Tight Fit - Excavation & Site Work - Contractor Talk
Tight Fit
Old 03-25-2009, 09:40 PM   #1
backhoe1's Avatar
Trade: excavating contractor
Rewards Points: 182
Tight Fit
let's hear your ideas:
need to dig a hole 10' deep between 2 bldgs. only access from 1 side.
the biggest problem is the bldgs are only 11.5' apart .
backhoe1 is offline
Old 03-25-2009, 10:03 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,572
Re: Tight Fit
Amigo's. Several.
WarnerConstInc. is offline
Old 03-25-2009, 10:32 PM   #3
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
Re: Tight Fit
Originally Posted by WarnerConstInc.;643936[B
]Amigo's[/B]. Several.
Who makes the Amigo's? Is that a Dewalt or Fein master tool can't say I have seen that before.
rbsremodeling is offline
Old 03-25-2009, 11:42 PM   #4
Kgmz's Avatar
Re: Tight Fit
Is it a hole or a trench?
How wide and how long?
Kgmz is offline
Old 03-26-2009, 05:57 AM   #5
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 926
Re: Tight Fit
This is what I would use.
Tight sites are one of my specialties!
A little more info might help.
www.gebcon.com
tgeb is offline
Old 03-26-2009, 07:50 AM   #6
backhoe1's Avatar
Rewards Points: 182
Re: Tight Fit
It's a hole for a foundation approx. 14' wide and 20'long. the mini is how I bid it. just looking for other ideas.
Tom-
I like your pics, but how do you swing?
backhoe1 is offline
Old 03-26-2009, 08:06 AM   #7
Re: Tight Fit
Buildings 11' apart,
hole 14X20X10' deep?
Better have some shoring
in the bid too.....
neolitic is offline
Old 03-26-2009, 09:32 AM   #8
backhoe1's Avatar
Rewards Points: 182
Re: Tight Fit
neo-
the engineer said not to worry about the buildings, but i plan to step the other sides down.
bid letting today, maybe I won't have to worry about it anyway!
backhoe1 is offline
Old 03-26-2009, 11:19 AM   #9
jmic's Avatar
Re: Tight Fit
Originally Posted by backhoe1 View Post
Tom-
Sounds a little personal.
Joe
jmic is offline
Old 03-26-2009, 11:49 AM   #10
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Re: Tight Fit
How do you put a hole 14' wide between buildings that are only 11.5' apart? 10' deep I bet you are going past the line of repose. That's why Neo mentioned shoring. Have the PE put it in writing that you don't have to worry about the buildings. You get that bid under those conditions, you're hosed if you have to shore it up, or worse, have to reinforce or underpin the existing foundations
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Old 03-26-2009, 03:14 PM   #11
tgeb's Avatar
Rewards Points: 926
Re: Tight Fit
14' X 20' and 10' deep?
I would use a compact track loader for that, as long as there is enough room for a ramp out. I would guess that you have to haul everything away as well right?
With the loader you can get it on the truck at the same time.
Actually, I would use the mini ex and the track loader, might speed things up.
Tom-
On that job I needed to dig down 9' to the foundation footing on 1 of those buildings (the one without siding). I stacked the soil on the surface close to the machine. When I had a big enough pile I would move the excavator out of the way and grab the soil with the skid loader and get it out of there, repeat as needed.
www.gebcon.com
tgeb is offline
Old 03-26-2009, 03:20 PM   #12
Nac's Avatar
Trade: Concrete, masonry & excavation
Rewards Points: 324
Re: Tight Fit
I would use a John Deere 135zts how deep are the footings on the 2 existing building? I hope there are as deep or you will definitely need to underpin or provide shoring in front of them.
Nac is offline
Old 03-26-2009, 05:12 PM   #13
backhoe1's Avatar
Rewards Points: 182
Re: Tight Fit
the building on one side jogs out, so where the ex would sit it is 11.5', but where the addition goes they are 14' apart.
As far as shoring etc. goes that wasn't the question. I was just making conversation about a challenging job that may be coming up and some people on here jump to the conclusion that I don't know what I'm doing.
The loader with a ramp idea was already thought of but on the side of this site (that actually has access) is an information tunnel about 3' away.
backhoe1 is offline
Old 03-26-2009, 05:33 PM   #14
Custom Stuff
Mike(VA)'s Avatar
Re: Tight Fit
backhoe1, sorry if you took my ramblings as jumping to a conclusion that you know not what you are doing. It's just that the information you gave us looked weird but now that you explain it, you are forgiven.
Sometimes people will bring up other issues as we did, from experience, and most of the time you don't really want to know why we have that experience. That comes from the 'let's leave that buried' files.
Mike(VA) is offline
Old 03-26-2009, 10:22 PM   #15
Re: Tight Fit
And sometimes we're
lucky enough to see someone
else get into trouble first!
neolitic is offline
Old 03-27-2009, 04:44 AM   #16
Custom Stuff
Mike(VA)'s Avatar
Re: Tight Fit
Yes, yes. And we like pictures.
Mike(VA) is offline
Old 03-29-2009, 06:16 PM   #17
john1066's Avatar
Trade: site work
Rewards Points: 75
Re: Tight Fit
i would use a komatsu pc 128UU like this one it can spin entirely with in its tracks and is only 8 feet wide only thing is you don't have a lot of reach but with that ammount of space you could back a 10 wheeler in behind you and load the truck
john1066 is offline
tight miters on door casings help! ROGER RAMJET Finish Carpentry 48 06-30-2013 10:31 PM
The use of a paint edger in tight spots?? Zeebo Painting & Finish Work 10 04-24-2009 07:47 AM
rusted tight door screws rservices General Discussion 19 02-25-2009 10:59 AM
How tight must forms be? lazerguy Masonry 18 09-22-2008 04:39 PM
Painting in a tight stairway - some tips of the trade Zeebo Painting & Finish Work 7 03-11-2006 08:49 AM
