California Licensing - Page 134 - Contractor Licensing - Contractor Talk
Old 02-17-2019, 08:01 PM   #2661
Calif Licensing Expert
License Guru's Avatar
Trade: Former California Contractors State License Board
Rewards Points: 1,842
Re: California Licensing
You'll need to complete the work certification form that is part of the application. This form gives them an overview of your overall experience. The project list form breaks down your experience per project.
You can find my app review service here.
Phil Cocciante
You've got Questions? I've got Answers!
License Guru is offline
Old 02-23-2019, 03:25 PM   #2662
codyj's Avatar
Trade: new to the trade
Rewards Points: 32
Hello,
I would like to get started in the roofing business and was considering forming a LLC and then hiring a licensed roofer to work with me. However, it appears the LLC would also need a roofing contractor's license and the bonding requirements for a LLC are rather high compared to a sole proprietor?
Then I was thinking of having the roofing business in the name of my employee as a sole proprietor and I would be licensed as a "home improvement salesperson" HIS so I can take bids. The problem with this arrangement is when the checks are written they would be to my employee?
Any ideas on the best way to do this?
codyj is offline
Old 02-24-2019, 07:56 PM   #2663
LLC is way expensive, and a new business probably wouldn't qualify for the LLC worker/surety bond. If you did, it would be $5000+ per year.
What if you obtained a corporate number and applied for a corporate contractors license. You could use the employee to be your qualifier, and you would be listed as an officer Pres/CEO?
That way you could bid, write contracts, supervise jobs, obtain experience so that you could replace your guy as the qualifier down the road.
Too much personal liability risk with a sole prop roofing license.
Phil Cocciante
The Following User Says Thank You to License Guru For This Useful Post:
Calidecks (02-24-2019)
Old 02-24-2019, 11:07 PM   #2664
codyj's Avatar
Rewards Points: 32
I'm new to this, what is a corporate number?// how is that different from a LLC
codyj is offline
Old 02-24-2019, 11:36 PM   #2665
codyj's Avatar
Rewards Points: 32
also, I posted this same question as a thread on this forum and before it was closed got the typical "start at the bottom" answers.
starting at the bottom isn't really a good place to be when you have the resources to hire a professional and start a real business
codyj is offline
Old 02-25-2019, 12:45 PM   #2666
You would/could apply for a corporation with the Sect. of State. Then file subchapter S with the IRS. This would give you better personal liability protection than a sole owner license or standard C corporation. (All corps, when formed, are C corps)
After the Sect of State issues the corporation number, then you could apply for the contractors license.
Google would do a better job than I can of answering the difference between a corp and LLC.
Phil Cocciante
Old 02-27-2019, 02:50 PM   #2667
alonsoedgar96's Avatar
Trade: C-5
Rewards Points: 14
Hello!
Thank you in advanced for any help provided!
So here is my situation. Me and my father are looking to start a small framing company (and hopefully expand it in the future). My father would like the business to be under my name. He wants me to be the business owner and handle the business side of it. I am 22 years old and have no experience in the field as a journeyman or anything like that. So I obviously can not apply for a license. My father, on the other hand, has all the experience required. He has 15+ years experience as a journeyman that he gained at a framing company. Proving it is not an issue either as he has all his W2's or whatever they might ask for. So my question is, how do we go about applying with him as the licensed contractor, but me as the business owner? If even possible? Also, he would be applying with his TIN. I read on the application instructions that this isn't a issue. Any thoughts on that? Will it be a issue?
Thank you
alonsoedgar96 is offline
Old 02-27-2019, 03:01 PM   #2668
Hello,
You could apply as a sole owner and have dad as the RME. Which means you'd have to carry workers comp.
Or apply for a partnership license where you would be the general partner and dad the qualifying partner.
Or you could create a corporation and apply for a corporate license where you could be the Pres/Sect/Tres and dad would be the RMO.
Phil Cocciante
Old 02-27-2019, 05:06 PM   #2669
codyj's Avatar
Rewards Points: 32
I dont know much about corporations. Every business I've started has been an LLC and then I hire the pro's
So let me get this straight - incorporate, then have the corp apply for a roofing business license - but wouldn't the employee have to be an owner??
And what would the bonding requirements be for a corp vs sole proprietor?? California is just crazy with this 4 year rule b/c most states it's more like 4 months.
