Locating Buried Electric Line - Excavation & Site Work - Contractor Talk
Old 04-29-2019, 10:32 PM   #1
bdog1234's Avatar
Trade: Contractor
Rewards Points: 335
We always do the digtess / 811. I am talking about a private electric line that the utility company won’t locate.
We have some work to do in an area where an electric line for the homeowner’s waterwell is buried - somewhere. Due to the layout of the house, driveway, etc it is really hard to guess which way it is run.
I am guessing the waterline and electric run in the same trench so I really want to avoid hitting them and making a big mess. Is there anyway to find these?
bdog1234 is offline
Old 04-29-2019, 10:46 PM   #2
Not a people person
Chris Doom's Avatar
Trade: Remodel/landscaping/irrigation
Rewards Points: 295
Re: Locating Buried Electric Line
If you have an Irrigation supply house around you they may have one of these you can borrow, it's called a valve locator, also called a wire tracer. technically it's called a null detector. You attach the red lead to one end of the un-energized wire and the black lead to a good ground, dial up a good current into the red lead and you can follow the wire underground anywhere by where the sound "isn't" in your headphones and on your meter on your handheld.
If you want any tips on how to use it. I have 25+years with those, you can call me, I'm a master with those.
https://www.google.com/url?sa=t&rct=...qmxxJpf_5CW8Rz
Chris Doom is offline
The Following 3 Users Say Thank You to Chris Doom For This Useful Post:
bdog1234 (04-30-2019), Fouthgeneration (05-05-2019), Seven-Delta-FortyOne (04-30-2019)
Old 04-30-2019, 08:40 AM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,576
Don't assume that.
I did an addition in a rural area, and there was a trench for the water, a few feet over a trench for the power, a trench for the sewer, and in a long sweeping curve that I've never been able to figure out, a different trench for the fire suppression water. Even though it ran the EXACT same place as the sewer.
Those locators are pretty good. You can usually hire an outfit that has them. There are some where they can put a wire into a water line, and trace those out as well.
Another option is to uncover the pipe where it leave's the well house, and see which way it goes. Do the same at the residence, and you "might" have an idea of how it runs.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
dayexco (05-01-2019), mrcat (04-30-2019)
Old 04-30-2019, 03:25 PM   #4
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 404
Originally Posted by Seven-Delta-FortyOne View Post
Don't assume that.
"Might" is an understatement lol.
I put up a garage for my mom last spring, didn't think there was any way we would hit the underground electric, even cheated the garage away from the house a little bit just in case.
Well I cheated it right on top of the electric, drilled right through it on the second post hole
The line took a long sweeping turn for no apparent reason still can't figure out why it was out that far.
mrcat is offline
The Following User Says Thank You to mrcat For This Useful Post:
Old 04-30-2019, 04:47 PM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Are you new to this or something? Long sweeping turns allow the electrons to flow easier.
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
mrcat (04-30-2019), sunkist (05-01-2019)
Old 04-30-2019, 05:35 PM   #6
mrcat's Avatar
Rewards Points: 404
Well I didn't think it had to be THAT long and sweeping for ease of electron flowage.
mrcat is offline
B.Johnson (05-01-2019)
Old 05-01-2019, 07:04 AM   #7
General Contractor
greg24k's Avatar
Rewards Points: 8,652
I use all fashion way 2 bent copper wires to locate anything, electric, water, sewer, gas... never fails works better than the trace tools utility company use. Tested 100 times against them, never failed.
For the newer installations, they are more accurate because now you have an attached trace-wire along the run... but older installations they always off.
Just a few months ago I was doing an estimate and the guys next door were trying to repair a sewer line, the guy was spot digging trying to find the pipe which had a bend in it to avoid the cleanout in the driveway. When I got there I walked into the house they were already looking for it when I was leaving about 30 min later they still spot digging... So I took the wires I have in my truck and outlined the whole sewer run for them and I left.
I ran into excavation guy about a week ago in a plumbing supply store and he gave me $10 said the coffee on me because I saved them a lot of time and grief.
This is an old trick I learned from an old timer excavation guy he said this trick never failed him and me also.
