Replacing Foundation With No Footer - Excavation & Site Work - Contractor Talk
Old 07-14-2020, 07:20 AM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,198
I have a very tiny house (288 sq ft) that I'm rebuilding and the foundation was 6" block laid above the frost line with no footers. I'm rebuilding the foundation and raising it up a block or two.
If I lay 5 courses of block, the original excavation on one end is about 8"-10" too deep for a standard footer. Should I just make the footer extra thick in this area?
I would lay 6 blocks and go deeper all around but that would probably mean that my footer drain to daylight would be running too deep...
dielectricunion is offline
Old 07-16-2020, 08:58 AM   #2
1 on 2
Ed Corrigan's Avatar
Trade: Mason
Rewards Points: 4
Re: Replacing Foundation With No Footer
If I'm following you right, yes you can make footer thicker at the one end. The bottom of footer wants to be level and then step up to next elevation of bottom of footer. Top of footer is then level all the way around.
Ed Corrigan is offline
Old 07-30-2020, 04:07 PM   #3
1 on 2
Trade: Mason
Rewards Points: 4
Soo... How'd that turn out?