Working for someone else is not an option - I'm too old for that not to mention they'd probably have new employees do all the donkey work for the first few months/YEARS
I like the idea of forming a company, hire 1-2 PRO's, get rolling and learn the business.
codyj is offline
Old 02-27-2019, 05:13 PM   #2670
A corp, same with an LLC, the entity "owns" or holds the license. An individual would be the qualifier for that license.
Bonding for a corp is the same as for a sole owner or partnership license. Just the one 15k bond is required.
Phil Cocciante
Old 02-27-2019, 05:20 PM   #2671
codyj's Avatar
Rewards Points: 32
Getting back to the sole proprietor - if I did find a licensed roofer willing to operate as a SP and then if I was licensed as "home improvement salesperson" I understand we would be losing MOST of the protections of an LLC however if your work were that shoddy an LLC wouldn't protect you anyway IMO
So, assuming I were to go that route all I would need is worker comp for myself and then my pro roofer to learn the trade from.
Almost any other state this wouldn't be an issue to just hire the specialist and get rolling/ learn the trade and then get my own license in a few MONTHS
codyj is offline
Old 02-27-2019, 05:23 PM   #2672
codyj's Avatar
Rewards Points: 32
But wouldn't the licensed roofer I hire HAVE to be a owner of the corp? And if I list said roofer as an employee he would be disqualified from working for anyone else?
codyj is offline
Old 02-27-2019, 05:26 PM   #2673
No one owns a corporation. It has officers and a qualifier of the classification.
If that qualifier is an RME (employee) then yes, he could not be a qualifier on any other active license.
Phil Cocciante
Old 02-27-2019, 05:40 PM   #2674
codyj's Avatar
Rewards Points: 32
I can't hire someone full time - not yet anyway. I was hoping to keep everyone as an independent contractor (I tell people this is sometime BETTER than a w-2 employee b/c you can write off YOUR expenses at tax time!)
If the bonding requirement is only 15k then why would an LLC be too expensive?
codyj is offline
Old 02-27-2019, 05:43 PM   #2675
The LLC worker/surety $100,000 bond can cost $3000 - $5000 Per Year!
And that's after you provide the broker with all of your personal and business financials... even when it's time to renew the bond... same hoops, same price.
Phil Cocciante
Old 03-02-2019, 12:17 AM   #2676
Hvackid's Avatar
Trade: C
Thanks for the Help. I appreciate it.
I have another quick question. Would it be bad if I just submit 3 years of Work Experience? Since I have a Certificate from a college in refrigeration and an Associate in Heating and Air, wouldn't this count as credit for experience for the C-20 license? I know the EPA is basically mandatory so I don't count that. Also I have some self-employed work, how would that affect the experience part. Does it matter if the self-employed work is "under the table"? Any help is always appreciated. Thank you.
Hvackid is offline
Old 03-11-2019, 07:04 PM   #2677
Any college or trade courses are valid and should be submitted. You'll also need to provide them with a CFC or Universal Type II card.
If you are paid under the table by a contractor, you can submit that as employed experience. The cslb says they won't go after the contractor for paying some under the table.
Phil Cocciante
Old 03-13-2019, 03:03 PM   #2678
Luke_16D's Avatar
Rewards Points: 4
License guru
As of March 2019, how has the CSLB been about pulling B license apps for secondary review? Have they lightened up at all?
Luke_16D is offline
Old 03-13-2019, 04:54 PM   #2679
Nope. Unless your experience was obtained as an employee of a B contractor, your application will require permits (pulled by your or not, in your name or not) and as many CSLB project list forms as it takes to come up with at least four years of B experience.
If some of those projects don't include framing as part of the scope of work, then those projects will most likely be eliminated.
I just came from a meeting at the CSLB where they are discussing (again) the possibility of creating a classification that doesn't require framing experience to qualify for the exam.
Phil Cocciante
Old 03-15-2019, 12:04 AM   #2680
Luke_16D's Avatar
Rewards Points: 4
What is the best way to apply if your experience was gained employed by a B licensed contractor but you were being paid cash under the table?
And any time frame as to when the new classification would possibly become an option?
Luke_16D is offline
Tags
application , california , contractors license , cslb , felonies , license guru , test
Are Cost Plus Home Improvement Contracts Illegal in California? Will Path Business 10 05-21-2014 12:41 PM
Licensing School - California sa1245 Contractor Licensing 11 06-14-2013 12:21 PM
Exit Lights in California darren Electrical 17 03-23-2008 11:13 PM
Additional licensing Milhaus Remodeling 8 10-27-2007 10:34 AM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 08:57 AM
