Case 580 Packings - Excavation & Site Work - Contractor Talk
Case 580 Packings
Old 12-07-2011, 09:36 PM   #1
aedwards's Avatar
Trade: excavation
Case 580 Packings
I have a Case 580sk and need a packing done on my clam bucket. I've tried to do it myself and did a number on my back. My efforts were a failure and need to find somebody I can send my ram to and have it packed. I've asked all the mechanics around my town and they all say they send them off so I figure I can send it off myself and not pay them to do it for me.
aedwards is offline
Old 12-07-2011, 09:42 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,966
Re: Case 580 Packings
Start here:
http://www.casece.com/wps/portal/cas...andsite_geo=NA
griz is offline
Old 12-07-2011, 09:47 PM   #3
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Must be someone around your area who specializes in hydrolics. Ask around some other companies of where they get there rams repaired. Do you have any guys who come around to jobsites who do equipment repair, welding, fabricating that may have some experience in this?
woodchuck2 is offline
Old 12-08-2011, 10:31 AM   #4
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
If you asked "mechanics" and told you they send them off, they are either, not a mechanic or yanking your chain. It is a 20 minute job.
Do you have a gladhand tool ?
You can probably find a mechanic that works for the dealer to do it on the side or a mechanic that works for a site contractor that can do it on the weekend. Ask around.
rino1494 is offline
The Following User Says Thank You to rino1494 For This Useful Post:
backhoe1 (12-09-2011)
Old 12-09-2011, 08:17 AM   #5
Head Grunt
woodchuck2's Avatar
I agree with Rhino, i have taken rams apart with no issue. The last one was bent and i pulled the piston with the ram still on the machine "mini-ex". I just put the main boom down, pulled the pins, stood the ram up and strapped it to the boom, unthreaded the collar "packing nut" and used the machines hydrolics to push the piston out. The guy who owned the machine picked the piston up out when it came to the top. I made sure the valves were centered and we never lost any oil when the machine shut off. We pulled the nut off the back and slid the packing nut off the rear. The piston was bent about 6" from the eye so we had to have the packing nut off so it could be pressed straight. Seemed easy to me. The owner went ahead and rebuilt the packing nut and re-installed everything. Piston is now straight and no leaks.
Case N Series Backhoe JCDIRT Excavation & Site Work 5 10-18-2010 09:22 AM
Cat 5CP2130 Case Repair GaryPDX Pressure Washing 1 10-11-2010 03:40 PM
Track Loader Cat or Case? lazerguy Excavation & Site Work 19 08-05-2010 01:32 PM
looking for Worm drive case ideas Erikfsn Tools & Equipment 14 05-08-2010 03:09 PM
WTB - Makita 4 or 4 1/2" grinder case only. ryan.s Contractor Swap 2 02-20-2006 02:14 AM
