Dewatering - Excavation & Site Work - Contractor Talk
Dewatering
Old 12-21-2015, 02:34 PM   #1
dayexco's Avatar
Rewards Points: 652
Dewatering
I know we deal with different soil types.
Locally, areas we have to dewater, we hired well drillers to place us wells, (typically 50 feet apart) with high capacity submersible pumps to lower the static water table.
Sometimes depending on the water table, they had to be placed closer. We preferred this over sand points because it freed up that side of the excavation for the most part.
On clay soils with water bearing sand lenses , we would over excavate 5-6 inches, use 3/4" rock back to grade for a french drain, stick a submersible in there to remove the water.
Worked well for us.
How do you guys do it?
Sent from my SCH-I545 using Tapatalk
dayexco is offline
Old 12-21-2015, 07:06 PM   #2
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
Re: Dewatering
Typically dig a hole to the side deeper than our normal excavation. Place a vertical piece of 12" or larger HDPE in vertically with some holes drilled in it. Fill around with gravel and pump.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
jhark123 (12-22-2015)
Old 12-22-2015, 06:12 PM   #3
dayexco's Avatar
Rewards Points: 652
Re: Dewatering
there are occasions we have to lower the water table 10-12'.
in those areas, typically it's a very clean sand/gravel. you wouldn't be able to get a hole dug to place any pipe like you're talking. we've had situations where we were pumping 300-400 gpm per well.
dayexco is offline
Old 12-22-2015, 07:59 PM   #4
mattg2448's Avatar
Trade: Excavating
Rewards Points: 390
Re: Dewatering
I'm with rino, we use a vertical pipe with a submersible in it. As far as drilling sumps, never seen that around here.
mattg2448 is offline
Old 12-22-2015, 08:56 PM   #5
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
Re: Dewatering
We usually do as Rino explained close to home.
FIL's old company worked close to Bethany Beach Delaware for a couple years, when they first started to do pond work they used well point dewatering. Bunch of "straws" for lack of a better word in the ground all tied to a large pipe and pump the entire perimeter. Worked great but was very $$$$! They installed everything and left about 20' hole for the equipment to move in and out of the ponds.
Moxley-Kidwell is offline
Old 12-22-2015, 09:40 PM   #6
Vagitarian
rino1494's Avatar
Re: Dewatering
I'm in the mountains, luckily I do not have to deal with well points.
rino1494 is offline
Old 12-24-2015, 07:44 AM   #7
JDavis21835's Avatar
Trade: Excavation
Rewards Points: 386
Re: Dewatering
You get much farther west of you, and you will see it. Around the Flint and Clio area I've been around a few deep jobs that required dewatering. One was a trunk line sewer, the total depth was 50 feet. On that job Mersino drilled 8 inch wells in every 25 feet and dropped big submersibles to pump 24/7.
In the Clio area there is a sand layer on top of clay, it has a lot of water in the area. Glavve did a sanitary main that was 20 feet deep on Vienna rd. They had a point dewatering system that was running constantly. They were pumping almost 500,000 gallons a day, and still were dealing with 2 feet of water in the bottom.
JDavis21835 is offline
Old 12-25-2015, 07:11 AM   #8
Ramrod, Troubleshooter
Bondo's Avatar
Trade: Blacktop,+ Dirt, along with about everything else
Rewards Points: 34
Re: Dewatering
Ayuh,.... 'round here in Jefferson County, We've got bedrock, or clay,....
The clay over burden can be from nothin' to 40',....
When openin' up a jobsite, such as an industrial park, deep ditchin' is how we can generally lower the water table of the area,....
This park, 'bout 100 acres was opened in the late '80s, has ditches 3' deep on the high side, which puts 'em on bedrock, to 'bout 20' deep at the low end, which isn't down to bedrock, but still dries out the upper layers,....
Last year, We did the ground work for a medical arts buildin',...
It was a swamp, several feet of over burden, then pitched bedrock,....
