Storm Sewer In Poor Soils? - Excavation & Site Work - Contractor Talk
Old 11-27-2012, 11:36 PM   #1
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
I have a county project that involves laying 24" RCP. Total footage of about 7000'. I have about 75% complete and now we ran into bad soils. The invert of the pipe is about 6' deep. The soils engineer bored the ground and the results are the top 5' are muck, then there is a couple of feet of peat and then the rest is marl down to about 15'. Then water sand. I was directed by the engineer to over excavate and fill with #8 crushed rock ( about 3/4"). So we did as directed and the pipe is still settling. The soils engineer is now calling for 24" of #2 crushed rock then the #8 above that. I think what is happening is the column is too narrow to support the pipe. Last I checked we were 7' wide and about 10' deep with stone. I also think the stone is absorbed horizontally by the marl walls. Which the creates a void for the pipe to settle.
Anyone run into this much bad ground? Our ideas so far are to increase the bottom area of the rock and build it In more of a bell shape. We are also considering going from RCP to say Hancore HP or ductile iron. Just looking for any ideas.
Thanks.
HUI is offline
Old 11-28-2012, 12:10 AM   #2
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,760
Re: Storm Sewer In Poor Soils?
I think that is the DEFINITION of a nightmare.
Have you considered a geotextile below the stone?
jhark123 is offline
Old 11-28-2012, 07:44 AM   #3
HUI's Avatar
Rewards Points: 178
I have. The problem is ground water. And the sloughing of the sides. As you dig the I'm this crap the walls just ooze in and squeeze the buckets and trench box. Then because there isn't not a bottom the excavator has no footing to pull a trench box or a bucket full of this crap
HUI is offline
Old 11-28-2012, 10:12 AM   #4
Cuda's Avatar
Trade: Drainage, Waterproofing & Sewer Contractor
Rewards Points: 214
Soils stabilization with polyurethane foam grout injection.
Cuda is offline
Old 11-28-2012, 10:24 AM   #5
HUI's Avatar
Rewards Points: 178
Never heard of the grout injection. Do you have any contacts or websites?
HUI is offline
Old 11-28-2012, 05:52 PM   #6
Crocop's Avatar
Trade: Concrete and building restoration
Rewards Points: 25
Look up a company called uretek they do urethane foam grouting
Crocop is offline
Old 11-29-2012, 12:09 AM   #7
PipeGuy's Avatar
Trade: underground
Rewards Points: 2,000
Originally Posted by HUI View Post
...we ran into bad soils. The invert of the pipe is about 6' deep....top 5' are muck, then there is a couple of feet of peat and then the rest is marl down to about 15'. Then water sand. I was directed by the engineer to over excavate and fill with #8 crushed rock ( about 3/4"). So we did as directed and the pipe is still settling. The soils engineer is now calling for 24" of #2 crushed rock then the #8 above that. Last I checked we were 7' wide and about 10' deep with stone. We are also considering going from RCP to say Hancore HP or ductile iron. The problem is ground water. And the sloughing of the sides. As you dig the I'm this crap the walls just ooze in and squeeze the buckets and trench box. Then because there isn't not a bottom
Dewater, dewater, dewater. The soil oozes because its being "pushed" by water. Until you remove the water from the equation you're fighting an uphill battle; potentially straight uphill. And if the soil is deflecting the sides of the trench shield to the point it confines the free movement of the bucket than its under-rated for the soils conditions. If it were me, I'd be wanting an approved change order before I went any further. I can't imagine the scope of work you're describing is within that of the County's contract; wether or not unit price line items are provided. The ground conditions you describe can easily make the last 1000 feet cost more than the first 6000. Good luck.
PipeGuy is offline
The Following 2 Users Say Thank You to PipeGuy For This Useful Post:
griz (11-29-2012)
Old 11-29-2012, 12:15 AM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 606
Perhaps the water table & soil conditions will not be alleviated by de-watering.
I agree with the C/O, but it sounds as if you are at the mercy of an Engineer. It's his problem to fix & yours to implement....
Does your contract/job specs cover this issue? to what remedy?
Good luck...
griz is online now
Old 11-29-2012, 01:31 AM   #9
HUI's Avatar
Rewards Points: 178
No there were not soil borings done in this area. These issues are above and beyond of the original contract.
HUI is offline
Old 11-29-2012, 10:33 PM   #10
Chuck
S.R.E.'s Avatar
Trade: Excavating, Clearing, Underground Utilities
Rewards Points: 506
Are you digging inside the trench box? I agree with the dewater stuff said above. I can't believe he had you using 3/4" rock. I would think you would need a base of at least 8"-12" rip rap that is at least 2' deep and then you place 6" of pipe bedding on top of that. Also make sure that your box is not below the pipe when you drag it. I would want the box to be at least above the spring line of the pipe when you drag it. Around here they usually refer you to the state spec for this and I know it does not call for 3/4" rock.
