Cat 287B Joystick Problem - Excavation & Site Work - Contractor Talk
Old 08-11-2018, 01:33 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,926
Just bought a 2006 Cat 287B.
Nice machine, good shape, but.....
I just got it home, and ran it for about an hour, and now the right hand joystick (bucket control) will just stop working randomly.
Machine still drives, but bucket stops working.
No lights on, like hydraulic switch off, or parking brake on.
I guessing anything from a faulty seat switch, or bar switch, to a failed relay in the ECM, or an actual problem in the joystick pilot controls.
Anyone had a similar problem?
Thanks in advance.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 08-11-2018, 01:42 PM   #2
dayexco's Avatar
Rewards Points: 88
Re: Cat 287B Joystick Problem
my guess is bad joy stick.
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
Seven-Delta-FortyOne (08-11-2018)
Old 08-11-2018, 04:32 PM   #3
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 712
I wouldn't rush right out and buy a new control just yet.
My New Holland would randomly shut down the controls while climbing a steep slope, turned out to be a wire under the seat had been run under the seat bracket and the bracket had a burr on it that would stab the wire under certain conditions.
Took me a while to find that one.
A guy I know who has an asv rc60 had a control issue and decided to replace the right hand controller and it did not fix it, turned out to be one of the solenoid valves was sticking sometimes.
I am not familiar with the Cat machines as far as how they work, by wire or sub hydraulic system for the control.
"Sounds" like a wiring/electrical problem to me at this point.
Sorry, I don't have much more...
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Old 08-11-2018, 04:35 PM   #4
tgeb's Avatar
Rewards Points: 712
Actually, I'd say that if it works OK sometimes, that it is not the controller. My thoughts are the controller either functions, or it does not, no in between.
www.gebcon.com
tgeb is offline
Old 08-14-2018, 09:27 AM   #5
Trade: Highwayman
Think I found it.
Door switch.
It's the only safety switch that will allow the machine to track, but shut down the bucket. All others shut everything down.
I noticed the door frame is a little wobbly, and it's easy to shut it, and think it's shut all the way, but it ain't. Add a little rattling, and it stops working.
I've been running it for a couple days now, paying attention to the door being shut all the way, and so far, no problems.
Get Off My Lawn.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
mrcat (08-14-2018), tgeb (08-14-2018), TheConstruct (08-14-2018)
Duraspin deck screw problem HandyHails Decks & Fencing 9 06-04-2012 05:33 PM
Floor joist squeak problem MuttMutt Flooring 9 05-12-2012 01:17 PM
Major problem spraying "SW All Surface Enamel" in Black. GHPJerry Painting & Finish Work 19 08-01-2011 09:15 PM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