We stripped the over burden, 'n stacked it outa the way, then hammered trenches in the bedrock to drain the water around the site,....
Then regraded the site in crushed limestone up to near the original grade, with all the infrastructure in place, poured the foundation, built the buildin', paved the parkin' lot, 'n used the dried out overburden dirt for soils to build the lawns,...
Bondo is offline
Old 12-25-2015, 09:40 AM   #9
mattg2448's Avatar
Trade: Excavating
Rewards Points: 390
Re: Dewatering
On the mess of a job I'm doing now, I cut a 1/4 of the detention pond and cut ditches from across the whole site into the pond and have a 4 inch pump running non stop
Old 12-25-2015, 12:17 PM   #10
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
Re: Dewatering
We use stand up pipe also. Luckily, we have had any jobs that required well points.
Upchuck is offline
Old 01-04-2016, 05:44 PM   #11
dayexco's Avatar
Rewards Points: 652
Re: Dewatering
We have soils here that will give up several hundred gallons of water a minute with Wells spaced 50 feet apart.
As I said earlier, without points or wells, you wouldn't get 5 feet in the ground.
dayexco is offline
Old 01-04-2016, 07:08 PM   #12
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Re: Dewatering
I think the technical term for that is a lake.
Metro M & L is offline
Old 01-05-2016, 12:13 AM   #13
mattg2448's Avatar
Trade: Excavating
Rewards Points: 390
Re: Dewatering
Haha
Old 01-19-2016, 10:26 AM   #14
dayexco's Avatar
Rewards Points: 652
Re: Dewatering
Here's a pic of my competitor's setup. Works great, but I don't like having both sides of my excavation tired up.
Stringing pipe, swinging pipe over it, laborers stumbling over it. ..
Personally, I like wells.
We can get at least a 40-50' spread between the wells which gives us a lot better access to the hole.
Another thing, the driller would have these in place and pumping by the time we got there, and pulled their well casings after we were done.
dayexco is offline
Old 01-19-2016, 09:05 PM   #15
Stud
Upchuck's Avatar
Trade: Excavation
Rewards Points: 660
Re: Dewatering
Seems like a pain to work around that
Upchuck is offline
Old 01-20-2016, 12:02 AM   #16
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,766
Re: Dewatering
Is there are submersible in each hole?
jhark123 is offline
Old 01-20-2016, 07:31 AM   #17
dayexco's Avatar
Rewards Points: 652
Re: Dewatering
In the picture above? No those are all sand points hooked up by the red hoses to a 10" pump st the end of the 8" manifold there.
dayexco is offline
The Following 2 Users Say Thank You to dayexco For This Useful Post:
JDavis21835 (01-23-2016), jhark123 (01-21-2016)
Old 01-20-2016, 09:26 PM   #18
Rewards Points: 286
Re: Dewatering
That setup is the only "professional" dewatering that I've ever been around. Worked like a charm at or even below sea level about 4-5 miles from the atlantic. I can see it being a pia to work around though.
The only thing we did around it was drive equipment in and out of sediment ponds while dewatering, there was a good size gap for equipment with a bunch of the wells surrounding the entire perimeter. Amazing how much water they pull from the ground.
Old 01-21-2016, 09:45 AM   #19
dayexco's Avatar
Rewards Points: 652
Re: Dewatering
Yeah, each one of those points are good for 20-30 gpm
dayexco is offline
Dewatering equipment Precision10 Excavation & Site Work 2 04-02-2012 09:14 PM
digging geothermal horizontal loops in high water table AustinDB Excavation & Site Work 11 05-31-2010 08:28 PM
Well point dewatering guyute65045 Excavation & Site Work 4 01-03-2010 04:36 PM
Who has welpoint dewatering equip in NE guyute65045 Excavation & Site Work 0 07-22-2009 06:24 AM
Shared Sump (Dewatering) and Sewerage Ejector Pump Michael Thomas Plumbing 22 03-31-2009 08:56 AM