Good luck
P.S Someone made a video about that
greg24k is offline
The Following 8 Users Say Thank You to greg24k For This Useful Post:
dayexco (05-01-2019), Fouthgeneration (05-05-2019), mrcat (05-01-2019), overanalyze (05-08-2019), Rio (05-01-2019), SouthonBeach (05-02-2019), TimNJ (05-05-2019), Tom M (05-05-2019)
Old 05-01-2019, 03:56 PM   #8
dayexco's Avatar
Rewards Points: 636
Between being on my own and working for my dad, that amounts to over 50 years in the excavating business.
Witching is like calling California psychic
Sent from my SCH-I545 using Tapatalk
dayexco is offline
The Following 3 Users Say Thank You to dayexco For This Useful Post:
Inner10 (05-12-2019), Rio (05-03-2019), tgeb (05-01-2019)
Old 05-01-2019, 04:15 PM   #9
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,638
..........The line took a long sweeping turn for no apparent reason still can't figure out why it was out that far.
99 out of 100 times, it's due to a pile of dirt or lumber or someone's truck that won't start in the way when the guy with the trencher shows up.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following 3 Users Say Thank You to 480sparky For This Useful Post:
Fouthgeneration (05-05-2019), mrcat (05-01-2019), Rio (05-03-2019)
Old 05-01-2019, 05:06 PM   #10
tgeb's Avatar
Rewards Points: 848
I've seen guys do it but, I don't trust in it.
I've never had any luck trying it, I must have too much negative energy.
The Seektech SR-20 works pretty darn well though.
www.gebcon.com
tgeb is online now
Old 05-01-2019, 06:13 PM   #11
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Only when it goes into the house, does not work if you want to sell power back to the grid
Still "Shakin" the tree boss
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
Old 05-01-2019, 06:56 PM   #12
480sparky's Avatar
That's half true. When the AC cycle changes the next 1/120th of a second, it's false.
Old 05-01-2019, 09:03 PM   #13
Not a people person
Chris Doom's Avatar
Rewards Points: 295
lol
The Following User Says Thank You to Chris Doom For This Useful Post:
tgeb (05-03-2019)
Old 05-02-2019, 02:51 AM   #14
builditguy's Avatar
Rewards Points: 2,072
I can witch water, but not electricity. Probably a genetic deficiency.
I did one last month with a metal detector. It was aluminum wire leading to an out building. Was able to find the wire with no problem and even tell how far underground it was.
One place it was only 1" deep.
builditguy is offline
Old 05-03-2019, 12:13 AM   #15
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Good luck
https://www.youtube.com/watch?v=AW_xDXDtDmc
I bet you believe in the Easter Bunny too...
Inner10 is offline
Old 05-03-2019, 02:56 AM   #16
General Contractor
greg24k's Avatar
Don't bet, might lose a shirt
greg24k is offline
Old 05-03-2019, 05:51 AM   #17
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 302
Witching = random chance.
rjconstructs is offline
Old 05-03-2019, 08:02 AM   #18
tjbnwi's Avatar
Rewards Points: 3,986
Just start digging, you'll find the line where you least expect it.
tjbnwi is online now
mrcat (05-03-2019), SouthonBeach (05-03-2019)
Old 05-03-2019, 09:35 AM   #19
General Contractor
greg24k's Avatar
They give you a mark-out based on within 2' of the line on each side.
So you have a 4' path where utility should be located.
You hit something within the 4' it's on you, you hit something on the outside of the 4' it's on them. That's the rule for the entire country I think.
I use the wires to double check and never been wrong.
The trick is to hold the wires the right way and apply the right amount of pressure yet allowing them to move freely.
Happy digging
greg24k is offline
Old 05-03-2019, 10:32 AM   #20
480sparky's Avatar
You hit something within the 4' it's on you, you hit something on the outside of the 4' it's on them. That's the rule for the entire country I think.........:
18" and 36".
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
greg24k (05-03-2019), overanalyze (05-08-2019)
Basement Wall Construction at Property Line PDX General Discussion 17 09-05-2017 10:17 AM
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 02:41 PM
electric wh malfunction boman47k Plumbing 3 01-13-2009 02:25 PM
