Transit Calibration - Excavation & Site Work - Contractor Talk
Transit Calibration
Old 02-22-2010, 10:19 PM   #1
Gnella's Avatar
Trade: site work/paving
Rewards Points: 89
Transit Calibration
Anyone know how often to calibrate your laser transit or sight transit? I have topcon rl60b and topcon sight transits. I can't find the manuals and thought this would be more fun than looking on line.
Gnella is offline
Old 02-22-2010, 10:30 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 736
Re: Transit Calibration
I have an old telescope I know is dead on and use it to check the laser & vice versa. I have the laser, Spectra LL550, done evry 2-3 years unless it has been dropped.
My Spectra has been a seriously bullet proof instrument.
Also have a PLS180 I check against the Spectra etc.
griz is online now
Old 02-23-2010, 08:47 AM   #3
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
I make sure lasers are calibrated every winter. One mistake can cost a lot of money.
Upchuck is offline
The Following User Says Thank You to Upchuck For This Useful Post:
pce (02-23-2010)
Old 02-23-2010, 11:19 AM   #4
cexcavation's Avatar
Trade: Excavation Contractor
Rewards Points: 250
Take a piece of paper and set it out 50' or more and mark where your laser hits.
Leaving the base exactly where it is, rotate the head unit 180deg. If you hit the same mark, no adjustment necessary.
If you are too high or too low, calibrate the lazer to the point in the middle and recheck.
There should be an allen head, etc. adjuster screw on the head unit to adjust the pendulum.
This ensures the laser is running on plane.
As far as a sight transit, you may be able to do some type of variation on this process using a helper.
Hope that helps.
cexcavation is offline
Old 02-23-2010, 04:44 PM   #5
pce's Avatar
Trade: the tough jobs
Rewards Points: 25
I worked for Spectra Physics. We were trained to field calibrate lasers. I would always take them into the shop to have them done on the range, same with the transits. It is worth every penny spent to have done in the shop. One wrong grade shot will cost more than the range fee, which I think was $ 50.00. Don't take the chance. Danhoe
pce is offline
The Following User Says Thank You to pce For This Useful Post:
JDavis21835 (02-24-2010)
Old 02-23-2010, 09:38 PM   #6
Gnella's Avatar
Rewards Points: 89
thanks everyone. I'm dropping them off at the shop today.
Gnella is offline
Old 02-23-2010, 09:40 PM   #7
Rewards Points: 250
The method I described is straight out of the manual for my laser. I am not sure what they do differently at the range, but I have calibrated my laser and it is spot on from what I know....no complaints from foundation guys yet!!!!
Old 02-24-2010, 03:49 PM   #8
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
Posted by cexcavation
While I'm sure your way is fine, I also take mine to the shop. I consider it a year tune-up for the lasers.
Upchuck is offline
Using A Transit To Determine Height bradjacob Excavation & Site Work 23 08-29-2010 12:23 AM
Transit On Slopes bradjacob Excavation & Site Work 6 12-15-2008 11:47 PM
interesting transit connect Bone Saw Vehicles 1 03-15-2008 07:16 PM
transit level for deck posts lemoncoke Decks & Fencing 23 08-30-2007 05:15 PM
