Sinking Septic Tank? - Excavation & Site Work - Contractor Talk
Old 06-06-2015, 12:33 AM   #1
bordercollie050's Avatar
Trade: house rehab
Rewards Points: 8
Got a call from someone a few days ago who said their septic tank has sunk down a few inches after being installed by someone else and they wanted to know what their options were.
Anyone know how this can be prevented, the water level here is kind of high now so soil conditions are definitely a factor
thanks!
bordercollie050 is offline
Old 06-06-2015, 09:18 PM   #2
Box Builder
Morning Wood's Avatar
Rewards Points: 10,276
Re: Sinking Septic Tank?
Get it inspected and make sure the piping is still intact.
Morning Wood is offline
Old 06-06-2015, 11:57 PM   #3
dayexco's Avatar
Rewards Points: 530
Tank itself settled, or soil on top of it?
dayexco is online now
The Following User Says Thank You to dayexco For This Useful Post:
SmallTownGuy (06-09-2015)
Old 06-06-2015, 11:58 PM   #4
dayexco's Avatar
Rewards Points: 530
High water table, empty septic tank = submarine
Old 06-07-2015, 11:06 AM   #5
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Quite possibly the previous installer over-excavated the hole and backfilled with soil that wasn't suitable or compacted causing settlement. This is just a theory. If correct, then you will have to dig down along side and set-up a sump to pump from. Dig around the tank. Have it pumped out. Have the manufacturer lift the tank back out with the boom truck. Dig out unsuitable material and replace with structural fill and compact. Replace tank and plumbing.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
mikeswoods (06-07-2015)
Old 06-07-2015, 11:11 AM   #6
GettingBy's Avatar
Rewards Points: 6,486
In principle,
you could pour a slab on the soil surface with the tank in the middle and fasten the tank walls to the slab. Then the downward force is spread out over the slab.
GettingBy is offline
Old 06-07-2015, 11:51 AM   #7
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
We always set tanks on 6" stone base. Sometimes the ground on the side of the tank will settle after a heavy rain. That might be what people are seeing and thinking everything settled. Opening tank and shooting some grades compared to as built plan or exposing inlet and outlet pipes is where I would start.
Upchuck is offline
Old 06-07-2015, 06:56 PM   #8
JDEERE's Avatar
Trade: Sitework
Rewards Points: 148
I agree. I have installed over 1,000 septic tanks and I can't ever remember one sinking. I have had a few float up, but never down.
JDEERE is offline
The Following User Says Thank You to JDEERE For This Useful Post:
muskoka guy (06-07-2015)
Old 06-07-2015, 07:41 PM   #9
GettingBy's Avatar
Which means that the weight of the tank plus contents
was less than the weight of the soil/water it displaced.
I'm not a civil engineer but I'd think these things should be routinely anchored somehow
such that a varying water table wouldn't raise or lower it, even over years.
The Following User Says Thank You to GettingBy For This Useful Post:
raldous (12-01-2016)
Old 06-07-2015, 07:46 PM   #10
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
Why don't they call whoever installed the tank. Why would they call someone who doesn't do septic tanks or have any knowledge about such things.
muskoka guy is offline
Old 06-07-2015, 07:48 PM   #11
JDEERE's Avatar
Trade: Sitework
Rewards Points: 148
When they are used (full) they never float up, only when empty and usually when they haven't been completely backfilled.
JDEERE is offline
Old 06-08-2015, 06:17 PM   #12
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
I've only seen one pop up when I was a kid. Put it in one day. Next day it was up 6". Crazy wet site.
Upchuck is offline
Old 06-09-2015, 03:43 PM   #13
Vagitarian
rino1494's Avatar
I had a 8,000lb tank pop up on me. Supplier set it in the ground, backfilled it. It was late in the day. That night we got huge rains and the tank lifted about 6". Had to dig around it and the supplier came back and lifted it back out for us. Had to scoop out the muck and place stone. After that, we never leave the job without having at least half the tank full of water.
rino1494 is offline
Old 09-08-2015, 11:12 AM   #14
markandrews's Avatar
Trade: Landscaping
Rewards Points: 4
I've not done installations myself, but have seen quite a few. I've also only seen them float...
markandrews is offline
Old 09-12-2015, 11:22 AM   #15
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,381
Over dig = settlement =broken or up hill sewer/septic lines.
Plastic septic easily float even large concrete tanks can float, especially in liquidized soil at 120+lbs/cubic foot.
Fill the tank the same day as it is covered, no worries. If you ever pump clean a septic tank, refill ASAP with water....
Document the lack of rock under the tank for the sue fest.
Use rock fill compacted everywhere soil is remove under the plumbing and tanks.
I recommend to install a field tile as close as legally possible to ensure the septic field and the cover over and around the system doesn't ever become supersaturated.
Soon it will be unheard of to pay tens of thousands of dollars for something without photographic records.... Check invoices for tons/yards of fill rock....
Septic tanks are ALMOST idiot proof.:laugh
Fouthgeneration is offline
Air pump on pressure tank? bob_cntrctr Plumbing 15 10-23-2012 08:17 AM
weird water heater tank connection?... BuenaHomes Plumbing 28 10-02-2012 04:33 PM
Addition built on top of septic tank KevinA General Discussion 20 04-02-2009 07:16 PM
finding a septic tank mikeybobo Plumbing 9 01-07-2009 01:29 AM
Septic tank install help metzade Plumbing 6 09-26-2008 08:47 PM
