Found An Underground Stream While Digging A Garage Pad Today. What To Do? - Excavation & Site Work - Contractor Talk
Old 01-15-2019, 12:20 AM   #1
Sam @ PWE's Avatar
Rewards Points: 62
Hey guys,
Customer of mine is planning to put up a garage in the next few months. He asked me to level out a 40x40 area to get it prepped...easy enough.
I showed up today with a skid steer and got to work stripping the sod off. As soon I got through the sod I made a 90* turn and sank the skid to it's belly . The mud got worse and worse and thankfully I was able to tow the machine out with my pickup. While trying to dig myself out I dug down with the bucket realized there was water flowing through the ground about 18" below grade. It's been dry here for a few days so something tells me this underground stream will continue until it really dries up this summer. Customer's yard now looks like a war zone because I was only able to dig about 1/3rd of the pad before it was too soupy to work in. From what I can tell this underground stream seems to run right through the middle of the future garage.
Do you guys have any ideas on what to do here? He's talking about moving the garage over about 10 feet, but that'll still put part of the garage in the wet area. I'm thinking of dumping some drain rock in the mud to firm it up so I can finish grading - but I'm not sure if that's going to be solid enough to build on. I might try to consult with a civil engineer, but I know my customer wouldn't like that extra expense. The customer wants to keep the job cheap, but I want to make sure it's done right and I definitely need to fix this quagmire sooner than later.
Last thought: I'm tearing out a concrete driveway at another job this week and it crossed my mind to throw some broken up concrete in the mix to firm things up. While I know that would do the job for me, I seriously doubt it would be okay to build on.
Any help is appreciated! I didn't take any pictures because it currently looks like hell.
Sam @ PWE is offline
The Following User Says Thank You to Sam @ PWE For This Useful Post:
cedarboarder (01-15-2019)
Old 01-15-2019, 01:04 AM   #2
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,723
Re: Found An Underground Stream While Digging A Garage Pad Today. What To Do?
Hire an engineer
Jay hole is offline
The Following 6 Users Say Thank You to Jay hole For This Useful Post:
griz (01-15-2019), jhark123 (01-15-2019), KAP (01-15-2019), Rio (01-15-2019), tgeb (01-15-2019), TheConstruct (01-16-2019)
Old 01-15-2019, 01:25 AM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,300
This will be an expensive fix.
For liability reasons you need an engineer and likely a soils report.
Your contract cover unknown/unforseens.
Get out while you can if the owner doesn't want to do it right.
griz is online now
The Following 11 Users Say Thank You to griz For This Useful Post:
dayexco (01-15-2019), hdavis (01-15-2019), jhark123 (01-15-2019), KAP (01-15-2019), onmywayup (01-15-2019), overanalyze (01-15-2019), Rio (01-15-2019), Sam @ PWE (01-15-2019), Seven-Delta-FortyOne (01-15-2019), tgeb (01-15-2019), TheConstruct (01-16-2019)
Old 01-15-2019, 07:08 AM   #4
builditguy's Avatar
Rewards Points: 2,126
This is the right path.
builditguy is online now
Old 01-15-2019, 07:15 AM   #5
TimNJ's Avatar
Rewards Points: 6,838
Trench it where the water is and lay some perforated pipe and stone and drain it away.
Farmers have been doing that in their fields here forever.
TimNJ is offline
Old 01-15-2019, 07:20 AM   #6
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,744
One thing for a farm field, whole other for a garage.
Big Johnson is online now
concretemasonry (01-15-2019)
Old 01-15-2019, 08:11 AM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
That's easy, hire architect Frank Lloyd Wright, he's an expert on building on top of running water.
Inner10 is offline
Fouthgeneration (01-21-2019)
Old 01-15-2019, 08:14 AM   #8
I donít think heís available.
Old 01-15-2019, 09:18 AM   #9
Mordekyle's Avatar
Rewards Points: 6,072
Water feature
Mordekyle is online now
Old 01-15-2019, 09:51 AM   #10
hdavis's Avatar
Rewards Points: 1,808
I wouldn't put a slab on grade in that location.
