Foundation Wall Beside Existing Slab - Excavation & Site Work - Contractor Talk
Old 10-18-2018, 11:26 PM   #1
Stunt Carpenter's Avatar
Rewards Points: 1,250
Hey Guy,
I have a garage addition coming up where I need to remove a part of a exposed aggregate patio to add a tandem bay to a garage.
The existing attached garage has 4ft poured concrete walls with the pad poured inside of it
My question is is there any way to pour the new walls tight to a saw cut on the patio so that when I’m finished there isn’t a section of patio missing beside the garage wall?
(If this is in the wrong section feel free to move it)
Stunt Carpenter is offline
Old 10-19-2018, 02:10 AM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,175
Re: Foundation Wall Beside Existing Slab
Layout the "footing edges" on the patio concrete, wet saw full depth, make a second cut 8-12" further in, save the pieces, reinstall on block 'brick'ledge, caulk the new joint, using stainless pin keep the saw cuts level with the un-cut patio SOG...
dig and pour the new footing fast!. use non shrink back fill....bid in at least ONE do over when it settles.
Under promise, everything but COST.
Fouthgeneration is online now
The Following 2 Users Say Thank You to Fouthgeneration For This Useful Post:
Bull Trout (10-19-2018), greg24k (10-19-2018)
Old 10-19-2018, 03:49 PM   #3
tgeb's Avatar
Rewards Points: 48
You would have to do a "Blind Side" foundation.
Essentially, you need to form the inside wall and soil is the outside form. We use bentonite sheet to waterproof the foundation.
The biggest hassle is making sure the form bracing for the inside wall is stout enough hold fast without tie backs to the outside form.
So in short, yes it can be done.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
TheConstruct (10-19-2018)
Old 10-20-2018, 08:12 AM   #4
SouthonBeach's Avatar
Rewards Points: 1,031
How deep and wide do you need to go?
Along what tgeb is talking about the blind side footing. Could you do a “shovel” footing.
Just dig the proper depth and width, pour it full with concrete letting the soil be your “forms”. Then form the walls and pour them as normal on top of it.
SouthonBeach is offline
Old 10-20-2018, 08:53 AM   #5
Thanks guys that’s what I was hopping to hear. I knew it was possible but getting confirmation that I’m not losing my mind is great.
The footing needs to be 4ft down to get below the frost line. The existing wall is 8inches thick so I would match that to make it uniform.
Old 10-20-2018, 12:44 PM   #6
Trade: Masonry
By far easier, would be cutting away the SOG above the toe of the footing and replacing it with other material as transition/border, like brick/CMU pavers or new crete with an colored mix?.
Or using the demoed washed finished old crete cut up as large 'paving stones' laid in sand. like the first post less the caulk and pins, and the pieces sawed into common lengths...
As a practical matter, you can't easily stand on the last 4" of slab that abuts a sided garage wall anyway....
Tall Residential Concrete Foundation Wall Question John 1979 Masonry 8 12-11-2016 03:19 PM
sealing leaking retaining wall poured on grade slab nwksremodeler Concrete & Paving 13 09-04-2014 07:22 PM
Mason foundation out of square with existing house jebeltra Masonry 16 08-01-2014 06:39 PM
can any one id this wall sensor HUDSONVALLEYEXT General Discussion 8 06-15-2012 07:20 AM
Concrete overlay over existing garage slab daft_GC Concrete & Paving 10 11-19-2009 08:42 AM
