Parking 30000# Track Loader In Shop - Excavation & Site Work - Contractor Talk
Old 05-02-2015, 11:56 PM   #1
txgencon's Avatar
Rewards Points: 450
With regards to the structural integrity of the concrete foundation of my shop, will I have any issues with bringing my 30000# track loader inside my shop?
(Yes it will fit through the door.)
I figure that there are 2,736 sq in of track on the ground. That figures out to about 11 psi. Obviously, that weight is not exactly evenly distributed over that 2,736 sq in.
Just wondering.....
Am I worried about nothing?
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 05-03-2015, 12:08 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 746
Re: Parking 30000# Track Loader In Shop
You referring to the slab?
Any idea how it was built? rebar, mix, thickness?
griz is online now
Old 05-03-2015, 12:37 AM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 746
I don't believe you have 2736 sq inches of track on the ground.
This would assume the track is flat, however the ribs on the track provide a point load rather than dispersed.
Guys I know that pull track laying equipment on to a slab use 1" thick livestock mats or 1-1/8" plywood under the tracks to prevent damaging the slab.
griz is online now
EthanB (05-03-2015)
Old 05-03-2015, 04:42 AM   #4
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
try it report back with the outcome
pappagor is offline
Old 05-03-2015, 09:03 AM   #5
txgencon's Avatar
Rewards Points: 450
Thinking of building an 8' X 16' mat with 8 sheets (two layers) of 23/32" T&G OSB to distribute the load better (and pinning it to the floor so it won't walk out from under the loader when entering/exiting). Of more concern is the total dead weight on that portion of the slab. It is sort of on the corner of the slab. My shop is still in the design stage. Since I don't want to drive on flatwork, I've created this entrance that can be accessed without having to cross the driveway entrances. I haven't turned it over to the foundation engineer yet. I'm sure I'll get some feedback from him. Just trying to make sure I don't have to do a complete redesign because of this special requirement.
txgencon is offline
Old 05-03-2015, 10:41 AM   #6
duburban's Avatar
Trade: building
Rewards Points: 1,776
this is a great engineering question. let us know what the man says.
duburban is online now
Old 05-03-2015, 10:58 AM   #7
diplomat
Golden view's Avatar
Rewards Points: 734
To me it seems like nothing for a properly constructed slab, except I'd worry about surface damage.
Golden view is offline
Old 05-03-2015, 11:56 AM   #8
burntside bob's Avatar
Trade: excavating
Rewards Points: 95
I put my 15 ton excavator in my shop twice a year.
cement floor 4 inch thick, thicker at door footing area.
I use rubber conveyor belt under tracks.
when I built I compacted really good the gravel under the slab, so It has not broken up under the weight.
burntside bob is offline
Old 05-03-2015, 12:05 PM   #9
GettingBy's Avatar
Rewards Points: 6,486
How important is it to bring this into the shop?
If you do bring it in and the slab cracks, how many kilobucks is that?
GettingBy is offline
Old 05-03-2015, 01:19 PM   #10
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
Pour a 6-8" slab, we bring every piece we have in the shop every year. Never had a problem other than just surface damage. Cat 953, 963's, Jd 755's and 50-60k excavators when we had them. Our 200's are 42-45k and no problems. Even if you only want the slab thicker in that area a couple inches of concrete should only be a few bucks more per sy.
Moxley-Kidwell is offline
Old 05-03-2015, 01:21 PM   #11
dayexco's Avatar
Rewards Points: 20
Griz he easily has 2700 square inches on the ground
dayexco is offline
Old 05-03-2015, 01:54 PM   #12
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
We have an 8" slab with wire mesh and we bring out 45,000 lb track loader in with no problem.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
tgeb (05-05-2015)
Old 05-03-2015, 02:31 PM   #13
dayexco's Avatar
Rewards Points: 20
Yeah rino. ..you're only talking about 4 psi
dayexco is offline
Old 05-03-2015, 04:34 PM   #14
diplomat
Rewards Points: 734
I missed the point about the shop not yet being built. That load is well within the realm of easy to design and little to no additional expense to build.
I had a 15,000 pound water tank in the corner of a garage. Engineer said nothing additional needed. Slab was 4" with #4 rebar 2' OC.
Old 05-03-2015, 04:43 PM   #15
Gnella's Avatar
Trade: site work/paving
Rewards Points: 89
We have an 8 inch slab with wire mesh and rebar. We bring our 23 ton excavator in with no problem. I sealed ours with 2 coats of concrete sealer. Not sure if it made a difference.
Gnella is offline
Old 05-03-2015, 07:01 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 746
I will certainly defer to you almighty dirt guys who make a living with that iron....
I'd be happy to discuss it with you over Bourbon on the rocks in Medford...
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
dayexco (05-03-2015), tgeb (05-05-2015)
Old 05-03-2015, 11:30 PM   #17
dayexco's Avatar
Rewards Points: 20
wife and i will be in the area again i'm guessing late june/early july...
would love to take you and mrs. out for dinner!
bourbon? you're the MAN!!!
jim beam...
know what's great about jim beam? when you hit the brakes, the bottle doesn't come rolling out under your feet.
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
griz (05-05-2015)
Old 05-04-2015, 12:27 PM   #18
GettingBy's Avatar
I'm sure that was the major design constraint for their bottles.
And you will have to hit the brakes if these pedestrians insist on walking on the sidewalk.
BTW,
http://www.google.com/search?client=...UTF-8&oe=UTF-8
You are in good company, sins will be forgiven, etc., etc..
Old 05-05-2015, 09:37 PM   #19
tgeb's Avatar
Rewards Points: 460
BTW,
Come on G... that's a little out of line and way off topic......
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
griz (05-05-2015)
Old 05-06-2015, 06:41 AM   #20
Vagitarian
rino1494's Avatar
Just wondering.....
You are off on your figuring. On concrete, the weight is distributed through the grouser bar, not the pads.
rino1494 is offline
Compact track loader for concrete business mcgconcrete Tools & Equipment 2 09-28-2012 01:25 PM
Setting Up a Shop GRB Tools & Equipment 42 08-05-2012 10:19 PM
New toy for the shop.... TBFGhost Tools & Equipment 11 07-10-2012 07:33 AM
Shop Vac Recommendations dannyboysemail Construction 21 09-02-2009 06:15 PM
