Tricky Sheeting Problem - Excavation & Site Work - Contractor Talk
Old 11-30-2011, 05:34 PM   #1
SlumberJack's Avatar
Trade: Site Work, Concrete, and Masonry
Rewards Points: 25
Hey guys; I'm figuring a job calling for the excavation for a new street elevator in the Bronx connected to the subway beneath and it will require some support in the way of sheeting.
We're digging to the subway roof beneath the road which varies from 8'-6" to 17'-6" below street level. The dig area is about 34' x 30'.
My problem is the fact that we're digging down to the existing concrete roof deck and will require sheeting to do so; and the issue is at the toe of the sheeting...obviously we cannot just drive the soldier beams down as we normally would because it's not just earth below...we have at least 12" of concrete and steel in the subway roof deck.
Does anyone have any ideas? I don't think we're able to drill into the concrete roof deck but I have an inquiry sent in already...
SlumberJack is offline
Old 11-30-2011, 08:34 PM   #2
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Re: Tricky Sheeting Problem
I am assuming that this hole will be open for awhile since you will be forming and pouring concrete.
I would contact GME, they might be able to come up with a solution.
rino1494 is offline
Old 11-30-2011, 10:53 PM   #3
Rewards Points: 25
Yes that's correct; we're pouring the concrete elevator pit and shaft...the elevator shaft itself is about 11' x 12' but there is also going to be some slab infill and structural steel work in the area surrounding and adjacent to the shaft; which is why the limit of excavation is about 34' x 30' ... we definitely have to provide some sort of excavation support as we're 25% in the street and 75% at sidewalk and we have a building within 5' on one side with the street on the other...we cannot compromise any larger an area than the limits I noted above.
Yeah I was thinking about GME's Slide Rail System...not sure I can get it to the size and placement I need. Thanks for the heads up...
Wondering if there's something I am not seeing or haven't thought about...
Old 12-01-2011, 07:40 AM   #4
Owner
ajbackhoe's Avatar
Trade: Excavation, Site work, Septic, Demolition
Rewards Points: 77
Maybe a Vanguard shoring system. I can send you pictures of one I used. northeast shorings website has good pictures, the one on his website is actually pictures I sent him. Not sure if I can post his website link.
Alan
A O Construction Inc.
Attleboro, MA 02703
Email: [email protected]
www.aoconstruction.net
ajbackhoe is offline
Old 12-04-2011, 09:21 AM   #5
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
Efficiency has a neat system that combines slide rails and some other sections used to go around utilities. They have different panels that are very narrow used to shore around obstacles in the way of large slide rail panels
HUI is offline
Old 12-04-2011, 04:46 PM   #6
Rewards Points: 25
Thanks guys...would like to see any pictures or a link for sure.
Old 12-04-2011, 07:11 PM   #7
JDavis21835's Avatar
Trade: Excavation
Rewards Points: 386
Google will help you. Worked for me http://www.efficiencytrenchbox.com/P...ilSystems.aspx
JDavis21835 is offline
Duraspin deck screw problem HandyHails Decks & Fencing 9 06-04-2012 05:33 PM
Major problem spraying "SW All Surface Enamel" in Black. GHPJerry Painting & Finish Work 19 08-01-2011 09:15 PM
Concrete problem...... ContractorDFW Concrete & Paving 10 07-03-2011 10:06 AM
Sheeting with staples or 8d's newbuilder Framing 7 10-09-2009 07:45 PM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
