Spongey / Springy Earth After Filling In Trench - Excavation & Site Work - Contractor Talk
Old 09-12-2015, 11:36 AM   #1
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 2,678
I know wood. Framing......easy peasy.
Earthworks.........not so much.
A good friend of mine has dug some 24" deep trenches for utility expansion and once inspected, he filled them in. He then used a compacting machine (like a gas-powered pogo stick - I don't know the industry term)
Well, the soil is a mix of clay, rocks sand and top soil. it was wet when it went back in the trench.
Fat forward a week, and he called me today to ask if I knew why the ground he tamped down in the trench area was springy? He says it gives about 1".
I'm thinking that the wet earth is trapped under the dried out top layer, but what do I know.
He's willing to rent the mini ex again and dig it up and add lime or replace it with different medium. Any thoughts/suggestions?
Life - Liberty - Pursuit of Happiness
Freedom is a God-given right
2A is my personal guarantee
wallmaxx is offline
Old 09-12-2015, 01:55 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Spongey / Springy Earth After Filling In Trench
Yes, too wet. The soil should be damp enough to clump together. If it is too wet, it will pump. You'll have to dig it up and try again.
When you dig it up, mix all the soil together and see where you are at with moisture content. You should be able to pick up some soil in your hand and make a clump by squeezing. If you have slimy mud on your hand it is too wet.
When filling back in you should be able to do 12" lifts of soil then compact with a jumping jack. You should be able to stand on a spade shovel after compaction and the shovel only go in about an inch or so if compacted correctly.
CrpntrFrk is offline
The Following User Says Thank You to CrpntrFrk For This Useful Post:
wallmaxx (09-12-2015)
Old 09-12-2015, 06:43 PM   #3
Box Builder
Morning Wood's Avatar
Rewards Points: 10,368
I'd use a plate compactor instead
Morning Wood is offline
Old 09-12-2015, 06:55 PM   #4
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,766
If there is paving going in over this trench he should replace the fill with 5/8minus
jhark123 is offline
Old 09-12-2015, 08:34 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 1,974
We don't usually put native soils back in the ditch.
3/4- in lifts or CDF.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
JDavis21835 (11-26-2015), wallmaxx (09-13-2015)
Old 09-12-2015, 09:54 PM   #6
slowsol's Avatar
Rewards Points: 2,248
Agreed, it was too wet. Depending on the size of the trenches, I'd fill with premium fill. We would use 57's in this area. Essentially small, self compacting stone.
-John
slowsol is offline
Old 09-13-2015, 11:54 AM   #7
Design Build
wallmaxx's Avatar
Thanks for the education.
Y'all are great.
I'll pass this along.
wallmaxx is offline
Old 09-13-2015, 07:12 PM   #8
dayexco's Avatar
Rewards Points: 652
dissimilar soils in an area that has extreme freeze/thaw areas...like here, that does NOT work. your granular/stone backfill, stays put, native soils around it....freeze/expand...leaving a divot every freeze period until the surrounding soils thaw and contract in the spring.
best thing is go by the soils report. adhere to the optimum moisture content in the soil. if what's excavated is too wet? haul it away and go find some very similar soils that are at optimum, or a touch below moisture wise...and compact it in.
dayexco is online now
The Following User Says Thank You to dayexco For This Useful Post:
Old 09-13-2015, 07:22 PM   #9
mattg2448's Avatar
Trade: Excavating
Rewards Points: 390
Sand is our normal back fill material.. depending where it comes from it packs very nicely
mattg2448 is offline
Old 09-14-2015, 04:06 PM   #10
rustyjames's Avatar
Rewards Points: 1,818
Here we typically use what came out of the excavation (without the topsoil) for backfilling. It's compacted in lifts, and lift depth depends on the type of compaction equipment being used. It can be quite expensive, and unnecessary filling an excavation with stone.
rustyjames is offline
Old 11-22-2015, 09:03 PM   #11
Powerjoke's Avatar
Trade: Excavation
Rewards Points: 4
I know it's a bit of an old thread but here it goes anyways, I hate for my first post to sound like I'm arguing with everyone but the mist of it is vibration is your enemy with wet material.
If there's utilities in the trench they'll call for granular or flowable fill most of the times, if there is nothing in the trench and it's still spongy dig it out throw some gabion in it let it jaw together and most importantly if you have wet soil DO NOT VIBRATE it'll just make it worse and worse with every pass,
I've had spots like your talking about start a trench wide and before it's over have to dig it out with loader and waste several loads of 4-6" all because of trying to work wet ground and vibrating.
Pj
Powerjoke is offline
Old 11-24-2015, 04:44 AM   #12
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Where is this at ? On his own property in his yard or on a customers property. If it his own in the yard that will not see any heavy traffic, then just leave it be. It eventually will dry out.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
rustyjames (11-27-2015)
Old 11-24-2015, 07:38 AM   #13
Railman's Avatar
Trade: Railing
Rewards Points: 1,159
It's spongy because air got pumped into the wet dirt, creating a gazzillion litle air pockets in the wet dirt. Eventually, rain pounding will usually work the air out. If not, I'd try a soaker hose.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Fouthgeneration (11-29-2015)
Old 11-26-2015, 01:54 PM   #14
Hierr's Avatar
Trade: Electrical, General Engineering, General Building
Rewards Points: 2
Am I the only one that saw that he backfilled it with one 24" lift of wet material and then hit it with a Wacker and said all good.
Better check the Geotech report and import some engineered fill. Anybody seen my 320 with the Sheepsfoot roller.
/Sarcasm off. Sorry gonna have to dig it back up. Be careful if it's direct buried. Be careful if its in pipe/conduit. Now spread out the material and let it dry out some, then backfill it in about 6" layers (Lifts) max, compact with the wacker, another lift, compact, etc. You need to have some moisture to get compaction, but without getting a tester to come take some samples and cook em to figure out optimum you can get it better than it is now. Now I wouldn't build a structure over it without getting the compaction tested.
Hierr is offline
Old 11-26-2015, 06:30 PM   #15
dayexco's Avatar
Rewards Points: 652
Right soils, 95℅ standard density is easily attainable with ex mounted sheepsfoot or vibe plate.
Sent from my CMP749 using Tapatalk
Old 11-28-2015, 08:29 PM   #16
dayexco's Avatar
Rewards Points: 652
I should have added to post "24 inch" lifts
Old 12-10-2015, 10:44 AM   #17
AndyStandy's Avatar
Trade: Excavation & Site Work
Rewards Points: 2
Also worth noting - if you are backfilling with native material, don't let any organic material get mixed into your pile you are excavating - put it to the side, otherwise if it ends up back in your trench you will have issues from the start - if the material coming out is wet, spread it out and let it dry out. If you are paving over it, import an engineered fill.
AndyStandy is offline
Filling Holes in PT ? We Fix Houses Decks & Fencing 29 02-24-2013 01:59 PM
Compressed Earth Block Construction Jaws Construction 12 02-07-2013 03:33 PM
UFO found on Google Earth Leo G Off Topic (Non Trade) 19 09-19-2010 08:49 PM
Trench Drains sbcontracting Concrete & Paving 7 06-21-2010 09:21 PM
Trench permitting Upchuck Excavation & Site Work 2 04-22-2009 08:20 PM
