California Licensing - Page 136 - Contractor Licensing - Contractor Talk
Old 05-03-2019, 10:20 AM   #2701
Calif Licensing Expert
License Guru's Avatar
Trade: Former California Contractors State License Board
Rewards Points: 1,602
Re: California Licensing
Originally Posted by Chris Doom View Post
I have a question Guru. I am interested in getting my GC and my new employer would probably sign off in I'm sure in a year or so which would add up to 6 years experience in my field. The problem is that the previous experience was cash jobs and no licensed GC to sign off on it. The apprenticeship was very good with an extremely knowledgeable guy but that doesn't matter in the eyes of the state. My new job has regular paychecks and all so there is a paper trail and a lot of variety of work from frame to finish. Should I wait to get more "official" experience before applying? My goal mainly is continue to work for this GC and other GC's as well as a sub.
Hello Chris.
I assume the new employer holds the B classification?
If you submit self employed experience, the cslb will require that you submit project forms explaining the projects you've worked on and the work you performed. You could, however, submit the cash paying experience as employed and list the B contractor(s) who was paying you under the table. The cslb doesn't care how you were paid, but they will ask you to document/prove your experience.
Phil Cocciante
You've got Questions? I've got Answers!
License Guru is offline
Old 05-15-2019, 09:06 PM   #2702
Shedman's Avatar
Trade: Framimg and carpentry
Hi license guru I got a big question I hope you can help with I've been working for a ca shed company as a subcontractor for 2 years and worked for another installer for 3 years here also before I went on my own with my own tools so I have 5 years or so experience but with 3 years cash and 2 years pay stubs and 1099s and tax returns . So would I qualify for a general b ? The sheds require multiple trade skills to be used but primarily framing and carpentry siding finish trim and painting. The reason I want to get a class b is so I can work at tuff shed because they require class b license to do their contracts. Any help greatly appreciated
Shedman is offline
Old 05-16-2019, 07:04 PM   #2703
Shedman and I discussed his options via email.
Phil Cocciante
Old 05-16-2019, 08:02 PM   #2704
alonsoedgar96's Avatar
Trade: C-5
Rewards Points: 14
Hello,
if a application is returned for correction, stating that all corrections must be initialed and a new application must not be submitted, should I put the new information on the existing application? do i cross out or white out the old information? The qualifier is being changed.
thank you
alonsoedgar96 is offline
Old 05-16-2019, 09:11 PM   #2705
White out works.
Phil Cocciante
The Following User Says Thank You to License Guru For This Useful Post:
alonsoedgar96 (05-17-2019)
Old 05-21-2019, 12:01 AM   #2706
Amarx's Avatar
Trade: Electrical
Im planning to take the the c10 exam. Im a journeyman with almost three years turned out. I passed an apprenticeship, My employer signed my emplyment verification today. I am very excited to try to swim on my own. How long from start to finish is the process, typically. Is there any common mistakes made on the paper work I should pay attention to. Is there any parts of the test i should concentrate on. Thank you for any light you can shed on the matter I truly appreciate it
Amarx is offline
Old 05-21-2019, 09:08 PM   #2707
From app submittal to license issuance.... at least 8 weeks.
The formatting of your experience outline will be the crucial part.
Phil Cocciante
Old Today, 12:32 AM   #2708
milosh's Avatar
Trade: Waterproofing
Rewards Points: 2
I'll try to make it short. Please help me choose an option:
Option 1 - I worked for a roofing company for 6 years where about the last 2 years I was a journeyman waterproofer (I was in the waterproofing division, not roofing). I have my journeyman card from the union but I did not complete my apprenticeship program. I have a Bachelor in construction management and want to see if I qualify for the roofing license C39. If so, do I have to submit W2's when I submit the application?
Option 2 - I have worked for a glazing contractor for about 6 years now (4 in the shop and 2 as a project manager) and have my bachelors in construction management. I have not worked in the field as a glazier though.
Option 3 - I want to do caulking and sealant work around windows, concrete, siding, epoxy application, (waterproofing), etc. using the D-12 license classification.
Which one would you recommend I proceed with?
Thank you
Which one of these do I qualify for to get my license?
milosh is offline
Old Today, 10:24 AM   #2709
Hmmmmm door #1, door #2, or door #3??
#1: You could submit C-39 experience but it wouldn't be true and accurate, and impossible to prove. This one's out.
#2: You could submit supervisory experience, suggesting that you have acted in a supervisory capacity in the field. Pay stubs would prove your employment, but the rate of pay would have to be at the supervisory level. This one...unkown.
#3: Would be the easiest to prove, but the most restrictive in what you could do. Plus there is no trade exam, only the law/business test. This one is probably the best option.
You degree would be worth 2-3 years of experience credit toward the 4 year minimum requirement.
Phil Cocciante
Old Today, 02:28 PM   #2710
milosh's Avatar
Rewards Points: 2
Thank you for the help. I will proceed with option 3 since the type of work I want to do caulking and sealant work around windows, concrete, siding, epoxy application, (waterproofing), etc. using the D-12 license classification.
Since I have a bachelor degree, can I obtain the 1-2 years of experience required for me to obtain the roofing or painting license by doing small jobs in the future?
Do you think obtaining the D-12 license now, will lead to obtaining the painting or roofing license in the future?
Thanks.
milosh is offline
Old Today, 03:18 PM   #2711
jusang's Avatar
Trade: D-34
Rewards Points: 14
Hello License Guru, I have a few questions I'm hoping you can help with, I attached the part 2 experience portion of my application with personal info whited out to help clarify.
When submitting the work experience the "full time" box was checked rather than the "part time" box. I have 15 years working with my employer and half of that, 7.5 years, is journeyman level or higher of experience. The app was also returned because only the last 10 years of experience are accepted. Do you see any issues with changing the full time to part time and using half of the last 10 years to equal 5 years of experience? Should I include a separate letter explaining each of the changes?
The final question is about editing the existing app, should I be crossing out the old information and writing above like the reviewer started to do in blue or should I use white out as you recommended previously.
Thanks for any recommendations you can provide.
jusang is offline
Tags
application , california , contractors license , cslb , felonies , license guru , test
Are Cost Plus Home Improvement Contracts Illegal in California? Will Path Business 10 05-21-2014 12:41 PM
Licensing School - California sa1245 Contractor Licensing 11 06-14-2013 12:21 PM
Exit Lights in California darren Electrical 17 03-23-2008 11:13 PM
Additional licensing Milhaus Remodeling 8 10-27-2007 10:34 AM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 08:57 AM
