Sports Field Strip ? - Excavation & Site Work - Contractor Talk
Old 11-11-2012, 12:23 PM   #1
Nac's Avatar
Trade: Concrete, masonry & excavation
Rewards Points: 324
I just got a call to go look at a job tommarow to stip an existing sports field it is 40,000 sf we have to stip the grass and 10" of soil. With such a shallow cut what do you think is the best way to attack this job?
Facebook
Nac is offline
Old 11-11-2012, 12:59 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 678
Re: Sports Field Strip ?
Sounds sorta like a football field...Done it twice.
First time was with a guys on a 5' drag box. He was awesome & pretty quick.
Second time a Grader hit it first & a box cleaned it up.
No hidden sprinklers or water pipes?
griz is online now
Old 11-11-2012, 01:12 PM   #3
tgeb's Avatar
Rewards Points: 444
Looks like around 125 tri-axle loads of soil to load out, maybe more because of the grass.
I think I would figure a dozer to push it to an excavator or wheel loader. Do you have to haul it away?
www.gebcon.com
tgeb is offline
Old 11-11-2012, 01:14 PM   #4
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Grader, wheel loader and a roller.
rino1494 is offline
Old 11-11-2012, 04:29 PM   #5
Kent Whitten's Avatar
Rewards Points: 2,040
Around here, that soil is gold. Hope you have a place to haul and store it.
Maybe, if the grass is as griz said a football field, call a turf company and see if they have equipment to cut and load at least the sod.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 11-11-2012, 09:35 PM   #6
PipeGuy's Avatar
Trade: underground
Rewards Points: 2,000
Originally Posted by tgeb View Post
...I think I would figure a dozer to push it to an excavator or wheel loader.
Ditto. But if fine grading isn't required I might prefer track loader to truck.
PipeGuy is offline
The Following User Says Thank You to PipeGuy For This Useful Post:
tgeb (11-11-2012)
Old 11-11-2012, 09:56 PM   #7
tgeb's Avatar
Rewards Points: 444
I would agree with that as well.
www.gebcon.com
tgeb is offline
Old 11-13-2012, 01:46 AM   #8
Chuck
S.R.E.'s Avatar
Trade: Excavating, Clearing, Underground Utilities
Rewards Points: 506
If it is top soil with sod on top have you considered spraying to kill grass and weeds, Rototill, then Sell premium topsoil to highest bidder?
I would probably use dozer, grader and excavator, depending on the job site.
S.R.E. is offline
Old 11-13-2012, 02:56 PM   #9
Vagitarian
rino1494's Avatar
What will the area be used after it is stripped ? Does it need to be grade, will it turned back into another field ??
I have stripped topsoil areas with a 977 and loaded trucks. Only need 1 machine. If you need to fine grade for a field, I would strip with a grader with a 14' blade. Something big with awd. I also suggested a roller because it should be sealed, depending on future use.
rino1494 is offline
Old 11-13-2012, 06:49 PM   #10
Nac's Avatar
Rewards Points: 324
It is a soccer field. After it is striped thay want to put in artificial turf. They asked for rough grade only. I was leening towards an excavator and dozer combo. I hear you about rooling it to seal it.
Facebook
Nac is offline
Old 11-14-2012, 07:47 PM   #11
Little's Avatar
Trade: Commercial Construction
Rewards Points: 252
Hoe loading straight into truck if possible with dozer/roller grading behind.
Commercial Construction, Central Jersey
Little is offline
Old 11-14-2012, 08:22 PM   #12
tgeb's Avatar
Rewards Points: 444
Might not be the best thing to seal it. Artificial turf may require that the soil remain "open" to assist with drainage, though I'm sure the new sub-grade will have a drain system, but keeping the soil loose may help with drainage.
www.gebcon.com
tgeb is offline
Old 12-17-2012, 02:50 PM   #13
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
953 or 963! Get a good operator and all you'll need is an hour or two behind them with a dozer to slick it all up. 12-14" easy for a good guy on a track loader, why mob. 2-3 machines when you can do the work and load with one.
Moxley-Kidwell is offline
Old 12-17-2012, 07:07 PM   #14
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
We are volunteered our trucks at a local club we are members of to help with re-do of a soccer field. They are installing some type of field turf. One guy volunteered to strip the field. He had 2 dozers, loader, excavator & roller.
The loam was thicker than they thought so another guy donated fill. Same guy that stripped loam donated all the stone that was needed. He set up his crushers on a job site he had & crushed huge amount of stone. I was hauling stone today. There were 8-10 contractors that volunteered trucks. I will have to post some pics from this job.
As far as your question. Dozer, loader, roller
Upchuck is offline
finishing flooring decorative strip zmusashi General Discussion 5 10-24-2012 11:02 AM
finishing a decorative strip inlay zmusashi Flooring 3 10-17-2012 07:05 PM
Max Framing nailer - Paper & Plastic Strip? Kastoria Tools & Equipment 3 03-27-2010 06:56 PM
Citi Field, a construction disaster Magnettica Off Topic (Non Trade) 12 09-06-2009 10:12 PM
