Hydraulic Hammer Productivity Breaking Concrete Footings - Excavation & Site Work - Contractor Talk
Old 06-10-2014, 02:02 PM   #1
burntside bob's Avatar
Trade: excavating
Rewards Points: 95
Any one have data on how much lineal feet one gets breaking concrete footings with a hyd hammer.
I mean the number of feet an hour.
Footing is one foot wide three feet tall; do not know if it has rebar in it.
Mini Excavator 12,000 machine Kubota 161.
Rental hammer looking at is Atlas Copco SBU220 weights 500 lbs. with
Energy Impact Class 550 (ft-lbs).
Could use the expanding grout to break it up, drill it pour in the grout let it set, but I think the hammer would be a lot faster.
burntside bob is offline
Old 06-10-2014, 03:36 PM   #2
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
Re: Hydraulic Hammer Productivity Breaking Concrete Footings
Get a larger machine and just dig it out. Breaking it out would work. But very slow. It would be much easier to excavate it then break it on the 12" dimension. With a larger machine you can break up the pieces much faster by lifting and dropping the pieces
HUI is offline
Old 06-10-2014, 03:40 PM   #3
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,766
I've got to agree, I big machine is much better for this task. Those hammers are expensive to rent. I bet you could bring in a sub with a 160 for not much more $
jhark123 is offline
Old 06-10-2014, 09:02 PM   #4
Trade: excavating
Rewards Points: 95
The concrete was poured on top of ledge rock, probably not able to break it free with my 312 hoe.
Old 06-10-2014, 09:23 PM   #5
HUI's Avatar
Rewards Points: 178
It will be difficult to break concrete 12" wide for the full depth. If you can excavate next to the footing and break horizontal would have better success but it is hard on the breaker and machine.
HUI is offline
Old 06-10-2014, 09:26 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 10,350
If it's poured on ledge than it's probably pinned with rebar to the ledge and anything that big should have rebar in it anyway. It's going to be slow going with a mini ex.
Morning Wood is offline
Old 06-11-2014, 06:02 PM   #7
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
Seems like it would take a ton of time to remove with a mini. Can you get a 160 or 200 size hoe just to get it to a pile then you could even use a skid steer with hammer to break it down. If I put one of our 200's on it I think you could at least get it down in bigger chunks to another machine.
Moxley-Kidwell is offline
Old 06-11-2014, 06:44 PM   #8
jhark123's Avatar
If you had to use small machines you could put a hammer on a big bobcat and move the chunks with the mini.
jhark123 is offline
Old 06-11-2014, 08:09 PM   #9
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
No data, but if I were bidding it, I would shoot from the hip. How many linear feet are we talking about ? If is it a large quanity, I would look at getting a bigger machine. The cost for rental is not much more and the speed of breaking will be 10 fold. We have a NPK hammer on our Cat 315. It is a 3,000 ft/lb hammer and we do alot of breaking with it. We also have a hammer our on Case 590 backhoe which is about the size of the one you are looking at renting. The bigger hammer will simply destroy the smaller hammer in production. When hammering, bigger is better.
rino1494 is offline
Old 06-13-2014, 09:46 PM   #10
Trade: excavating
Rewards Points: 95
The lineal feet is 128 feet.
Old 06-15-2014, 07:50 AM   #11
operator
peteo's Avatar
Trade: excavating, concrete, landscaping
Rewards Points: 518
A 200 size hoe is a bit overkill in my opinion. A 315 with a hammer should whip that out in about 2-3 hours. I'd break it into 2'-4' chunks and then throw it in a truck. Should be done by lunch time
peteo is offline
Hydraulic Concrete Chain Saw with powerpack Lettusbee Contractor Swap 2 01-12-2015 12:25 AM
Bagged premixed lime mortar for tuckpointing wazez Masonry 158 10-28-2012 07:02 PM
Hydraulic Concrete Chain Saw Setup Lettusbee Contractor Swap 0 10-20-2012 10:39 PM
Uneven Concrete Meets Subfloor Handy Hero Flooring 6 09-30-2012 04:59 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
