Mini Excavator Help - Excavation & Site Work - Contractor Talk
Mini Excavator Help
Old 10-02-2012, 08:44 PM   #1
jakejorgenson's Avatar
Trade: GC/Carpentry
Rewards Points: 107
Mini Excavator Help
Rented a mini today to do an electrical trench for a job we are doing out in the boonies. Have to dig up 800 ft of trench at 3 ft deep for the main line from the nearest location. Got about 120 ft done today. Super slow going as the ground is sort of a packed clay that once you break it up is more like sand. There is a layer about a foot thick from 6" deep to about 18 deep that is super compacted and hard until it breaks. The mini was not even making a dent in this stuff. I had to hit it with the teeth on the bucket over and over until it would finally "pop" and then go about a foot. I was getting really bounced around and the machine was just standing up instead of digging into the materials. It was a kx41-3v kubota with 18" bucket. Will a larger machine make much difference. They are telling me they have one 2 sizes up (about 10k lbs) that would make this no problem. Thoughts? Will I have issues with that much weight behind my 2500 dodge cummins up or down a highway with some pretty large elevation change?
jakejorgenson is offline
Old 10-02-2012, 09:11 PM   #2
Sar-Con's Avatar
Trade: Civil Construction, Excavation, Concrete + Forming
Rewards Points: 504
Re: Mini Excavator Help
Don't send a boy in to do a man's job.....Mini's are great for small, tight sites but you'll kill yourself on a production job. I assume this is a direct bury application? A trencher would've had that licked in under a day.
Sar-Con is offline
The Following User Says Thank You to Sar-Con For This Useful Post:
griz (10-02-2012)
Old 10-02-2012, 09:16 PM   #3
Trade: GC/Carpentry
Rewards Points: 107
We had a trencher set up and the rental place went out of business literally yesterday and we didn't know until we showed up at the door this morning to get it. We had to drive an added hour (30 min each way) just to get something.
Old 10-02-2012, 09:17 PM   #4
Trade: GC/Carpentry
Rewards Points: 107
Will a trencher go through that hard pan soil set at 3 ft depth on a skid steer?
Old 10-02-2012, 10:04 PM   #5
Sar-Con's Avatar
Rewards Points: 504
I was thinking of something a little bigger than a skid steer attachement. I'm sure it would work but you might find that slow going too. Hard to say for sure without seeing the soil, access, etc.
Sar-Con is offline
Old 10-02-2012, 10:50 PM   #6
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,522
Second the trencher..or maybe just hire a trenching sub...they could slam that footage out quick and be gone...freeing you up to do the electrical portion. A lot of our trenchers charge by the foot...
overanalyze is online now
Old 10-02-2012, 10:59 PM   #7
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
Slighlty bigger machine and a smaller bucket.
wyoming 1 is offline
The Following User Says Thank You to wyoming 1 For This Useful Post:
tgeb (10-03-2012)
Old 10-02-2012, 11:00 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 2,164
18" bucket....
Try a 12" or a 9"...
I would sub it out to a dirt guy....
griz is online now
CanDoExcavating (10-02-2012)
Old 10-02-2012, 11:18 PM   #9
MikeyJP1980's Avatar
Rewards Points: 75
Your machine is too small for the task at hand. Seldom will any contractor in the excavating business have a machine that small. Shallow plumbing lines could be the only thing that machine is good for. There is an art to trenching with an excavator at a productive rate. 10k lb. machine would do the job in a reasonable time. Trenchers would not work in my area at 3’ depth. Main problem is kubota’s are for farmers.
MikeyJP1980 is offline
Old 10-03-2012, 04:53 AM   #10
tgeb's Avatar
Rewards Points: 966
I agree with the above, larger machine, smaller bucket will help.
A typical chain trencher is no good for any pipe greater than 3" diameter or more, unless you get one with a six inch wide chain...which is rare to see.
www.gebcon.com
tgeb is online now
Old 10-03-2012, 10:28 PM   #11
wellbuilt home's Avatar
Trade: ,additions ,kitchens baths house reno
Rewards Points: 168
I have a bob cat 435 11500lbs with a 12" bucket and good teeth.
I can dig 800 ' in a long day. In tough hard rocky soil .
Ive been runing a lot of gas line and conduit the last few years .
wellbuilt home is offline
Old 10-04-2012, 06:34 AM   #12
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Go with a bigger machine and smaller bucket as others have said. Trenchers around here never work, too much rock. I had an 8k lb mini-ex and i could do 800' in a day unless it was all riverbed conditions. But decent soil or sand was no issue for 800' in a day. Never played with clay much but certainly have hardpan, bigger is better. Hiring this out may be the better option too, just pad the bill so you make money too.
Sometimes you think you are making all this money running the equipment yourself but if you step back and let someone else do it and still make money off them you could be actually making more money by getting the job done much faster, its not like you will be standing around waiting on him, for 800' thats a lot of wire to roll out and sleeve if you are using conduit. I sleeve everything and that often takes longer than the digging so once they start digging i run out my wire, start sleeving it, once they are done i drop in as much sleeved wire as possible so they can begin backfilling, then i go back to sleeving, once finished i drop in the rest and go to work attaching the ends.
woodchuck2 is offline
Old 10-04-2012, 08:14 PM   #13
Trade: GC/Carpentry
Rewards Points: 107
Found a guy nearby to do it with a 19k lb backhoe. No issues and digging right through it. He should finish in the morning. Sounds like I just had way too small of machine.
The Following User Says Thank You to jakejorgenson For This Useful Post:
tgeb (10-04-2012)
Mini Ex size rino1494 Excavation & Site Work 24 07-29-2012 05:56 PM
interested in starting up my own mini excavator/ landscaping company dieseljames Excavation & Site Work 10 01-18-2012 07:25 PM
Ditch Witch SK500 Mini Skid w/attachments arbor pro Contractor Swap 3 04-14-2011 10:52 AM
2 mini skid steers plus lots of attachments for sale arbor pro Contractor Swap 15 03-03-2011 09:37 AM
Mini Van for work?? mnjconstruction Vehicles 16 03-02-2009 01:53 AM
