Estimating Dump Truck Materials - Excavation & Site Work - Contractor Talk
Old 06-26-2015, 10:44 PM   #1
bdog1234's Avatar
Trade: Contractor
Rewards Points: 335
We just bought a dump truck and have a couple thousand yards of topsoil and fill dirt that we are going to sell from a pond we dug.
We don't have any scales and are wondering if there are any tips or tricks on estimating yardage. I know how to calculate volume and have painted some hash marks on the inside of dump truck corresponding to 5,6,7,8,9 yards but it is not really easy to get a uniform load especially if you are loading from one side and in a hurry. We loaded the truck over a dozen times today.
I err on the side of too much because I don't want to short anyone but I bet on average my loads are close to one yard too much. Is counting buckets better than trying to estimate the load once in the truck? We could do that but we often have two machines loading the truck at once.
bdog1234 is offline
Old 06-27-2015, 09:42 AM   #2
tgeb's Avatar
Rewards Points: 420
Re: Estimating Dump Truck Materials
Load it by the bucket full. Everyone around here loads out bulk mulch and topsoil by the cubic yard.
Know the volume of your loader and adjust accordingly.
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
hdavis (07-03-2015), slowsol (09-03-2015)
Old 06-27-2015, 09:46 AM   #3
diplomat
Golden view's Avatar
Rewards Points: 674
Since you have a couple hundred loads it's worth hitting some scales to calibrate your bucket technique. That way you're not shorting anyone but you'll also avoid getting hit with an overload fine.
Golden view is online now
Old 06-27-2015, 10:48 AM   #4
bdog1234's Avatar
Trade: Contractor
Rewards Points: 335
Thanks guys. We are pretty rural here. Closest scales are 30 miles away. Almost all the dirt has been going within 5-10 miles of me on rural roads. Not too worried about overweight. Have been getting better at estimating it. Waiting on a tractor to pull me out now. Dump truck is stuck in a guys horse pen. Nothing is ever as easy as it seems.
bdog1234 is offline
Old 06-30-2015, 02:05 PM   #5
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
We just count the buckets as we load. It gets hard if you are using a smaller machine because I tend to get distracted quickly and can't remember if that was 12 or 13 I put on. I can usually tell by the hump in the box.
rino1494 is offline
Old 07-02-2015, 02:22 AM   #6
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,381
Most businesses don't make 10% profit... giving away 200 yards or tons of dirt that would make a rent /payment on a truck scale is silly.
Can you even legally sell it by the 'ton' if you aren't measuring it?
Just one greedy customer taught me to how to measure cord wood too a gnat's exhaust.
Fouthgeneration is offline
Old 08-06-2015, 08:32 AM   #7
Hairy Cat's Avatar
Trade: Excavation and grading
Rewards Points: 6
Get a proctor on some of the material. The proctor will tell you what the weight of a cubic foot of material is at 95% compaction. That is pretty similar to what you'd have in the ground for clay materials. Now you have the weight of the soil and how that corresponds to the volume of that soil. Now, go get a weight done at a truck stop of a typical load (you'll need an empty weight and a full weight). Now you know what your truck holds in terms of weight for a typical load. Let's say the truck held 14 tons and your proctor was 105. You take your proctor and multiply it by 27 (27 cubic feet to the cubic yard). 105 X 27 = 2,835 pounds per yard
14 tons X 2,000 pounds per ton = 28,000 pounds.
28,000/2,835 = 9.87 Cubic yards per truck. This is equivalent to what came out of the ground in terms of volume and what the customer can expect in terms of placed yardage.
Hairy Cat is offline
The Following User Says Thank You to Hairy Cat For This Useful Post:
Fouthgeneration (08-06-2015)
Old 09-02-2015, 06:12 PM   #8
Civil Headache's Avatar
Trade: Earthwork
Rewards Points: 26
We always can get about 30-32 tons into truck and pup with a steel box here in Washington, that works out to about 15-17 bank yards and we usually call that 24 truck yards. We use as 1.3-1.5 conversion to loose/truck yards and a 1.8-2.0 conversion to tonnage. the conversion can very from soil type to soil type and moisture content but those figures are pretty solid.
A lot of time we will just settle on calling a truck load 24 yards if we dumping somewhere with no scale and being charged a fee.
Civil Headache is offline
Old 09-02-2015, 06:17 PM   #9
Trade: Earthwork
Rewards Points: 26
FYI - we recently found a pretty cool site for posting your dump sites and export sites. It's basically like a classified for pits and dump sites. www.siteimportexport.com. So far it's worked pretty good for us.
Old 09-03-2015, 07:55 AM   #10
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
freedirt.com is another good one
or filldirt.com
or I think dirtseek.com has the best layout of any site
mrcharles is offline
Old 09-03-2015, 11:39 AM   #11
Trade: Earthwork
Rewards Points: 26
or filldirt.com
I seen those first two before - the layouts are clunky.
That dirtseek.com only has stuff in Michigan. Still think I like site import export the best, IMO. They have ton of pits on there.
Old 12-12-2015, 11:48 PM   #12
Stick-man's Avatar
Trade: Welding, fabrication, repair
Rewards Points: 8
I always knew how many FULL buckets to a truckload. I ran 22' dump trailers. A 973 was 3 buckets, 963 was 4, 953 was 5, and an S300 with a 74" HD tooth bucket was 17. Excavators, I could see in the trailer better so I would do it more by sight.
If you're running on air, there is a scale system that turns the PSI into weight on a gauge, and is rather inexpensive.
Stick-man is offline
Old 12-13-2015, 12:41 AM   #13
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,760
Man, I really want a 963 with a 4n1. I don't need one and my business would likely only use it 10-20 days a year, but it would be awesome.
jhark123 is offline
Old 12-13-2015, 06:01 PM   #14
Stick-man's Avatar
Rewards Points: 8
I've been told that chitcago is one of the few markets for track loaders. And they're all over around here.
Dump Truck Phillip_I General Discussion 21 02-21-2015 07:35 PM
used truck jhammer7 Excavation & Site Work 18 06-01-2013 10:10 PM
Dump truck Daniella2011 Excavation & Site Work 2 11-26-2012 08:42 PM
Trouble with International Dump Truck MRstark44 Vehicles 4 04-28-2011 04:31 PM
Tri-axel dump truck for hire barrett45 Construction 0 06-23-2009 01:12 PM
