Concrete Overlays, Anyone Use One? - Excavation & Site Work - Contractor Talk
Old 08-23-2012, 04:41 PM   #1
Little's Avatar
Trade: Commercial Construction
Rewards Points: 252
I'm doing some work for a friend which consists of ripping out his existing driveway and widening. When I went over to look at the job I seen that just the front left corner (2ftx3ft) of his garage apron was cracked and had sunken about 3/4". The rest of the apron (3ft x 12ft wide) is still in great shape with no cracks minus the fact that the stones are showing since the house is old. Now the problem is that they poured the apron and the garage floor monolithic and I would not be able to sawcut all the way to the edges to remove the whole apron. Instead, I'm considering Overlaying the existing apron after i cut out just the broken piece and repouring. Can anyone recommend a good product? I have seen a product by Ardex for exterior as well as from sakrete. Also I plan on only skim coating maybe 1/8" thick.
Commercial Construction, Central Jersey
Little is offline
Old 08-23-2012, 06:32 PM   #2
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,058
Re: Concrete Overlays, Anyone Use One?
I've used "Top And Bond", I think by Quickcrete, with good results.
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 08-24-2012, 02:11 AM   #3
valparaiso's Avatar
Trade: general
Rewards Points: 75
euclid's ultra thin top
valparaiso is offline
Old 08-24-2012, 07:09 PM   #4
Miss Brown's Avatar
Trade: Wood n' concrete finishes
Rewards Points: 150
I like ardex, but if the color doesn't matter quickcrete vinyl patch does just fine. I've done a few floors with vinyl patch n' acid stain...stuck right good. Ardex appears to be more expensive. (Vinyl Patch is really dark, ardex is light grey, or white.)
Miss Brown is offline
I need a fence post mounted on a concrete pad. JT Wood Decks & Fencing 23 10-06-2011 11:42 PM
driveway concrete aydin_eng Concrete & Paving 4 03-10-2010 10:36 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 10:03 PM
I need a to pour 1/4 yard of black concrete... ruskent Masonry 9 05-25-2009 11:50 AM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 08:10 PM
