Fusing Pipe Vs Compression Fittings - Excavation & Site Work - Contractor Talk
Old 02-13-2016, 09:10 AM   #1
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
We just started a new subdivision that will require 2" press. sewer pipe. Did same time of job a few years ago and used compression fittings. Wasn't all that impressed with them and debating fusing the pipe this time.
Only problem I see is that we'll be putting in 14 lateral tees in 800' of pipe and it seems to me that production will slow down quite a bit waiting for pipe to cool down after fusing.
Line will have to be air tested so we'll prob. leave any connection exposed so it'll be easier to find if there is a leak.
Just looking for some opinions
Upchuck is offline
Old 02-13-2016, 11:58 PM   #2
Tom M's Avatar
Rewards Points: 5,280
Re: Fusing Pipe Vs Compression Fittings
Maybe Flared ends?
Tom M is online now
raldous (11-30-2016)
Old 02-14-2016, 05:29 PM   #3
JDavis21835's Avatar
Trade: Excavation
Rewards Points: 386
Originally Posted by Tom M View Post
Maybe Flared ends?
By Flared ends are you meaning flanged connections?
JDavis21835 is offline
Old 02-14-2016, 05:38 PM   #4
Trade: Excavation
Rewards Points: 386
Are you looking to butt fusion weld these pipe? If so, I would be concerned about the welds being a catch point, but probably no different than a push joint pipe. As far as testing and leaving fuses exposed, you could probably do a majority of your fabrication above ground, and air test that way. This way you know everything is good. Then do your official test once installed and buried.
As far as cool time, 2 inch pipe, in say 55 degree temperatures, even up in to the 80s, has a realistic cool time of 5-10 minutes. If you have a ton of fab work you can always get a second saddle, and while you are waiting for the first fuse to cool, you can be making the second fuse with the other saddle.
The other option would be electrofusion couplings. While more expensive, they do speed things up a tad. You have to have the fusion box though. It comes with a scraper to prep the pipe, and like the butt fusions, you are supposed to clean the scraped area with rubbing alcohol. Then you slide the electrofusion coupling on to the pieces to be joined, hook up the electrodes, scan the bar code, the box figures air temp for heat and cool time, press the yes button twice, and the box zaps the fitting, heating the metal coils inside the coupling up, melting the hdpe inside the coupling, and you are done.
The Following 2 Users Say Thank You to JDavis21835 For This Useful Post:
raldous (11-30-2016), Upchuck (02-15-2016)
Old 02-14-2016, 06:03 PM   #5
Tom M's Avatar
http://search.aol.com/aol/image?q=fl...t=wscreen50-bb
Tom M is online now
Old 02-14-2016, 06:09 PM   #6
Trade: Excavation
Rewards Points: 386
Im not seeing anything for HDPE which is what I'm assuming is being discussed by the cooling time statement
Old 02-14-2016, 07:11 PM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,001
So you are plumbing the sewers from a swamp up to a lift station?
Won't you be using wye's instead of tees?, maybe a double wye?
The specs don't call out the technology they want used?
No city, county inspectors?
The fused connections would seem to grossly simplify your materials list. and cut waste pipe to single digit percentages.
Take a rainday and go watch someone that knows what they're are doing. Or call the welding machine maker up for some video classes on how to plumb....
Fouthgeneration is offline
Old 02-15-2016, 06:08 PM   #8
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
[QUOTE=JDavis21835;4314305]By Flared ends are you meaning flanged connections?[/QUOTE
I'm talking about fusing plastic pipe. I assume you're talking about flared ends for copper.
Upchuck is offline
Old 02-15-2016, 06:20 PM   #9
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
The houses will have individual pumps tying into 2" pipe discharging into existing manhole.
Plans calls for tees not wyes.
Specs allow for compression fittings (which we've used) or fused connections. Everything is inspected by town so plenty of oversight.
Waste shouldn't be much different since we can use left over pipe sections from tee to treebelt for house connections.
I've seen the gas company fuse pipe multiple times. They usually do 4" mains opposed to 2". It seems like they take more time but they are a utility and production isn't always a concern.
Always looking for different ways to do things and figured someone on this site might have some experience fusing pipe and share the opinions.
Upchuck is offline
Old 02-15-2016, 06:23 PM   #10
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
Thanks. I would be renting a fusion box. I assume you need it for either type of fusing you're describing.