Have you considered using sheet pile and frames ? A company I worked for a while back would use that type of shoring when we had wet nasty ground. We would dig down about 4' then set a frame. Then we would set the sheet pile and just lap it. Then we would drive the sheets down and dig inside the frame. As the frame would settle down we would add frames as needed and hold them up with chains. It was a slow process and we would get about 3 sticks of pipe a day depending on utilities in the area.
S.R.E. is offline
Old 11-29-2012, 11:19 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 606
Helical piles with support cradles for the pipe?...
griz is online now
Old 11-29-2012, 11:44 PM   #12
HUI's Avatar
Rewards Points: 178
I think helicles or wood piles with a cap. I have a meeting with the engineer and the owner tomorrow.
HUI is offline
Old 11-30-2012, 12:14 AM   #13
PipeGuy's Avatar
Trade: underground
That's friggin' crazy. Piles and pile caps for a 6' deep storm sewer?
If you can get a workable excavation to 2' - 3' below pipe subgrade there's hardly any ground condition that a combination of geotextile, 4" stone and 2" stone won't make suitable to lay a 6' deep RCP storm sewer on. Use a woven fabric to keep the stone segrated from the surrounding soils and extend the stone section from 2 or 3 feet below the pipe to a foot abve - again wrapping the whole section in fabric. It might even help to have a layer of geogrid in there somewhere beneath the pipe.
Just out of curiosity, is the grade really flat? Is this a single long rrun carrying flow over a distance or a "trunk" with "branches".
PipeGuy is offline
The Following User Says Thank You to PipeGuy For This Useful Post:
Old 11-30-2012, 06:11 AM   #14
HUI's Avatar
Rewards Points: 178
Yes the grade is flat. We are laying the pipe in a bean field in northern Indiana.
I would agree with you on the stone and fabric. And it seems that some combination would work. The problem though that with using RCP it does take much settlement to open up the joints.
With these soils they are organic so they will continue to decay. Over time the entire pipe will settle thus opening up the joints.
We are digging with a 336 Cat. When you are excavating you will take a bucket swing and dump then come back around to get another bucket, the bucket will not fit in the trench because the walls are sloughing.
You can also taken the bucket and just push it into the ground just about as far as you want. There is very little resistance.
By far the worst soil conditions I've ever seen
HUI is offline
Old 11-30-2012, 08:44 PM   #15
Chuck
S.R.E.'s Avatar
Rewards Points: 506
You need to dewater and use trench boxes. Dig inside the trench box, keep pushing box down to bottom of base. Place and compact base inside box, Pull box up, place bedding, pull box up, lay pipe, bed pipe, pull box up, place about 2' of backfill on top of pipe before removing box. You will most likely have to use two trench box setups and have both in the ground most of the time. You will need to leave one in at all times so the bell is in the middle of the box. Good luck!
S.R.E. is offline
Old 11-30-2012, 08:47 PM   #16
Chuck
S.R.E.'s Avatar
Rewards Points: 506
Not cheap but, you could use ductile iron pipe with field lock gaskets. they will not pull apart.
S.R.E. is offline
Old 11-30-2012, 08:49 PM   #17
HUI's Avatar
Rewards Points: 178
Thought that as well.but once you get the box in there isn't solid enough material under the excavator to pull the box even with 20' wide mats below the excavator
HUI is offline
Old 11-30-2012, 09:21 PM   #18
Chuck
S.R.E.'s Avatar
Rewards Points: 506
Maybe you should just bore through the nasty area. Of course it would probably sink....
S.R.E. is offline
Old 11-30-2012, 09:28 PM   #19
HUI's Avatar
Rewards Points: 178
Yeah we have a 36" auger bore to do in about 500'.
HUI is offline
Old 11-30-2012, 09:33 PM   #20
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
They run pipelines through wetlands and swamps all the time. My buddy was on a pipeline job where they could take the bucket off a John Deere 270 and push it all the way into the swamp up to the boom. They welded the pipe together and floated it into the swamp.
Look into a well point system, over excavate poor soils, place geo-tex, backfill with some #4 stone, place some gravel for bedding and fuse HDPE together and possibly concrete it.
Either way, this is going to cost the county a crap load of money.
rino1494 is offline
Helical piers and the big storm out east killerdecks Decks & Fencing 1 11-16-2012 09:12 AM
Storm sewer and parking lot. jmacd Excavation & Site Work Picture Post 25 05-20-2012 07:35 AM
Storm Sewer Work jmacd Excavation & Site Work Picture Post 10 11-11-2011 05:57 PM
Insurance Storm Work, Documenting The Undocumented Storm...What Do You Use For Proof Ed the Roofer Business 6 04-15-2009 07:31 AM
storm sewer drop inlets dayexco Excavation & Site Work 7 06-04-2006 07:29 PM
