How Do You Know When Concrete Was Too Hot To Pour - Page 5 - Excavation & Site Work - Contractor Talk
Old 10-15-2012, 08:38 PM   #81
PipeGuy's Avatar
Trade: underground
Rewards Points: 2,000
Re: How Do You Know When Concrete Was Too Hot To Pour
Originally Posted by Elyrain View Post
...they add water...so they don't get it all stuck in the drum.
It's all about the water. If the amount of water added to the batch in order to keep it usable exceeded the mix design's w/c ratio then it won't produce the specified mix - period. If there's too much water then you didn't install the specified mix.
PipeGuy is offline
Old 10-17-2012, 11:49 PM   #82
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,066
Viscosity ?
Calidecks is offline
Old 11-03-2012, 06:29 PM   #83
jack of all trades
one man show's Avatar
Trade: general
Rewards Points: 75
Blaa Blaaa Blaa
water , ratio, 4500lbs, viscocity, greg 24k is correct again
300 turns of the drum or 1.5 hrs
if they have exceeded those astm specifications send it back ESPECIALLY ON A REQUIRED 4500LB MIX
one man show is offline
Old 11-03-2012, 06:37 PM   #84
GC/carpenter
Calidecks's Avatar
Itz been a month and no sign of problems
Old 11-03-2012, 06:38 PM   #85
GC/carpenter
Calidecks's Avatar
It was 2 hours i think it will be just fine
Old 11-03-2012, 06:45 PM   #86
GC/carpenter
Calidecks's Avatar
Originally Posted by one man show
Blaa Blaaa Blaa
Besides, there is Already a building on it so it would be very difficult to send back now.
How do you know when concrete was too hot to pour-forumrunner_20121103_164454.jpg
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
SmallTownGuy (11-03-2012), tgeb (11-03-2012)
Old 11-03-2012, 08:16 PM   #87
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
[QUOTE=Californiadecks;1619869]Besides, there is Already a building on it so it would be very difficult to send back now.
That's right, the sooner you cubber up de evidence de better...
SmallTownGuy is offline
Old 11-03-2012, 08:58 PM   #88
GC/carpenter
Calidecks's Avatar
Evidence of what? Mud was 2 hours old ?
What do you suppose is going to happen?
I got info from a special inspector that doesn't seem to be too concerned about it. As a matter of fact he said 4500 psi isn't for the load, it for the acidic soil and the 4500 is needed for its density. But the slab has 4 inches of sand and plastic so the concrete isn't even contacting the soil. The footings were poured with the first truck that had no problems.
Old 11-03-2012, 09:18 PM   #89
John the Builder
I don't think ANYTHING bad is gonna happen. In fact, I thought all of this was much ado about nothing.
Here we are, still talking about drum turns & water ratios and the durned building is nearly done!
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Calidecks (11-03-2012)
Old 11-03-2012, 09:49 PM   #90
The Sheriff
Jaws's Avatar
Rewards Points: 13,836
Question
Originally Posted by griz View Post
Depends on the mix design & purpose....
But 60 minutes & back to the plant to wash out & re-batch...
A builder here had a 5,500 sq ft poured an hour and fifteen from the plant in august. Last truck was a 11 am, probably 100 degrees. Had a structural crack that the client sued for, and won.
Not a lesson to forget
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 11-03-2012, 10:01 PM   #91
GC/carpenter
Calidecks's Avatar
That contractor must of had a piss poor lawyer because 90 minutes is acceptable practices, so if it was 75 minutes old he was within acceptable time limits, so something tells me there's more to the story then 75 minute mud.
SmallTownGuy (11-04-2012)
Old 11-03-2012, 10:06 PM   #92
The Sheriff
Jaws's Avatar
Good lawyer, the client was a better one The client was a prominent litigator and a college football star. Story is he told the builder he should of known hed sue for something.
I dont know the whole story, the guy may of set up his slab improperly.
My post had nothing to do with your thread, Im sure your slab is fine.
John
Jaws is online now
Old 11-03-2012, 10:11 PM   #93
GC/carpenter
Calidecks's Avatar
Usually structural cracks are soils related, if its poured on expansive clay and the ground was dry there can be extensive structural cracks, expansive clay can exert as much as 15000 psf. Usually following a rain or irrigation. The way that is solved is to saturate the clay before you pour so the soil is pre expanded. This has to be accompanied by a structural slab that has been engineered with the proper reinforcement.
Old 11-03-2012, 10:15 PM   #94
GC/carpenter
Calidecks's Avatar
Someone brought this post back from the dead, and I was moving forward, now I'm going to trip on it again.
Old 11-03-2012, 11:10 PM   #95
Fire up the BBQ
griz's Avatar
Rewards Points: 678
...Usually structural cracks are soils related.....
May be a contributing factor...but
Mix design as ordered compared to what was delivered...
or how it was placed
Water/Cement ratio
add mixes or lack of
Weather
over worked mix
How was it cured?
when was it saw cut?
I'm sure there's more...but I can't recall any right now
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (11-03-2012), Jaws (11-03-2012)
Old 11-03-2012, 11:35 PM   #96
GC/carpenter
Calidecks's Avatar
Lots of things that go on that we have no control over, like non of us get to see them actually mix it. Other things we can't control is the weather. But your right Griz, many factors when it comes to concrete, most of those factors are above my pay grade. ( like engineering )However, I try to keep up the quality on the things I can control.
griz (11-03-2012), Jaws (11-03-2012), SmallTownGuy (11-04-2012)
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Powder actuated pins in 4500 psi concrete Calidecks Concrete & Paving 10 10-03-2012 05:55 PM
Uneven Concrete Meets Subfloor Handy Hero Flooring 6 09-30-2012 04:59 PM
Pour concrete retaining wall... ruskent Masonry 30 11-03-2009 10:58 PM
Help with concrete bid KennMacMoragh Concrete & Paving 13 08-17-2009 03:50 AM
