Digging Holes - Excavation & Site Work - Contractor Talk
Digging Holes
Old 07-26-2016, 03:21 PM   #1
WAbrothers's Avatar
Rewards Points: 8
Digging Holes
Howdy,
I need to dig 9' holes for light pole bases. The deepest I've ever gone was 4'. I would use an auger with an extension but whoever did demo to the building that this lot stands on did not completely demo the building underground. There's a lot of bricks and concrete mixed in the dirt. I feel like the auger wont work.
Has anyone excavated a larger hole, inserted the sonotube then back filled while compacting?
Thanks,
Woj
WAbrothers is offline
Old 07-26-2016, 06:08 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: Digging Holes
Yes. All the time.
-John
slowsol is offline
Old 07-26-2016, 07:25 PM   #3
hdavis's Avatar
Rewards Points: 1,556
Re: Digging Holes
Cali pointed out that some seismic zones may not allow it - other than that, tamping and filling is done all the time.
hdavis is offline
Old 07-26-2016, 09:14 PM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,938
Re: Digging Holes
Even in seismic zones that's allowed as long as it's compacted properly.
Calidecks is offline
hdavis (07-26-2016)
Old 08-05-2019, 04:30 PM   #5
Thatholedigger's Avatar
Trade: excavation
Rewards Points: 6
Re: Digging Holes
I have a very similar question, but mine is in ultra rock thick soil on the side of a mountain in Colorado. I need 20, 7' foot holes filled with sonotubes. I am afraid that I will break the auger bit on the skid steer at that length in this terreain. what kind of rock blasting equipment exists to take some of the strain off the bit? is there such a thing? I am starting to think I just need to tamp and backfill the entire area. thanks.
Thatholedigger is offline
Old 08-05-2019, 04:53 PM   #6
GC/carpenter
Calidecks's Avatar
Re: Digging Holes
Dexpan?
Mike.
_______________
Old 08-05-2019, 07:56 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 388
Re: Digging Holes
Originally Posted by WAbrothers View Post
Howdy,
Thanks,
Woj
You should check with the Engineer that spec'd the 9' holes how they would like to proceed. To over excavate and insert a form & backfill/compact is called sleeving. Sonotube may not be an acceptable material due to the likelihood of it being damaged. I've done it several times with well casing.
Good Luck....
If you are trying to dig say 2' dia holes in a very rocky terrain you will soon find yourself with a hole 6-7 feet in diameter. You are correct about breaking an auger. You would be doing a lot of drilling into rock and using a lot of dexpan or ecobust. Same as above check with the engineer that spec'd the holes
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (08-05-2019), Fouthgeneration (08-07-2019)
Old 08-06-2019, 09:54 PM   #8
tjbnwi's Avatar
Rewards Points: 1,122
Re: Digging Holes
Micro piles an option?
Call Straightline,
https://www.straightlinepier.com/pro...w/solana-solar
Never heard of these things until I got to Colorado. The builders super explain them to me, seeing them go in is interesting.
tjbnwi is offline
Old 08-06-2019, 10:24 PM   #9
GC/carpenter
Calidecks's Avatar
Re: Digging Holes
Call Straightline,
Nice!
Mike.
_______________
Old 08-07-2019, 08:41 PM   #10
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,335
Re: Digging Holes
Why not get rock driller to drill the holes
Hammer drill core drill rig?
rotary diamond oil field style bit?
Hill side fill and only 7' deep is enough?
Call a rock miner.....
BOOM-BOOM?
Rotary pneumatic/Hydraulic rock drills and rock cracking chemicals?
Buy the POCO pole installer lunch/beers and ask a Pro how they do it in the same area...... Why reinvent the wheel, steal it like a ChiCOM.
Erect the poles, back-fill 7' plus with self compacting fill...
Will the poles last inside a steel pipe poured into 3- 4 yard lump of concrete 7' tall about in side a 3-4' wide tube form (old 500/1000 gasoline tank) don't forget the Ufer ground wires/rods.
There are 110 year old power poles and towers in California land, it can't be Too tough.
Fouthgeneration is offline
Old 08-07-2019, 08:45 PM   #11
GC/carpenter
Calidecks's Avatar
Re: Digging Holes
Maybe you could get an engineer to sign off on tying directly to the rock. It's probably been there for a gazillion years.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Fouthgeneration (08-07-2019), Rio (08-07-2019)
Digging post holes around roots Pie Construction 37 10-20-2014 11:38 PM
Hurd Windows, where are the weep holes Lettusbee Windows, Siding and Doors 13 07-18-2014 08:25 AM
Digging Post holes in winter we R reno General Discussion 21 02-05-2014 08:49 AM
Something keeps digging up my flowers jkfox624 Landscaping 11 02-11-2010 11:53 AM
Tape / other material to hide screw holes in metal door frame? Panzer5 General Discussion 6 06-08-2009 01:44 PM