It can be done and get through the warrantee period. Get an engineer, peel off the loam, put in big rock, smaller rock, mix, gravel, compact as you go. Get the footer above the problem grade.
hdavis is online now
tgeb (01-15-2019)
Old 01-15-2019, 10:02 AM   #11
tgeb's Avatar
Rewards Points: 1,028
A dewatering pit could be pretty handy in this situation.
I run into different unforeseen conditions all the time, and when something like this pops up, I inform the owner or GC and tell them the correct path forward is to employ an engineer to design a plan of action that will work for the long run.
I'm smart enough to make recommendations, but also smart enough to know that I don't want the liability for the building shifting on my shoulders.
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
hdavis (01-15-2019), Sam @ PWE (01-15-2019)
Old 01-15-2019, 12:24 PM   #12
TimNJ's Avatar
It's a garage slab, not house with a full basement.
What is the footing depth requirement?
TimNJ is offline
Old 01-15-2019, 12:43 PM   #13
test
cedarboarder's Avatar
Trade: General
Rewards Points: 815
http://www.vancouversun.com/touch/ne...190/story.html
long story short the drilling company doing geo thermal hit a pressurized aquifer, panics and pulled the drill. Once the water started pouring out he jumped on the next flight to his home country.
the owners of the house had to give the property to the city or face even more liability
To stop the water from flooding the homes around the site the city put in a giant pump and 10 inch pipes to the river about 2 kms away.
Talk about a **** up.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
The Following 2 Users Say Thank You to cedarboarder For This Useful Post:
hdavis (01-15-2019), mrcat (01-15-2019)
Old 01-15-2019, 12:50 PM   #14
hdavis's Avatar
That's awesome!
cedarboarder (01-15-2019), knucklehead (01-15-2019)
Old 01-15-2019, 01:17 PM   #15
test
Trade: General
Rewards Points: 815
https://vancouversun.com/news/local-...aquifer-breach
More updated link. total cost was 10 million to repair. I was working for the City at the time and we put up sand bags all down the block to divert the water just incase.
The Following User Says Thank You to cedarboarder For This Useful Post:
hdavis (01-15-2019)
Old 01-15-2019, 05:32 PM   #16
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Are garages on pontoons common there?
Just asking...
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 01-15-2019, 07:58 PM   #17
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Figure out where the water is coming from.
What do you mean underground stream?
That water is coming from somewhere.
NKLHD
knucklehead is offline
The Following User Says Thank You to knucklehead For This Useful Post:
TimNJ (01-15-2019)
Old 01-15-2019, 08:33 PM   #18
TimNJ's Avatar
That reminds me of a house I worked on back in the mid '80's. There was a group of houses right at the foot of the rte 72 bridge to Long Beach Island. About 5' from the bulkhead of the bay was a 1" galvanized pipe sticking up out of the ground with a 90 on it.
The fresh water flowed from that pipe 24/7 according to the lady whose house we worked on, and she had her house for 15 years and it was there when she moved in.
She told me all the houses on the street would get water from that pipe for drinking rather than the city water.
TimNJ is offline
Old 01-15-2019, 08:38 PM   #19
TimNJ's Avatar
They should just build a nice fancy fountain around it and make it a tourist attraction.
TimNJ is offline
The Following 2 Users Say Thank You to TimNJ For This Useful Post:
cedarboarder (01-15-2019), SmallTownGuy (01-15-2019)
Old 01-15-2019, 08:38 PM   #20
hdavis's Avatar
There are springs and underground streams. Everyone knows springs.
Underground streams run through a layer that percs well, with an impermiable layer below.
dayexco (01-15-2019), Fouthgeneration (01-21-2019)
Got a subpoena today to be an "expert witness".. barry1219 General Discussion 55 05-23-2013 09:29 PM
Garage Floor Epoxy We Fix Houses Painting & Finish Work 9 12-31-2012 11:37 AM
2 spare breakers 15 & 20a, want to wire outlets in garage pitterpat Electrical 8 05-13-2012 02:58 PM
Started new job, Look what i found today....UGH.... maleko Decks & Fencing 10 07-07-2011 08:17 AM
I had to Pass on a 60 K Garage today... JonM General Discussion 18 07-02-2009 12:48 PM
