redwood Tiling 16 10-23-2012 08:54 PM
Heat Pump lockout temperature ENERGYSTAR HVAC 7 12-14-2010 10:06 PM
CO2 heat pumps. flashheatingand HVAC 14 11-08-2010 08:31 PM
heat pump jdager HVAC 2 01-31-2009 04:17 PM