Upchuck is offline
Old 02-15-2016, 10:11 PM   #11
dayexco's Avatar
Rewards Points: 16
would they allow a schedule 80 pvc? SW them all?
dayexco is online now
Old 02-16-2016, 06:26 PM   #12
Trade: Masonry
I'm trying to get my head around 14 sewer lift pumps running into just One 2" "main"? so one back flow valve fails, one house has 17 houses worth of sewage in the basement?
How many houses can run a 2" main before you switch to a 2.5" or 3"?
Old 02-16-2016, 07:25 PM   #13
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
The design shows each house with exterior pump chamber with about 60 gallons reserve. I don't care for that so we will use 1000 gallon precast pump chamber with one backflow preventer in tank and another in tree belt. Also, calls for a shut-off at tree belt.
The way it has been explained to me is that the 2" main is always full and as each house pump works the waste in the line is pushed out. Picture making sausage if you ever seen it done.
Don't know how many more houses before the main would be upsized. We don't design them, just install them.
Upchuck is offline
The Following User Says Thank You to Upchuck For This Useful Post:
Fouthgeneration (02-16-2016)
Old 02-16-2016, 07:30 PM   #14
Box Builder
Morning Wood's Avatar
Rewards Points: 9,986
That is basically how the sewer system works in the city next door to me. Everyone's step pump pressurizes the main line. It's kind of a crappy setup.
Morning Wood is offline
Old 02-16-2016, 07:34 PM   #15
Trade: Masonry
Can you "legally" Siamese any two Units to use a common chamber on the lot lines.... I'm a cheapskate...
I'm getting pretty high flow # at the discharge end of the 2" common pipe.
If its stamped by an engineer, drive on.
Old 02-16-2016, 07:36 PM   #16
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
I'll have to ask. We've done single houses that way. Not sure if would make a difference for multiple houses with low pressure system.
Upchuck is offline
Old 02-16-2016, 08:24 PM   #17
Trade: Excavation
Rewards Points: 386
This is butt fusion equipment
http://www.machinio.com/listings/739...-united-states
This is electro fusion equipment, I assume this is what you mean when you say rent the box.
http://www.centralplastics.com/en_US...c-machine.html
Old 02-23-2016, 05:11 PM   #18
operator
peteo's Avatar
Trade: excavating, concrete, landscaping
Rewards Points: 518
Not a force main expert by any means but the engineering on this sounds suspect. Tees instead of wyes, socket fusions, etc...maybe its just been a long time since I've done sewer work but i was always taught that the flow line needs to be as smooth as possible. I believe socket fusion leaves rough spots at the joints for solids to get hung up on. Like I said, its been a while since I've done sanitary work
peteo is offline
Old 03-06-2016, 09:47 AM   #19
OMB's Avatar
Trade: Building, Excavating
Rewards Points: 142
Always used compression fittings, not to say that is the best way, just what is spec'ed.
Years ago ran into the same situation with a 14 lot subdivision; that setup "homeran" 2" pressure lines from the individual homes' pump 200-800' to a 18" gravity main with check valves. I think we bought 2" in 1000' coils so the only joints were at the terminatations. I remember thinking the gravity line has an issue and the check valve sticks open, it won't be pretty. My solution maybe would be 4" gravity lines from each house to a pump station below the lowest house, 3" force main up to the 18" gravity. Advantages: isolate homes from the pressure line, one big pump vs. 14 little ones. Disadvantage: Some homeowners put things down the drain that even grinder pumps have a problem with, hard to figure out the culprit in a community system.
If you debur properly I don't think you would have a problem with 'hangups'.
OMB is offline
Old 03-08-2016, 12:35 PM   #20
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Very different than whats code here. Always an interesting read.
Here's what we have to do in NYC: (as far as I know anyhow, Im not a master plumber)
cast iron bells' sealed with oakum and lead (when using cast iron below ground)
cannot use hubless on cast iron below ground
Ploypropylene and PVDF piping must use electric fusing/fusion tools. (cant fuse together either)
Lead and oakum is what I see most often for the home to city lines. There's not too many youngin's who know how to do it either.
madmax718 is offline
What is this pipe? AmeliaP Plumbing 1 03-01-2013 06:45 PM
Question about the difference in FIP and Compression fittings... sy85 Plumbing 1 10-18-2011 12:28 PM
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
Question: Stainless Steel Pipe Fittings and Valves jasonltsp Plumbing 0 01-06-2009 02:42 PM
