HDPE Pipe Vacuum Problems - Excavation & Site Work - Contractor Talk
Old 10-01-2010, 05:31 PM   #1
turfguy13's Avatar
Trade: General Engineering
Hello,
Does anyone have experience with gravity flow water systems using HDPE (10") pipe?? I installed a 3.5 mile long line to bring water down to a golf course. It was to be laid in an existing water ditch (and not excavated). Engineer calculated a 10 inch would get us sufficient water (675 gpm). Seemed to work well the first year or two, but last few years has not been able to flow more than 500 gpm without the pipe collapsing due to vacuum. It seems like the pipe strength has diminished over the years. Pipeline was supposed to be a low pressuree pipe, not a vacuum pipe. Does anyone know what may be causing the problem or have heard of problems with hdpe like this??
Thank You in advance,
Mark
turfguy13 is offline
Old 10-01-2010, 10:30 PM   #2
cexcavation's Avatar
Trade: Excavation Contractor
Rewards Points: 250
Re: HDPE Pipe Vacuum Problems
Sounds like you have some type of restriction at the "head" of your pipe. If input falls short of out put, the water in the pipe will start pulling on the pipe itself. Sort of like breathing in air and then covering half of your mouth with your hand........your cheeks will collapse!!!
That's my guess
cexcavation is offline
Old 10-02-2010, 10:01 AM   #3
turfguy13's Avatar
Thank you. We have pulled the fish screen off and tested without it. It seems to make no difference. We did think that that may have the problem, but it did not test out. We think it has something to do with more friction loss than avaliable head pressure. We did raise the water level in the creek 2 feet (by building a raised dam), and did not see any changes in flow rate. This is puzzling. Thank you for the advice.
Mark
Old 10-02-2010, 03:32 PM   #4
shaper's Avatar
Trade: residential construction
Rewards Points: 12
What thickness is your pipe is it DR9 DR11 DR17? . Are there low areas where the gravity flow actually has to go uphill for short distances?. Any chance of buildup in the pipe such as scale or algae?
shaper is offline
Old 10-02-2010, 04:29 PM   #5
Chuck
S.R.E.'s Avatar
Trade: Excavating, Clearing, Underground Utilities
Rewards Points: 506
This is a very good question. Maybe the engineer specified the wrong thickness.
S.R.E. is offline
Old 10-02-2010, 10:54 PM   #6
Dozerman56's Avatar
Trade: Site Prep
Rewards Points: 31
Interesting question. Since the pipe functioned as desired the first few years, and it was designed to be a low pressure system, not a negative pressure system, it seems your friction losses have become greater than anticipated in recent years. Most likely you're getting buildup of some kind on the interior of your pipe. Or maybe the water has some mildly corrosive properties.
Dozerman56 is offline
Old 10-05-2010, 08:53 PM   #7
PipeGuy's Avatar
Trade: underground
Rewards Points: 2,000
Mark
Another 2 feet of head gets you less than 1 psi additional head pressure - not much there to measure.
Almost all the low pressure DR-11 HDPE sewers I've built have had a dual function air/vacuum air-release valve designed into them. That might be an easy fix for the issue. "Google" Apco, Crispin or Val-Matic.
PipeGuy is offline
Old 10-06-2010, 09:57 AM   #8
turfguy13's Avatar
Thanks for the input all. The pipe is DR 26, and was specified to be low pressure application. I now wish we would have used a much thicker pipe, however the bending of the historic ditch probably would not have accomidated the thicker pipe. We are able to break the pipeline open at every 1000 feet as we installed flanges. We have recently flushed the pipe with approx. 1500gpm to remove any sediment that may have gotten through the fish scree. There deos not seem to be any scale or sediment in the pipe.
Thanks again guys,
I am learning and all comments have been very helpful.
Old 10-06-2010, 08:43 PM   #9
tgeb's Avatar
Rewards Points: 4
Ok I'll throw my nickel in.
HDPE is negatively affected by sunlight, what those affects are I do not know.
However if you suspect that the pipe is being affected by vacuum that reduces the flow, would that also change the profile of the pipe?
Is it possible to monitor the pipe to see if it is collapsing and causing restriction?
I realize you have 3.5 miles of pipe, maybe there is a specific area that would be more prone to damage/subject to vacuum than the rest of the line.
www.gebcon.com
tgeb is online now
Old 01-26-2011, 12:46 PM   #10
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
Being dr 26 I would say is a large portion of the problem. HDPE is not affected by sunlight like PVC is. What are you using to pull the vacuum? Why not push it with a pump instead?
HUI is offline
Considering a Gas Range, need advice on pipe sizing/service size xmptsunami HVAC 4 09-01-2010 06:09 AM
Perforated Pipe for Foundation Drain malatu Masonry 6 05-26-2010 09:46 PM
Drain Pipe denick Excavation & Site Work 18 07-12-2009 03:41 PM
painting pipe fence diesel power Painting & Finish Work 14 09-06-2008 09:37 AM
HDPE pipe mechanical couple bsolar Excavation & Site Work 6 05-01-2008 03:30 PM
